H400D (HQI-T)
H400D (HQI-T)
    AMSOSRAM(艾迈斯半导体)
    OSRAM - H400D (HQI-T) - LAMP, HALIDE, DAYLIGHT, 400W
H400D (HQI-T) 数据手册
www.osram.com POWERSTAR® HQI® Technical Information c All rights reserved. No part of this document may be reproduced, copied or distributed in any form (printed matter, photocopy, etc.) without the written permission of HID M-M, OSRAM Germany. c This brochure supersedes all previous editions. c All dimensions, weights, specifications and graphic representations are given without obligation. All design features, dimensions and technical specifications are subject to change without notice. POWERSTAR ® HQI®-T 1 Type ILCOS Lamp wattage W Lamp voltage V Ignition voltage min./max. kVs Lamp current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm² · 1000 lx Base Diameter d mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. pinch temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. Luminous flux in % Survival rate in % 80 70 60 0 2000 4000 Hours burned 6000 Survival rate HQI 70 W/NDL, (/D) 100 Luminous flux in % 80 70 60 50 0 2000 4000 Hours burned 80 70 60 0 6000 8000 2000 4000 Hours burned 6000 8000 6000 8000 Luminous flux behaviour HQI-T, 70 W/NDL 100 90 HQI-T 150 W NDL UVS MT/UB-150/42/ 1B-H-G12-25/84 150 100 3.6/5 1.8 13000 87 NDL 4200 85 > 17 < 0.5 G12 25 84 56 universal 9000 550 280 20 HQI-T 150W/NDL 4050300488448 12 1 2/5 90 50 8000 HQI-T 150 W WDL UVS MT/UB-150/30/ 1B-H-G12-25/84 150 100 3.6/5 1.8 13000 87 WDL 3000 77 > 22 < 0.4 G12 25 84 56 universal 9000 550 280 20 HQI-T 150W/WDL 4050300873664 12 1 2/5 Luminous flux behaviour HQI-T, 70 W/WDL 100 90 50 HQI-T 70 W NDL UVS MT/UB-70/42/ 1B-H-G12-25/84 75 100 3.6/5 1 5800 77 NDL 4200 84 > 50 < 0.14 G12 25 84 56 universal 9000 500 280 12 HQI-T 70W/NDL 4050300488424 12 1 2/5 Survival rate HQI 70 W/WDL 100 Survival rate in % HQI-T 70 W WDL UVS MT/UB-70/30/ 1B-H-G12-25/84 75 95 3.6/5 1 5300 71 WDL 3000 76 > 17.3 < 0.48 G12 25 84 56 universal 9000 500 280 12 HQI-T 70W/WDL 4050300412993 12 1 2/5 90 80 70 60 50 0 2000 4000 Hours burned  POWERSTAR ® HQI®-T, BT 1 2 Type ILCOS Lamp wattage W Lamp voltage V Ignition voltage min./max. kVs Lamp current A Nominal gear current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm² · 1000 lx Base Diameter d mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. base edge temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. Luminous flux in % Survival rate in % 80 70 60 0 6000 Hours burned 8000 10000 80 70 60 50 0 2000 4000 6000 Hours burned 8000 10000 Survival rate HQI 400 W/N 100 Luminous flux in % 80 70 60 0 2000 4000 70 60 0 6000 Hours burned 8000 10000 12000 2000 4000 6000 Hours burned 8000 10000 12000 8000 10000 12000 8000 10000 12000 Luminous flux behaviour HQI 400 W/D 90 80 70 60 0 2000 4000 6000 Hours burned Luminous flux behaviour HQI 400 W/N 100 90 50 80 50 12000 HQI-T 400 W N UVS, HQI-VG MT/UB-400/40/ 2B-H-E40-46/273/P45 380 120 3.6/5 3.6 3.5 34000 89 N 4000 > 60 > 45 < 0.19 E40 46 275 175 p 45 12000 500 250 35 HQI-T 400W/N 4050300324647 12 1 2 Luminous flux behaviour HQI 250 W/D 100 90 HQI-T 400 W N UVS, NAV-VG MT/UB-400/35/ 2B-H-E40-46/273/P45 430 120 3.6/5 4.0 4.6 42000 98 N 3500 > 65 > 45 < 