HTM150
HTM150
    AMSOSRAM(艾迈斯半导体)
    OSRAM - HTM150 - Lighting Transformer, 1 x 240V, 11.4V, 150 W, HTM Series
HTM150 数据手册
Product datasheet HTM 150/230…240 HALOTRONIC-COMPACT – HTM, HTN | Electronic transformers for low-voltage halogen lamps Areas of application Effect and accent lighting Living rooms Object lighting Conference rooms Restaurants Recessed and surface-mounted furniture fixtures Shop lighting Event rooms __ Product benefits Dimmable on the leading edge (without HTN) and trailing edge Very low power loss thanks to high efficacy Strain relief suitable for different cable types (HTM) Suitable for space-critical installation thanks to compact functional design Extremely compact transformer for highly space-critical installation conditions (HTN) Protective operation throughout the entire partial-load range for long lamp life Product features Line frequency: 50…60 Hz RI suppression: to EN 55015 (A1: 2007)/CISPR 15, EN 55022 Line harmonics according to EN 61000-3-2 Immunity according to EN 61547 Safety: to EN 61347 Short-circuit protection, overload protection, overtemperature protection: electronically reversible Electrical isolation between the primary side and the secondary side Switching between electronic transformer and lamp not permitted Energy efficiency: ≥ 91 % (according to ErP regulation 2012/1194/EC) August 25, 2014, 14:52:57 HTM 150/230…240 © 2014, OSRAM GmbH. All rights reserved. Page 1 of 5 Product datasheet Technical data Electrical data Lamp wattage 50…150 W Line current 0.57 A 1) Nominal voltage 230…240 V DC voltage - Power factor λ 0.99 Operating frequency 40 kHz 2) Output voltage 11.4 / 11.5 V 3) Mains frequency 50…60 Hz System wattage 157.00 W Galvanic isolation primary/secondary 4.00 kV Maximum no-load wattage 0.31 W 1) Effectively 2) Approximately 3) 150 W / 50 W Dimensions & weight __ Product line drawing Length 153.0 mm Width 54.0 mm Mounting hole spacing, length 146.0 mm Height 36.0 mm Mounting hole spacing, width 15.0 mm Wire preparation length, input side 12 / 8.0 mm 1) Wire preparation length, output side 12 / 8.0 mm 1) August 25, 2014, 14:52:57 HTM 150/230…240 © 2014, OSRAM GmbH. All rights reserved. Page 2 of 5 Product datasheet Product weight 185.00 g 1) Cable sheath / Wire Temperatures Ambient temperature range 0…+45 °C Maximum temperature at tc test point 80 °C Additional product data Design / version Compact with cable clamp Capabilities Dimmer Trailing- or leading-edge phase control for inductive load dimmers Overload protection Automatic reversible Overheating protection Automatic reversible Short-circuit protection Automatic reversible Maximum wiring length ECG/lamp 2.0 m Cable types, input side NYM 3x1.5 / H05VV-F 3x1.0 / H03VV-F 3x1.5 mm² Cable types, output side NYM 3x1.5 / H05VV-F 2x0.75 / H05VV-F 2x1.0 / H05VV-F 2x1.5 / H03VV-F 2x0.75 / H03VV-F 2x1.5 mm² Dimmable Yes Dimming range 0…100 % No-load proof Yes Suitable for fixtures with prot. class II __ Certificates & standards Approval marks – approval VDE / VDE-EMC / E1 approval Standards acc. to EN 55015:2006 + A1:2007/acc. to EN 61000-32/acc. to EN 61547/acc. to EN 61047/acc. to IEC 61347 August 25, 2014, 14:52:57 HTM 150/230…240 © 2014, OSRAM GmbH. All rights reserved. Page 3 of 5 Product datasheet Product line drawing assembling Others graphics Download Data File Addon Technical Information ATI HTM 150230-240 (GB) Brochures HALOTRONIC NANO HTN __ Certificates EMC-Marks approval Certificates ENEC-Marks approval Certificates ENEC-Marks approval HTi 105 DIM Certificates EAC HT family Certificates ENEC-Certificate HTL_HTM_HTN_HTi Certificates VDE-EMC-Certificate HTM_HTN Declarations of conformity Declaration of conformity HTI DALI 150 DIM Installation/Operation notice Technical guide - HALOTRONIC for low-voltage halogen lamps Installation/Operation notice HALOTRONIC Manual CAD data 3-dim HTM 150 CAD data 3-dim HTM 150 August 25, 2014, 14:52:57 HTM 150/230…240 © 2014, OSRAM GmbH. All rights reserved. Page 4 of 5 Product datasheet Logistical Data Product code Product description Packaging unit (Pieces/Unit) Dimensions (height x width x length) Volume Gross weight 4050300581415 HTM 150/230…240 Shipping carton box 10 166 mm x 98 mm x 276 mm 4.49 dm³ 2046.50 g The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. __ August 25, 2014, 14:52:57 HTM 150/230…240 © 2014, OSRAM GmbH. All rights reserved. Page 5 of 5
HTM150 价格&库存
很抱歉,暂时无法提供与“HTM150”相匹配的价格&库存,您可以联系我们找货
