DL2484
DL2484
    AMSOSRAM(艾迈斯半导体)
    Module
    OSRAM - DL2484 - LAMP, DULUX, L, CW, 24W
DL2484 数据手册
Product datasheet DULUX L 24 W/840 2G11 OSRAM DULUX L LUMILUX | CFLni, with 4-pin 2G11 base for ECG/CCG operation Areas of application Offices, public buildings Shops Supermarkets and department stores Hotels, restaurants Industry __ Product benefits Very economical Outstanding luminous flux Outstanding luminous efficiency Long service life OSRAM System+ Guarantee in combination with OSRAM QUICKTRONIC ECG Less than half as long as tubular fluorescent lamps Improved maintenance Product features Short and compact pin-base lamp with double-turn tubes Single-ended four-pin plug-in 2G11 base Dimmable (1…100 % with QUICKTRONIC QTi DALI/DIM) Color rendering index R : 80…89 a Average life: 20,000 h (with QUICKTRONIC) Operates on battery, solar and AC power with suitable electronic control gear Also available in blue August 25, 2014, 12:57:05 DULUX L 24 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 1 of 8 Product datasheet Technical data Electrical data Nominal wattage 24.00 W Rated wattage 24.00 W Energy consumption 27 kWh/1000h Photometrical data __ Nominal luminous flux 1800 lm Rated luminous flux 1800 lm Color temperature 4000 K Light color 840 Light color as per EN 12464-1 LUMILUX Cool White Color rendering index Ra 80…89 Luminous flux at 25 °C 1800 lm Rated LLMF at 4,000 h 0.90 Rated LLMF at 6,000 h 0.88 Rated LLMF at 8,000 h 0.86 Rated LLMF at 12,000 h 0.84 Rated LLMF at 16,000 h 0.81 Rated LLMF at 20,000 h 0.80 Luminance 2.1 cd/cm² Color rendering group 1B Dimensions & weight Product line drawing Overall length August 25, 2014, 12:57:05 DULUX L 24 W/840 2G11 Base 317.0 mm © 2014, OSRAM GmbH. All rights reserved. Page 2 of 8 Product datasheet Product weight 75.00 g Tube diameter 17.5 mm Length 317.0 mm Length acc. to IEC standard 320 mm Length with base excl. base pins/connection 317.00 mm Colors & materials Lamp mercury content 1.7 mg Temperatures Rated ambient temp.w.max.luminous flux 25.0 °C Lifespan __ Nominal lamp life time 20000 h Rated lamp life time 20000 h Service life 13000 h 1) Rated lamp survival factor at 2,000 h 0.99 Rated lamp survival factor at 4,000 h 0.99 Rated lamp survival factor at 6,000 h 0.99 Rated lamp survival factor at 8,000 h 0.99 Rated lamp survival factor at 12,000 h 0.95 Rated lamp survival factor at 16,000 h 0.81 Rated lamp survival factor at 20,000 h 0.50 Operation mode LLMF/LSF HF Lifespan 20000 h 1) 1) With preheat ECG Additional product data August 25, 2014, 12:57:05 DULUX L 24 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 3 of 8 Product datasheet Spectral power distribution __ Base (standard designation) 2G11 Appropriate disposal acc. to WEEE Yes Footnote only for product For ECG and CCG operation Capabilities Suitable for indoor Yes Certificates & standards Energy efficiency class A Country specific categorizations ILCOS FSD-24/840-E-2G11-43,9/317 Country specific information Product code METEL code SEG number STK number UK Org 4050300010755 OSRDL24840 8330452 4933884 - August 25, 2014, 12:57:05 DULUX L 24 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 4 of 8 Product datasheet Lamp-ECG combination (System) Product name Product name ECG EAN Nominal current Nominal wattage + Power loss Luminous flux at 35 °C Number of lighting outlets DULUX L 24W/840 2G11 QT-ECO 1x18-24/220-240 L 4050300660417 0.16 A 22.50 W 1600 lm 1 QT-ECO 1x18-24/220-240 S 4050300638560 0.16 A 22.50 W 1600 lm 1 QT-M 2x26-42/220-240 S 4008321110022 0.23 A 54.00 W 1750 lm 2 QTP-DL 1x18-24 4008321117861 0.115 A 26.00 W 1800 lm 1 QTP-DL 2x18-24 4008321117885 0.22 A 49.00 W 1800 lm 2 QTP-M 1x26-42 4008321329134 0.12 A 25.00 W 1750 lm 1 QTP-M 2x26-32 4008321329158 0.22 A 48.00 W 1750 lm 2 QTP-OPTIMAL 1x18-40 4008321873743 0.12 A 27.00 W 1750 lm 1 QTP-OPTIMAL 2x18-40 4008321873767 0.23 A 53.00 W 1750 lm 2 QTi 1x14/24 DIM 4050300870922 0.11 A 25.00 W 1800 lm 1 QTi 2x14/24 DIM 4050300870946 0.22 A 49.00 W 1800 lm 2 QTi 3x14/24 DIM 4008321069719 0.32 A 73.00 W 1800 lm 3 QTi 4x14/24 DIM 4008321069993 0.43 A 98.00 W 1800 lm 4 QTi DALI 1x14/24 DIM 4050300870380 0.11 A 25.00 W 1600 lm 1 QTi DALI 2x14/24 DIM 4050300870861 0.22 A 49.00 W 1800 lm 2 QTi DALI 3x14/24 DIM 4008321069955 0.32 A 73.00 W 1800 lm 3 QTi DALI 4x14/24 DIM 4008321070036 0.43 A 98.00 W 1800 lm 4 QTi DALI-T/E 1x18-57 DIM 4008321060808 0.12 A 26.00 W 1200 lm 1 __ August 25, 2014, 12:57:05 DULUX L 24 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 5 of 8 Product datasheet Product name Product name ECG EAN Nominal current Nominal wattage + Power loss Luminous flux at 35 °C Number of lighting outlets QTi DALI-T/E 2x18-42 DIM 4008321060822 0.22 A 51.00 W 1200 lm 2 __ August 25, 2014, 12:57:05 DULUX L 24 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 6 of 8 Product datasheet Guarantee Equipment / Accessories Suitable for standard control gears and starters Suitable for operation on electronic and conventional control gear __ Circuit diagram Circuit diagram Circuit diagram Logistical Data Product code Product description Packaging unit (Pieces/Unit) Dimensions (height x width x length) Volume Gross weight 4050300010755 DULUX L 24 W/840 2G11 Folding carton box 1 46 mm x 27 mm x 347 mm 0.43 dm³ 98.50 g 4050300242330 DULUX L 24 W/840 2G11 Shipping carton box 10 136 mm x 103 mm x 361 mm 5.06 dm³ 1099.00 g The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. References / Links August 25, 2014, 12:57:05 DULUX L 24 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 7 of 8 Product datasheet For more information on QUICKTRONIC electronic control gear go to www.osram.com/QUICKTRONIC For more information on the system guarantee and the terms and conditions of the guarantee visit www.osram.com/system-guarantee Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. __ August 25, 2014, 12:57:05 DULUX L 24 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 8 of 8
DL2484 价格&库存
很抱歉,暂时无法提供与“DL2484”相匹配的价格&库存,您可以联系我们找货
