Product datasheet
DULUX D 13 W/827
OSRAM DULUX D | CFLni, 2 tubes, with 2-pin base for CCG operation
Areas of application
Offices, public buildings
Shops
Supermarkets and department stores
Hotels, restaurants
Industry
__
Product benefits
Extremly economical
Good quality of light
Excellent luminous flux
Long service life
Improved maintenance
Product features
Average life: 10,000 h
Color rendering index R : 80…89
a
Short and compact pin-base lamp with double-turn tubes
Single-ended two-pin plug-in G24d base
August 25, 2014, 16:39:18
DULUX D 13 W/827
© 2014, OSRAM GmbH. All rights reserved.
Page 1 of 6
Product datasheet
Technical data
Electrical data
Nominal wattage
13.00 W
Rated wattage
13.00 W
Energy consumption
17 kWh/1000h
Photometrical data
__
Nominal luminous flux
900 lm
Rated luminous flux
900 lm
Color temperature
2700 K
Light color
827
Light color as per EN 12464-1
LUMILUX INTERNA
Color rendering index Ra
80…89
Luminous flux at 25 °C
900 lm
Rated LLMF at 4,000 h
0.78
Rated LLMF at 6,000 h
0.76
Rated LLMF at 8,000 h
0.75
Luminance
4 cd/cm²
Color rendering group
1B
Dimensions & weight
Product line drawing
Base
Overall length
138.0 mm
Product weight
40.00 g
Tube diameter
12 mm
Length
138.0 mm
DULUX D 13 W/827
Page 2 of 6
Product datasheet
Length acc. to IEC standard
130 mm
Length with base excl. base pins/connection
115.00 mm
Colors & materials
Lamp mercury content
1.4 mg
Temperatures
Rated ambient temp.w.max.luminous flux
25.0 °C
Lifespan
__
Nominal lamp life time
10000 h
Rated lamp life time
10000 h
Service life
6500 h
Rated lamp survival factor at 2,000 h
0.98
Rated lamp survival factor at 4,000 h
0.98
Rated lamp survival factor at 6,000 h
0.95
Rated lamp survival factor at 8,000 h
0.81
Operation mode LLMF/LSF
50 Hz
Lifespan
10000 h 1)
1) With CCG/LLCG
Additional product data
DULUX D 13 W/827
Page 3 of 6
Product datasheet
Spectral power distribution
__
Base (standard designation)
G24d-1
Appropriate disposal acc. to WEEE
Yes
Capabilities
Suitable for indoor
Yes
Certificates & standards
Energy efficiency class
A
Country specific categorizations
ILCOS
FSQ-13/827-I-G24d-1
Country specific information
Product code
METEL code
SEG number
STK number
UK Org
4050300008127
OSRDD13827
8330128
4933873
DULUX D 13 W/827
Page 4 of 6
Product datasheet
Guarantee
Equipment / Accessories
Suitable for operation on conventional control gear
Safety advice
In case of lamp breakage: www.osram.com/brokenlamp
__
Circuit diagram
Circuit diagram
Logistical Data
Product code
Product description
Packaging unit
(Pieces/Unit)
Dimensions (height x
width x length)
Volume
Gross weight
4050300008127
DULUX D 13 W/827
Folding carton box
1
39 mm x 35 mm x
145 mm
0.20 dm³
52.00 g
4050300238487
DULUX D 13 W/827
Shipping carton box
10
121 mm x 158 mm x
153 mm
2.93 dm³
583.00 g
The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or
more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit.
DULUX D 13 W/827
Page 5 of 6
Product datasheet
Disclaimer
Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release.
__
DULUX D 13 W/827
Page 6 of 6
很抱歉,暂时无法提供与“DD1382”相匹配的价格&库存,您可以联系我们找货