0.19 E40 46 275 175 p 45 12000 500 250 45 HQI-T 400W/N 4050300324647 12 1 2 90 50 12000 Luminous flux in % Survival rate in % 4000 Survival rate HQI 400 W/D 100 Survival rate in % 2000 HQI-BT 400 W D UVS, HQI-VG MC/UB-400/59/ 1A-H-E40-62/285 360 120 3/5 3.5 3.5 27000 75 D 5900 90 > 50 < 0.06 E40 62 285 175 universal 12000 500 250 35 HQI-T 400W/D 4050300468471 12 2 2 100 90 50 HQI-BT 400 W D UVS, NAV-VG MC/UB-400/52/ 1A-H-E40-62/285 420 120 3/5 4 4.6 35000 83 D 5200 90 > 50 < 0.06 E40 62 285 175 universal 12000 500 250 45 HQI-T 400W/D 4050300468471 12 2 2 Survival rate HQI 250 W/D 100  HQI-T 250 W D UVS MT/UB-250/53/ 1A-H-E40-46/225 250 100 3/5 3 – 20000 82 D 5200 90 > 50 < 0.08 E40 46 225 150 universal 12000 500 250 32 HQI-T 250W/D 4050300015293 12 1 2 90 80 70 60 50 0 2000 4000 6000 Hours burned POWERSTAR ® HQI®-T 1 Type ILCOS Lamp wattage W Lamp voltage V Ignition voltage min./max. kVs Lamp current A Nominal gear current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm² · 1000 lx Base Diameter d mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. base edge temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. HQI-T 400 W GREEN UVS MT-400/GREEN/ H-E40-46/260/P55 360 120 3/5 3.6 3.5 uncertain uncertain GREEN monochr. – – – E40 46 275 175 p 55 – 500 250 35 HQI-T 400W GREEN 4050300575957 12 1 2 HQI-T 400 W MAGENTA UVS MT-400/MAGENTA/ H-E40-46/275/P55 440 120 4/5 4.2 4.6 uncertain uncertain MAGENTA monochr. – – – E40 46 275 175 p 55 – 500 250 45 HQI-T 400W MAGENTA 4050300649535 12 1 2 Survival rate HQI 400 W Blue, Magenta, Green 100 Survival rate in % HQI-T 400 W BLUE UVS MT-400/BLUE/ H-E40-46/260/P55 360 120 3/5 3.6 3.5 uncertain uncertain BLUE monochr. – – – E40 46 275 175 p 55 – 500 250 35 HQI-T 400W BLUE 4050300575971 12 1 2 90 80 70 60 50 0 1000 2000 Hours burned 3000 4000  POWERSTAR ® HQI®-T 1 2 Type ILCOS Lamp wattage W Mains voltage V Lamp voltage V Ignition voltage min./max. kVs Lamp current A Nominal gear current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm² · 1000 lx Base Diameter d mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. base edge temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. 80 70 60 0 2000 4000 Hours burned 6000 Survival rate HQI-T 2000 W D 100 Luminous flux in % 80 70 60 50 0 2000 4000 Hours burned 6000 8000 HQI-T 2000 W N /SN SUPER MT-2000/72/1A-E- E40-100/430/P30 2050 400 230 4/5 10.2 10.3 180000 88 D 7250 90 > 50 < 0.15 E40 100 430 265 p 30 9000 500 250 60 HQI-T 2000W/D 4050300015330 4 2 2 MT-2000/44/2B-E- E40-100/430/P60 2000 400 220 4/5 9.4 8.8 220000 110 N 4400 65 > 23 < 0.36 E40 100 430 265 p 60 9000 500 250 37 HQI-T 2000W/N/E SUPER 4050300301860 4 2 2 MT-2000/44/2B-EE40-100/430/P60 2000 400 220 0.9/1.3 9.4 8.8 220000 110 N 4400 65 > 24 < 0.35 E40 100 430 265 p 60 9000 500 250 37 HQI-T 2000W/N/SN SUPER 4050300348629 4 2 2 80 70 60 0 2000 4000 Hours burned 6000 8000 6000 8000 Luminous flux behaviour HQI-T 2000 W D 100 90 HQI-T 2000 W N /E SUPER 90 50 8000 HQI-T 2000 W D Luminous flux behaviour HQI 1000 W T/D, E/N 100 Luminous flux in % Survival rate in % MT-1000/72/1A-H- MT-1000/35/2B-H- E40-76/345/P30 E40-76/345/P30 1050 1000 230 230 130 125 4/5 4/5 8.9 9.1 9.5 9.5 