DS1184
DS1184
    AMSOSRAM(艾迈斯半导体)
    Module
    OSRAM - DS1184 - LAMP, DULUX, S, COOL, 11W
DS1184 数据手册
Product datasheet DULUX S 11 W/840 OSRAM DULUX S | Short CFLni, with 2-pin base for CCG operation Areas of application Ideal for cost-effective creative illumination and decoration Offices, public buildings Shops Supermarkets and department stores Hotels, restaurants __ Product benefits Extremly economical Good quality of light Extremely low profile Long service life Improved maintenance Product features Average life: 10,000 h Color rendering index R for lamps with white light: 80…89 a Also available in red, green and blue Short and compact pin-base lamps with single-turn tubes Single-ended two-pin plug-in G23 base August 25, 2014, 16:43:47 DULUX S 11 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 1 of 6 Product datasheet Technical data Electrical data Nominal wattage 11.80 W Rated wattage 11.80 W Energy consumption 15 kWh/1000h Photometrical data __ Nominal luminous flux 855 lm Rated luminous flux 855 lm Color temperature 4000 K Light color 840 Light color as per EN 12464-1 LUMILUX Cool White Color rendering index Ra 80…89 Luminous flux at 25 °C 900 lm Rated LLMF at 4,000 h 0.78 Rated LLMF at 6,000 h 0.76 Rated LLMF at 8,000 h 0.75 Luminance 2.7 cd/cm² Color rendering group 1B Dimensions & weight Product line drawing Base Overall length 237.0 mm Product weight 38.30 g Tube diameter 12 mm Length 237.0 mm August 25, 2014, 16:43:47 DULUX S 11 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 2 of 6 Product datasheet Length acc. to IEC standard 215 mm Length with base excl. base pins/connection 214.00 mm Colors & materials Lamp mercury content 1.4 mg Temperatures Rated ambient temp.w.max.luminous flux 25.0 °C Lifespan __ Nominal lamp life time 8000 h Rated lamp life time 8000 h Service life 6500 h Rated lamp survival factor at 2,000 h 0.98 Rated lamp survival factor at 4,000 h 0.98 Rated lamp survival factor at 6,000 h 0.86 Rated lamp survival factor at 8,000 h 0.50 Operation mode LLMF/LSF 50 Hz Lifespan 10000 h 1) 1) With CCG/LLCG Additional product data August 25, 2014, 16:43:47 DULUX S 11 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 3 of 6 Product datasheet Spectral power distribution __ Base (standard designation) G23 Appropriate disposal acc. to WEEE Yes Capabilities Suitable for indoor Yes Certificates & standards Energy efficiency class A Country specific categorizations ILCOS FSD-11/840-I-G23 Country specific information Product code METEL code SEG number STK number UK Org 4050300010618 OSRDS11840 8330028 4933856 - August 25, 2014, 16:43:47 DULUX S 11 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 4 of 6 Product datasheet Guarantee Equipment / Accessories Suitable for operation on conventional control gear __ Circuit diagram Circuit diagram Logistical Data Product code Product description Packaging unit (Pieces/Unit) Dimensions (height x width x length) Volume Gross weight 4050300010618 DULUX S 11 W/840 Folding carton box 1 36 mm x 26 mm x 239 mm 0.22 dm³ 48.30 g 4050300239507 DULUX S 11 W/840 Shipping carton box 10 111 mm x 133 mm x 219 mm 3.23 dm³ 536.00 g 4050300239477 DULUX S 11 W/840 Unpacked 1 43 mm x 23 mm x 242 mm 0.24 dm³ 49.17 g 4050300239484 DULUX S 11 W/840 Shipping carton box 50 240 mm x 190 mm x 261 mm 11.90 dm³ 2659.35 g 4052899213395 DULUX S 11 W/840 Folding carton box 1 - x - x - 4052899213401 DULUX S 11 W/840 Shipping carton box 261 mm x 190 mm x 11.90 dm³ 2440.00 g August 25, 2014, 16:43:47 DULUX S 11 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 5 of 6 Product datasheet 50 240 mm The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. __ August 25, 2014, 16:43:47 DULUX S 11 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 6 of 6
DS1184
物料型号:DULUX S 11 W/840
器件简介: - 适用于成本效益高的创意照明和装饰。 - 适用于办公室、公共建筑、商店、超市、百货商店、酒店和餐馆。
引脚分配: - 单端双针插入式G23底座。
参数特性: - 额定功率:11.80W - 额定光通量:855lm - 色温:4000K - 光色:840(LUMILUX Cool White) - 显色指数Ra:80...89 - 25°C时的光通量:900Lm - 寿命:10000小时(使用CCG/LLCG时)
功能详解: - 非常经济 - 良好的光质 - 极低的轮廓 - 长寿命 - 改善维护
应用信息: - 适用于室内使用 - 符合能源效率等级A - 符合WEEE指令的适当处理
封装信息: - 总长度:237.0 mm - 管径:12mm - 产品重量:38.30g - 根据IEC标准的长度:215 mm - 带底座但不包括底座引脚/连接的长度:214.00 mm
其他产品数据: - 汞含量:1.4mg - 额定环境温度下最大光通量:25.0°C - 额定寿命:8000小时 - 服务寿命:6500小时 - 2000小时、4000小时、6000小时和8000小时的额定灯生存因子分别为0.98、0.98、0.86和0.50
物流数据: - 产品代码:4050300010618 - 包装单位:1个折叠纸盒 - 尺寸(高x宽x长):36mmx26mmx239mm - 体积:0.22 dm³ - 毛重:48.30g
DS1184 价格&库存
很抱歉,暂时无法提供与“DS1184”相匹配的价格&库存,您可以联系我们找货
