www.osram.com/LED-Systems
DRAGONeye® - DE1
Data Sheet
Benefits
Picture for
Datasheet
is missing
¾
Compact High-Flux LED Minispotlight
¾
Slim metallic housing for optimum heat
dissipation
¾
IP65 Protection for use in outdoor lighting
Applications
¾
Small luminaire head for mini spotlights
¾
Orientation and accent lighting
¾
Museum lighting of UV sensitive exhibits
¾
Illumination of shelves and display cases
Technical Operating Data
Product
Color
Number of
LEDs
Current
[mA]*
Power
[W]*
Radiance
Angle [°]*
Wavelength [nm]
Color Temp [K]*
Lum. Intensity
[cd]*
DE1-W4F-854
white
1
350
1,2
15
5400 K
650
DE1-W3F-830
white
1
350
1,2
15
3000 K
485
DE1-A2 **
red
1
350
0,8
18
616 nm
380
DE1-Y2 **
yellow
1
350
0,8
18
589 nm
265
DE1-T2 **
green
1
350
1,2
15
531 nm
135
DE1-B2 **
blue
1
350
1,2
15
468 nm
32
*) All Data are related to the entire module
Due to the special conditions of the manufacturing processes of LED the typical data of technical parameters can only reflect statistical figures and do not necessarily
correspond to the actual parameters of each single product which could differ from the typical data.
+) Preliminary Data
**) Discontinued
Technical Features
¾ Dimensions DRAGONeye: H: 32 mm, Ø: 23 mm
¾ Easy assembly due to integrated thread M10 x
60529
¾ Metallic housing for optimum heat dissipation
1.5
¾ Factory installed 500 mm / AWG20 for white
modules and 200mm / AWG 22 for colored
modules double pole cable.
¾ Operation only with OPTOTRONIC® constant
current devices (see page 3)
¾ A crank at the bottom of the housing (Ø: 12 mm)
allows perfect centering.
DE1 - 24.07.2009
¾ Protection class IP 65 according to DIN EN
Page 1 of 4
¾ Narrow beam angle for use as a point light
source
¾ Only serial connection of modules allowed
¾ Up to 70,000h lifetime
Minimum and Maximum Ratings
Product
Operating Temperature
at Tc-Point [ °C ] *
Storage Temperature
[ °C ] *
Max. Current
[ A dc ] *
Reverse Voltage
[ V dc ] *
DE1-W4F-854
-30 ... 65
-40 ... 65
0,5
DE1-W3F-830
-30 ... 65
-40 ... 65
0,5
DE1-A2 **
-30 ... 65
-40 ... 65
0,5
DE1-Y2 **
-30 ... 65
-40 ... 65
0,5
DE1-T2 **
-30 ... 65
-40 ... 65
0,5
DE1-B2 **
-30 ... 65
-40 ... 65
0,5
The module is designed to work with current sources. The maximum output voltage may not exceed 100 V DC. Reverse operation is not allowed and may
destroy the module.
Exceeding maximum ratings for operating and storage temperature will reduce expected life time or destroy the LED Module.
Exceeding maximum ratings for operating current will cause hazardous overload and will likely destroy the LED Module. Several modules may be connected in series up to the
maximum voltage of 100 V DC (outside SELV limits).
The temperature of the LED module must be measured at the Tc-point according to EN60598-1 in a thermally constant status with a temperature sensor or a temperature
sensitive label. For exact location of the Tc-point see drawing below.
Drawings
Drawing is missing !!!
DE1 - 24.07.2009
Page 2 of 4
Safety Information
¾ The LED module itself and all its components must not be mechanically stressed.
¾ Assembly must not damage or destroy conducting paths on the circuit board.
In order to drive OSRAM LED-Modules safely, it is absolutely necessary to operate them with an electronically
stabilised power supply protecting against short circuits, overload and overheating.
To also ease the luminaire/installation approval, electronic control gear for LED or LED modules should carry the CE mark and be
ENEC certified. In Europe the declarations of conformity must include the following standards:
CE: EC 61374-2-13, EN 55015, IEC 61547 and IEC 61000-3-2 - ENEC: 61374-2-13 and IEC/EN 62384.
Also check for the mark of an independent authorized certification institute.
Please see the relevant brochure for more detailed information (see "Related and Further Information")
OSRAM OPTOTRONIC® electronic control gear complies to all relevant standards and guarantees safe operation.
¾ Installation of LED modules (with power supplies) needs to be made with regard to all applicable electrical and safety standards.
Only qualified personnel should be allowed to perform installations.
¾ Observe correct polarity!
Depending on the product incorrect polarity will lead to emission of red or no light. The module can be destroyed! Correct polarity
immediatelly! (see "reverse voltage", page 2)
¾ Serial connection is highly recommended as safe electrical operation mode.
Parallel connection is not recommended. Unbalanced voltage drop can cause hazardous overload and damage the LED module.
¾ Pay attention to standard ESD precautions when installing the module.For further information see the ESD application notes, you
can find them in the internet.
¾ Recommended power supply:
- OT 9/200-240/350 or OT 9/100-120/350(E) for 350 mA constant current operation
- OT 9/10-24/350 DIM, OT 9/10-24/350 DIM(E) for 350 mA constant current, 1..10V interface (dimming with PWM)
- OT 9/200-240/350 DIM for 0-350 mA constant current operation, 1..10 V interface (dimming) and strain relief
- OT 18/200-240/700 DIM for 0-500 mA constamt current operation, 1..10V interface (Dimming with PWM) and strain relief
¾ The OT18 comes with preset limitation to 500mA, thus giving 12W due to SELV (
很抱歉,暂时无法提供与“DE1-T2”相匹配的价格&库存,您可以联系我们找货