85000 110000 81 110 D N 7250 3500 90 65 > 25 < 0.33 E40 E40 76 76 345 345 220 220 p 30 p 30 9000 9000 500 500 250 250 85 85 HQI-T HQI-T 1000W/D 1000W/N 4050300015323 4008321116604 6 6 1 1 2 2 90 50 Survival rate in % HQI-T 1000 W N Survival rate HQI 1000 W T/D, E/N 100  HQI-T 1000 W D 90 80 70 60 50 0 2000 4000 Hours burned POWERSTAR ® HQI®-T 1 Type ILCOS Lamp wattage W Mains voltage V Lamp voltage V Ignition voltage min./max. kVs Lamp current A Nominal gear current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm² · 1000 lx Base Diameter d mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. base edge temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. Luminous flux in % Survival rate in % 80 70 60 0 2000 4000 Hours burned 6000 Survival rate HQI-T 2000 W/N 100 Luminous flux in % 80 70 60 50 0 2000 4000 Hours burned 80 70 60 0 6000 8000 2000 4000 Hours burned 6000 8000 6000 8000 Luminous flux behaviour HQI-T 2000 W/N 100 90 MT-2000/40/2B-E/I-E40-100/430/P60 2000 400 230 not reqd. 9.0 8.8 200000 100 D 4000 65 > 10 < 0.81 E40 100 430 265 p 60 9000 500 250 37 HQI-T 2000W/N 4050300015347 4 1 1 90 50 8000 HQI-T 2000 W N without igniter Luminous flux behaviour HQI-T 2000 W, D/I 100 90 50 HQI-T 2000 W D /I MT-2000/72/1A-E/I-E40-100/430/P30 2050 400 230 not reqd. 10.3 10.3 180000 88 D 7250 90 > 42 < 0.2 E40 100 430 265 p 30 9000 500 250 60 HQI-T 2000W/D/I 4050300015446 4 1 1 Survival rate HQI-T 2000 W D, D/I 100 Survival rate in % HQI-T 2000 W N 230 V MT-2000/44/2B-E-E40-100/430/P30 1900 230 120 0.7 16.5 16.5 190000 100 N 4400 65 > 19 < 0.43 E40 100 430 265 p 30 9000 500 250 125 HQI-T 2000W/N/230 V 4050300421582 4 1 2 90 80 70 60 50 0 2000 4000 Hours burned  POWERSTAR ® HQI®-TS 1 Type ILCOS Lamp wattage W Lamp voltage V Ignition voltage min./max. kVs Lamp current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm² · 1000 lx Base Diameter d mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. pinch temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. Luminous flux in % Survival rate in % 80 70 60 0 4000 Hours burned 6000 80 70 60 0 2000 4000 6000 Hours burned 8000 10000 Luminous flux in % 80 70 60 0 2000 4000 6000 Hours burned 70 60 0 8000 10000 12000 2000 4000 Hours burned 6000 8000 Luminous flux behaviour HQI-TS 150 W/WDL 90 80 70 60 0 2000 4000 6000 Hours burned 8000 10000 12000 10000 12000 Luminous flux behaviour HQI-TS 150 W/NDL, /D 100 90 50 80 50 12000 Survival rate HQI-TS 150 W/NDL, /D 100 Luminous flux behaviour HQI-TS 70 W/WDL/NDL/D 100 90 HQI-TS HQI-TS HQI-TS 150 W 150 W 150 W WDL NDL D UVS UVS UVS MD/UB-150/30/1B-H- MD/UB-150/42/1B-H- MD/UB-150/52/1B-HRX7s24-23/132/P45 RX7s24-23/132/P45 RX7s24-23/132/P45 150 150 150 95 90 100 3.6/5 3.6/5 3.6/5 1.8 1.8 1.8 11700 12000 12000 78 80 80 WDL NDL D 3000 4200 5200 76 87 91 > 41 > 10.2 > 11.7 < 0.2 < 0.8 < 0.7 RX7s-24 RX7s-24 RX7s-24 23 23 23 132 132 132 66 66 66 p 45 p 45 p 45 12000 12000 12000 650 650 650 280 280 280 20 20 20 HQI-TS 150W/WDL HQI-TS 150W/NDL HQI-TS 150W/D 4050300412979 4050300362380 4050300437545 12 12 12 1 1 1 2/3/5 2/3/5 2/5 90 50 8000 Luminous flux in % Survival rate in % 2000 Survival rate HQI-TS 150 W/WDL 100 50 HQI-TS 70 W D UVS