Product datasheet
DULUX S/E 11 W/827
OSRAM DULUX S/E | Short CFLni, with 4-pin base for ECG operation
Areas of application
Offices, public buildings
Shops
Supermarkets and department stores
Hotels, restaurants
__
Product benefits
Extremly economical
Good quality of light
Improved maintenance
Low power consumption (7 W, 9 W, 11 W)
Long service life
Extremely low profile
Product features
Average life: 20,000 h (with QUICKTRONIC)
Color rendering index R : 80…89
a
Dimmable (3…100 %)
Short and compact pin-base lamps with single-turn tubes
Single-ended four-pin plug-in 2G7 base
Operates on battery, solar and AC power with suitable electronic control gear
August 25, 2014, 16:43:48
DULUX S/E 11 W/827
© 2014, OSRAM GmbH. All rights reserved.
Page 1 of 7
Product datasheet
Technical data
Electrical data
Nominal wattage
11.80 W
Rated wattage
11.80 W
Rated lamp efficacy (HF data 25 °C)
Under clarification by authority and standardization
body
Energy consumption
15 kWh/1000h
Photometrical data
__
Nominal luminous flux
900 lm
Rated luminous flux
900 lm
Color temperature
2700 K
Light color
827
Light color as per EN 12464-1
LUMILUX INTERNA
Color rendering index Ra
80…89
Luminous flux at 25 °C
900 lm
Rated LLMF at 4,000 h
0.86
Rated LLMF at 6,000 h
0.84
Rated LLMF at 8,000 h
0.82
Rated LLMF at 12,000 h
0.79
Rated LLMF at 16,000 h
0.78
Rated LLMF at 20,000 h
0.76
Luminance
2.7 cd/cm²
Color rendering group
1B
Dimensions & weight
DULUX S/E 11 W/827
Page 2 of 7
Product datasheet
Product line drawing
__
Base
Overall length
214.0 mm
Product weight
34.80 g
Tube diameter
12 mm
Length
214.0 mm
Length acc. to IEC standard
215 mm
Length with base excl. base pins/connection
214.00 mm
Colors & materials
Lamp mercury content
1.4 mg
Temperatures
Rated ambient temp.w.max.luminous flux
25.0 °C
Lifespan
Nominal lamp life time
20000 h
Rated lamp life time
20000 h
Service life
13000 h 1)
Rated lamp survival factor at 2,000 h
0.99
Rated lamp survival factor at 4,000 h
0.99
Rated lamp survival factor at 6,000 h
0.99
Rated lamp survival factor at 8,000 h
0.99
Rated lamp survival factor at 12,000 h
0.95
Rated lamp survival factor at 16,000 h
0.81
Rated lamp survival factor at 20,000 h
0.50
Operation mode LLMF/LSF
HF
Lifespan
20000 h 1)
DULUX S/E 11 W/827
Page 3 of 7
Product datasheet
1) With preheat ECG
Additional product data
__
Spectral power distribution
Base (standard designation)
2G7
Appropriate disposal acc. to WEEE
Yes
Footnote only for product
For ECG operation only
Capabilities
Suitable for indoor
Yes
Certificates & standards
Energy efficiency class
A
Country specific categorizations
ILCOS
FSDH-11/827-/P/-2G7
Country specific information
Product code
METEL code
SEG number
STK number
UK Org
4050300017662
OSRDSE11827
8330064
4933957
DULUX S/E 11 W/827
Page 4 of 7
Product datasheet
Lamp-ECG combination (System)
Product name
Product name ECG
EAN
Nominal current
Nominal wattage
+ Power loss
Luminous flux at
25 °C
Number of
lighting outlets
DULUX S/E 11W/827 2G7
DT-S/E 5-11/220-240 L
4008321181473
0.10 A
13.50 W
900 lm
1
DT-S/E 5-11/220-240 S
4008321181459
0.10 A
13.50 W
900 lm
1
QT-ECO 1x4-16/220-240 L
4050300660370
0.09 A
13.00 W
900 lm
1
QT-ECO 1x4-16/220-240 S
4050300638584
0.09 A
13.00 W
900 lm
1
QT-ECO 2x5-11/220-240 S
4050300821504
0.16 A
24.00 W
700 lm
2
QTP-D/E 1x10-13
4008321181572
0.06 A
14.00 W
900 lm
1
QTP-D/E 2x10-13
4008321181596
0.12 A
28.00 W
950 lm
2
__
DULUX S/E 11 W/827
Page 5 of 7
Product datasheet
Guarantee
Equipment / Accessories
Suitable for operation on electronic control gear
Safety advice
In case of lamp breakage: www.osram.com/brokenlamp
__
Others graphics
Circuit diagram
Circuit diagram
Logistical Data
Product code
Product description
Packaging unit
(Pieces/Unit)
Dimensions (height x
width x length)
Volume
Gross weight
4050300017662
DULUX S/E 11
W/827
Folding carton box
1
39 mm x 23 mm x
229 mm
0.21 dm³
44.80 g
4050300251295
DULUX S/E 11
W/827
Shipping carton box
10
155 mm x 203 mm x
99 mm
3.12 dm³
508.00 g
The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or
more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit.
DULUX S/E 11 W/827
Page 6 of 7
Product datasheet
References / Links
For more information on QUICKTRONIC electronic control gear go to
www.osram.com/QUICKTRONIC
Disclaimer
Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release.
__
DULUX S/E 11 W/827
Page 7 of 7
很抱歉,暂时无法提供与“DSE112”相匹配的价格&库存,您可以联系我们找货
