4058075000285
4058075000285
    AMSOSRAM(艾迈斯半导体)
    OSRAM - 4058075000285 - LED Light Bar, Warm White, 800 lm, 8 W, 230 V, 573 mm, IP20
4058075000285 数据手册
Product family datasheet LEDVANCE® Linear Indoor luminaires | LED surface-mounted luminaire Area of application      General indoor illumination Corridors, entrance lighting Accent lighting, public areas Cove lighting Shelves, furniture integration or under cabinet lighting  Seamless linear lighting Product benefits          Compact dimensions Easy to install in two different mounting angles Energy savings of up to 45% compared to conventional linear luminaires Complete mounting and connecting accessories included Connect up to 10 luminaires in series On/off switch on luminaire Different lengths available For seamless lines of light Available certificates: CE, CB, TUEV SUED Product features          Luminaire efficacy: up to 100 lm/W Luminous flux: up to 1450lm Available with color temperature: 3000K, 4000K Beam angle: 140° Type of protection: IP20 White polycarbonate housing and diffuser Ambient operating temperature: -20…+40 °C Lifetime (L70/B50): up to 30000h 3-years guarantee V1-2016 Page 1 of 2 © 2016, LEDVANCE GmbH. All rights reserved. Product family datasheet Technical data Nominal wattage [W] Nominal voltage [V] Power factor [λ] Luminous flux [lm] Luminaire efficacy [lm/W] Colour temperature [K] CRI index [Ra] 4058075000247 4W 230V > 0.5 400 100 3000K >80 4058075000261 4W 230V > 0.5 450 110 4000K >80 Linear LED 600 8W/3000K 230V IP20 4058075000285 8W 230V > 0.5 800 100 3000K >80 Linear LED 600 8W/4000K 230V IP20 4058075000308 8W 230V > 0.5 800 100 4000K >80 Linear LED 1200 14W/3000K 230V IP20 4058075000322 14W 230V > 0.5 1400 100 3000K >80 Linear LED 1200 14W/4000K 230V IP20 4058075000346 14W 230V > 0.5 1500 100 4000K >80 Product description Beam angle Rated life time L70 / B50 [h] Type of protection IP rating Protection class Product size l x w or Ø [mm] Height h [mm] Body colour Linear LED 300 4W/3000K 230V IP20 140° 30000 20 II 313 x 28 36 white Linear LED 300 4W/4000K 230V IP20 140° 30000 20 II 313 x 28 36 white Linear LED 600 8W/3000K 230V IP20 140° 30000 20 II 573 x 28 36 white Linear LED 600 8W/4000K 230V IP20 140° 30000 20 II 573 x 28 36 white Linear LED 1200 14W/3000K 230V IP20 140° 30000 20 II 1173 x 28 36 white Linear LED 1200 14W/4000K 230V IP20 140° 30000 20 II 1173 x 28 36 white Product description GTIN (EAN) Linear LED 300 4W/3000K 230V IP20 Linear LED 300 4W/4000K 230V IP20 Packaging information Product description GTIN (EAN) Dimensions EAN10 lxwxh [mm] Gross weight EAN 10 [g] Volume [dm³] Packaging unit [Pieces/unit] Linear LED 300 4W/3000K 230V IP20 4058075000247 520 x 40 x 30 183 0.94 25 Linear LED 300 4W/4000K 230V IP20 4058075000261 520 x 40 x 30 183 0.94 25 Linear LED 600 8W/3000K 230V IP20 4058075000285 780 x 40 x 30 385 1.37 25 Linear LED 600 8W/4000K 230V IP20 4058075000308 780 x 40 x 30 385 1.37 25 Linear LED 1200 14W/3000K 230V IP20 4058075000322 1380 x 40 x 30 558 2.38 25 Linear LED 1200 14W/4000K 230V IP20 4058075000346 1380 x 40 x 30 558 2.38 25 Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. V1-2016 Page 2 of 2 © 2016, LEDVANCE GmbH. All rights reserved.
4058075000285 价格&库存
很抱歉,暂时无法提供与“4058075000285”相匹配的价格&库存,您可以联系我们找货