MD/UB-70/52/1B-H- RX7s-20/114.2/P45 75 110 3.6/5 1 5500 73 D 5200 85 > 16 < 0.52 RX7s 20 114.2 57 p 45 12000 500 280 12 HQI-TS 70W/D 4050300437521 12 1 2/5 100 90 50 Survival rate in % HQI-TS 70 W NDL UVS MD/UB-70/40/1B-H- RX7s-20/114.2/P45 73 85 3.6/5 1 5700 76 NDL 4000 83 > 7 < 1.26 RX7s 20 114.2 57 p 45 12000 500 280 12 HQI-TS 70W/NDL 4050300412931 12 1 2/3/5 Survival rate HQI-TS 70 W/WDL/NDL/D 100  HQI-TS 70 W WDL UVS MD/UB-70/30/2B-H- RX7s-20/114.2/P45 75 95 3.6/5 1 5100 71 WDL 3000 76 > 23 < 0.36 RX7s 20 114.2 57 p 45 12000 500 280 12 HQI-TS 70W/WDL 4050300412955 12 1 2/3/5 90 80 70 60 50 0 2000 4000 6000 Hours burned 8000 POWERSTAR ® HQI®-TS 1 2 Type ILCOS Lamp wattage W Lamp voltage V Ignition voltage min./max. kVs Lamp current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm² · 1000 lx Base Diameter d mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. pinch temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. Luminous flux in % Survival rate in % 80 70 60 0 2000 4000 6000 Hours burned 8000 10000 Luminous flux in % 80 70 60 0 2000 4000 6000 Hours burned 8000 10000 Luminous flux behaviour HQI 400 W/NDL 100 Luminous flux in % 80 70 60 0 2000 4000 6000 Hours burned 70 60 0 8000 10000 12000 2000 4000 6000 Hours burned 8000 10000 12000 8000 10000 12000 8000 10000 12000 Luminous flux behaviour HQI 250 W/NDL, /D 90 80 70 60 0 2000 4000 6000 Hours burned Luminous flux behaviour HQI 400 W/D 100 90 50 80 50 12000 HQI-TS HQI-TS 400 W 400 W D D UVS, NAV-VG UVS, HQI-VG MD/UB-400/52=56/ MD/UB-400/52=56/ 1A-H-Fc2-31/206/P45 1A-H-Fc2-31/206/P45 400 350 125 120 3/5 3/5 4.1 3.6 37000 31000 90 89 D D 5200 5600 93 90 > 11 min > 11 min < 46 < 46 Fc2 Fc2 31 31 206 206 103 103 p 45 p 45 12000 12000 650 650 300 300 45 35 HQI-TS 400W/D HQI-TS 400W/D 4050300015385 4050300015385 12 12 2 2 2 2 Luminous flux behaviour HQI 250 W/WDL 100 90 HQI-TS 400 W NDL UVS MD/UB-400/42/1B- H-Fc2-31/206/P45 400 120 3/5 4.11) 36000 90 NDL 4200 88 > 11 min < 47 Fc2 31 206 103 p 45 12000 650 300 45 HQI-TS 400W/NDL 4050300304090 12 2 2/3 90 50 12000 Survival rate HQI 400 W/NDL, /D 100 50 HQI-TS 250 W D UVS MD/UB-250/51/1A- H-Fc2-25/163/P45 250 100 3/5 3 20000 82 D 5100 93 > 18 < 0.46 Fc2 25 163 81.5 p 45 12000 650 300 32 HQI-TS 250W/D 4050300436050 12 1 2 100 90 50 Survival rate in % HQI-TS 250 W NDL UVS MD/UB-250/42/1B- H-Fc2-25/163/P45 250 100 3.6/5 3 20000 82 NDL 4200 88 > 12 < 0.71 Fc2 25 163 81.5 p 45 12000 650 300 32 HQI-TS 250W/NDL 4050300436036 12 1 2/3 Survival rate HQI 250 W/WDL, /NDL, /D 100 Luminous flux in % HQI-TS 250 W WDL UVS MD/UB-250/32/1B- H-Fc2-25/163/P45 250 110 3.6/5 2.8 22000 88 WDL 3200 80 > 12 < 0.68 Fc2 25 163 81.5 p 45 12000 650 300 32 HQI-TS 250W/WDL 4050300436012 12 1 2/3 90 80 70 60 50 0 2000 4000 6000 Hours burned 1) Operate only with NAV control gear.  