Product datasheet
DULUX S/E 9 W/840
OSRAM DULUX S/E | Short CFLni, with 4-pin base for ECG operation
Areas of application
Offices, public buildings
Shops
Supermarkets and department stores
Hotels, restaurants
__
Product benefits
Extremly economical
Good quality of light
Improved maintenance
Low power consumption (7 W, 9 W, 11 W)
Long service life
Extremely low profile
Product features
Average life: 20,000 h (with QUICKTRONIC)
Color rendering index R : 80…89
a
Dimmable (3…100 %)
Short and compact pin-base lamps with single-turn tubes
Single-ended four-pin plug-in 2G7 base
Operates on battery, solar and AC power with suitable electronic control gear
August 25, 2014, 16:39:16
DULUX S/E 9 W/840
© 2014, OSRAM GmbH. All rights reserved.
Page 1 of 7
Product datasheet
Technical data
Electrical data
Nominal wattage
8.00 W
Rated wattage
8.00 W
Rated lamp efficacy (HF data 25 °C)
Under clarification by authority and standardization
body
Energy consumption
12 kWh/1000h
Photometrical data
__
Nominal luminous flux
600 lm
Rated luminous flux
600 lm
Color temperature
4000 K
Light color
840
Light color as per EN 12464-1
LUMILUX Cool White
Color rendering index Ra
80…89
Luminous flux at 25 °C
600 lm
Rated LLMF at 4,000 h
0.86
Rated LLMF at 6,000 h
0.84
Rated LLMF at 8,000 h
0.82
Rated LLMF at 12,000 h
0.79
Rated LLMF at 16,000 h
0.78
Rated LLMF at 20,000 h
0.76
Luminance
2.8 cd/cm²
Color rendering group
1B
Dimensions & weight
DULUX S/E 9 W/840
Page 2 of 7
Product datasheet
Product line drawing
__
Base
Overall length
144.0 mm
Product weight
26.20 g
Tube diameter
12 mm
Length
144.0 mm
Length acc. to IEC standard
145 mm
Length with base excl. base pins/connection
144.00 mm
Colors & materials
Lamp mercury content
1.4 mg
Temperatures
Rated ambient temp.w.max.luminous flux
25.0 °C
Lifespan
Nominal lamp life time
20000 h
Rated lamp life time
20000 h
Service life
13000 h 1)
Rated lamp survival factor at 2,000 h
0.99
Rated lamp survival factor at 4,000 h
0.99
Rated lamp survival factor at 6,000 h
0.99
Rated lamp survival factor at 8,000 h
0.99
Rated lamp survival factor at 12,000 h
0.95
Rated lamp survival factor at 16,000 h
0.81
Rated lamp survival factor at 20,000 h
0.50
Operation mode LLMF/LSF
HF
Lifespan
20000 h 1)
DULUX S/E 9 W/840
Page 3 of 7
Product datasheet
1) With preheat ECG
Additional product data
__
Spectral power distribution
Base (standard designation)
2G7
Appropriate disposal acc. to WEEE
Yes
Footnote only for product
For ECG operation only
Capabilities
Suitable for indoor
Yes
Certificates & standards
Energy efficiency class
A
Country specific categorizations
ILCOS
FSDH-9/840-/P/-2G7
Country specific information
Product code
METEL code
SEG number
STK number
UK Org
4050300020174
OSRDSE9840
8330060
4933953
DULUX S/E 9 W/840
Page 4 of 7
Product datasheet
Lamp-ECG combination (System)
Product name
Product name ECG
EAN
Nominal current
Nominal wattage
+ Power loss
Luminous flux at
25 °C
Number of
lighting outlets
DULUX S/E 9W/840 2G7
DT-S/E 5-11/220-240 L
4008321181473
0.08 A
10.50 W
600 lm
1
DT-S/E 5-11/220-240 S
4008321181459
0.08 A
10.50 W
600 lm
1
QT-ECO 1x4-16/220-240 L
4050300660370
0.07 A
10.00 W
600 lm
1
QT-ECO 1x4-16/220-240 S
4050300638584
0.07 A
10.00 W
600 lm
1
QT-ECO 2x5-11/220-240 S
4050300821504
0.13 A
18.00 W
550 lm
2
QTP-D/E 1x10-13
4008321181572
0.05 A
9.50 W
600 lm
1
QTP-D/E 2x10-13
4008321181596
0.09 A
18.00 W
600 lm
2
__
DULUX S/E 9 W/840
Page 5 of 7
Product datasheet
Guarantee
Equipment / Accessories
Suitable for operation on electronic control gear
Safety advice
In case of lamp breakage: www.osram.com/brokenlamp
__
Others graphics
DULUX S/E 9 W/840
Circuit diagram
Circuit diagram
Page 6 of 7
Product datasheet
Circuit diagram
Logistical Data
__
Product code
Product description
Packaging unit
(Pieces/Unit)
Dimensions (height x
width x length)
Volume
Gross weight
4050300020174
DULUX S/E 9 W/840
Folding carton box
1
39 mm x 23 mm x
159 mm
0.14 dm³
33.20 g
4050300252988
DULUX S/E 9 W/840
Shipping carton box
10
105 mm x 136 mm x
143 mm
2.04 dm³
378.00 g
The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or
more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit.
References / Links
For more information on QUICKTRONIC electronic control gear go to
www.osram.com/QUICKTRONIC
Disclaimer
Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release.
DULUX S/E 9 W/840
Page 7 of 7
很抱歉,暂时无法提供与“DSE984”相匹配的价格&库存,您可以联系我们找货
