FX-SC08-G2-CT4PJ-IP54KIT
    AMSOSRAM(艾迈斯半导体)
    OSRAM - FX-SC08-G2-CT4PJ-IP54KIT - LED Accessories, Strip To Strip Connector IP54 Sleeve, SLIMCONNE...
FX-SC08-G2-CT4PJ-IP54KIT 数据手册
www.osram.com/flex FLEXESSORIES SLIMCONNECT SYSTEM 08 – G2 TECHNICAL DATASHEET Enjoy full flexibility in lighting design. Connect easily modules without any need of tools. The SLIMCONNECT SYSTEM is made for minimalistic integration into aluminum profiles and luminaires. Yet offering a strong retention force to the module and extra mounting support through the additional adhesive back on the connectors’ backside. Key Features & Benefits ‒ ‒ ‒ ‒ ‒ ‒ Assembly without tools Robust connection Fits into SLIM TRACK 3M Adhesive tape on the back to support mounting Keep LED pitch at board to board connection Extension wires for connection across corners Possible Applications ‒ Applying to LINEARlight Flex and Value Flex G3 LED strips. Due to the special conditions of manufacturing processes of LED, the typical data of technical parameters ca n only reflect statistical figures and do not necessarily correspond to the actual parameters of each single product which could differ from the typical data. Subject to change without notice. Errors and omissions excepted. Version: 2017-12-18 01 FLEXESSORIES | SLIMCONNECT SYSTEM 08 – G2 | TECHNICAL DATASHEET Power feed for single channel / color Power feeders to connect modules with single white and single monochromatic light Use with Linearlight Flex Advanced, Monochrome, Shortpitch, Power, Shop White, Meat White, Veggie White, Value Flex G3 Description 2pin power feeding connector with 50cm cable 2pin power feeding connector with 1m cable Product FX-SC08-G2-CT2PF-0500 FX-SC08-G2-CT2PF-1000 Cable length 500 mm 1,000 mm Rated insulation voltage < 25 V < 25 V Rated current 5A 5A Connector closing force
FX-SC08-G2-CT4PJ-IP54KIT 价格&库存
很抱歉,暂时无法提供与“FX-SC08-G2-CT4PJ-IP54KIT”相匹配的价格&库存,您可以联系我们找货
