ELEMENT 30/220-240/24
    AMSOSRAM(艾迈斯半导体)
    AC/DC LED Power Supply 30W Single 4-Pin
ELEMENT 30/220-240/24 数据手册
OPTOTRONIC® LED Power Supply Product Data Sheet ELEMENT 30/220-240/24 Constant Voltage LED Power Supply 24V The reliable choice for the decorative lighting, compact size and well tested by Osram quality standards, fits all flex applications in retails, hotel, restaurants and industries. Benefits Compatible with OSRAM Flex; High efficiency up to 86% Class II design for wide applications Excellent price/quality/watt ratio Applications Hospitality – decorative lighting night light Restaurants – decorative lighting Shops – decorative lighting, shelf lighting Residential – cove lighting, under cabinet lighting Housing material: plastic, grey Approval marks (Under preparation if not shown on label) L: 140mm L1: 126mm W: 45mm W1: 33.4mm H: 27.5mm D: 3.2mm R: 2.1mm Product Features  24V constant output voltage  Overload protection  SELV  Over temperature protection  Output power up to 30W  Short circuit protection  Mains voltage 220 – 240V  Wide ta range: -20…+45 °C  High efficiency up to 86%  Case temperature up to 85 °C  50’000 h lifetime at tc = 75 °C  3 years Guarantee 1 Edition: Feb 2017 Ver.: 1.2 Status: Preliminary Misprints and technical changes excepted Element LED Power Supply Product Data Sheet ENVIRONMENT OUTPUT INPUT Electrical Specifications Item Value Unit Nominal voltage Nominal frequency AC voltage range Nominal current Total Harmonic Distortion (THD) Power factor Efficiency Protection class Inrush current Max. units per circuit breaker Touch current Nominal voltage range Minimum voltage Maximum voltage Voltage ripple (typical) Nominal power range Maximum power Galvanic isolation Ambient temperature range ta Maximum case temperature tc Max. case temp. in fault condition Storage temperature range Relative humidity Surge transient protection Environmental rating IP rating Mains switching cycles Expected lifetime 220 – 240 50 - 60 198 – 264 0.2 < 20 > 0.9 86 II
ELEMENT 30/220-240/24 价格&库存
很抱歉,暂时无法提供与“ELEMENT 30/220-240/24”相匹配的价格&库存,您可以联系我们找货