POWERSTAR ® HQI®-TS l1 1 Type ILCOS Lamp wattage W Lamp voltage V Ignition voltage min./max. kVs Hot restrike kVs Lamp current A Nominal gear current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm² · 1000 lx Base Diameter d mm Insertion length l1 mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. pinch temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. MN-1000/44/1B-H-cable lug-36/187/P15 1000 120 4/5 36 9.2 9.5 90000 90 NDL 4400 > 85 > 15 min < 34 cable 36 157 187 93 p 15 6000 950 390 85 HQI-TS 1000W/NDL/S 4050300349916 10 1 2/3 MN-1000/59/1A-H-cable lug-36/187/P15/S15 1000 120 4/5 36 9.4 9.5 90000 90 D 5900 ≥ 90 > 5.5 min < 92 cable 36 157 187 93 p 15/s 15 6000 950 390 85 HQI-TS 1000W/D/S 4050300300092 10 1 2/3 90 80 70 60 50 0 2000 Hours burned Luminous flux behaviour HQI-TS 1000 W NDL, D/S 100 Luminous flux in % Survival rate in % HQI-TS 1000 W D /S Survival rate HQI-TS 1000 W NDL, D/S 100 10 HQI-TS 1000 W NDL /S 4000 6000 90 80 70 60 50 0 2000 Hours burned 4000 6000 POWERSTAR ® HQI®-TS l1 l1 1 2 Type ILCOS Lamp wattage W Lamp voltage V Ignition voltage min./max. kVs Hot restrike kVs Lamp current A Nominal gear current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm² · 1000 lx Base Diameter d mm Insertion length l1 mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. pinch temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. MN-2000/59/1A-E- cable lug-36/187/P15 1950 205 4/5 36 11.51) 10.3 200000 103 D 5900 ≥ 90 > 15 min < 33 cable 36 157 187 93 p 15 4000 950 390 60 HQI-TS 2000W/D/S 4050300271682 10 1 2/4 MN-2000/59/1A-H- MN-2000/44/1B-E- MN-2000/44/1B-H- cable lug-36/187/S15 cable lug-36/187/P15 cable lug-36/187/S15 1950 1950 1950 205 205 205 4/5 4/5 4/5 36 36 36 11.31) 11.31) 11.31) 10.3 10.3 10.3 200000 200000 200000 103 103 103 D NDL NDL 5900 4400 4400 ≥ 90 > 85 > 85 > 15 min < 33 cable cable cable 36 36 36 157 157 157 187 187 187 93 93 93 2) s 15 p 15 s 152) – 4000 – 950 950 950 390 390 390 60 60 60 HQI-TS 2000W/D/S/V HQI-TS 2000W/NDL/S HQI-TS 2000W/NDL/S/V 4050300977232 4008321910196 4008321910202 10 10 10 1 1 1 2/4 2/4 2/4 80 70 60 0 1000 2000 Hours burned 3000 Survival rate HQI-TS 2000 W/N/L 100 Luminous flux in % 80 70 60 50 0 2000 1) L amps may only be operated on 10.3 A chokes! 4000 Hours burned 6000 8000 2) L amps to be operated in axially symmetrical luminaires only where the lamp is situated along the axis. MN-2000/44/1B-Ecable lug-36/187/P15 2150 220 4/5 – 10.7 10.3 230000 107 N 4400 ≥ 65 > 3.4 min < 148 cable 32 242 275 137 p 15 8000 950 390 60 HQI-TS 2000W/N/L 4050300607344 10 2 2/4 80 70 60 0 1000 2000 Hours burned 3000 4000 6000 8000 Luminous flux behaviour HQI-TS 2000 W/N/L 100 90 HQI-TS 2000 W N /L 90 50 4000 HQI-TS 2000 W NDL /S/V Luminous flux behaviour HQI-TS 2000 W D/S 100 90 50 HQI-TS 2000 W NDL /S Luminous flux in % Survival rate in % HQI-TS 2000 W D /S/V Survival rate HQI-TS 2000 W D/S 100 Survival rate in % HQI-TS 2000 W D /S 90 80 70 60 50 0 2000 4000 Hours burned For all 2000 W lamps: Operation on 400 V supply voltage. 11 POWERSTAR ® HQI®-E 1 2 Type ILCOS Lamp wattage W Lamp voltage V Ignition voltage min./max. kVs Lamp current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm² · 1000 lx Base Diameter d mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. base edge temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. Luminous flux in % Survival rate in % 80 70 60 0 4000 Hours burned 6000 Luminous flux in % 80 70 60 50 0 2000 80 70 60 0 4000 Hours burned 6000 8000 2000 4000 Hours burned 6000 8000 6000 8000 Luminous flux behaviour HQI-E 70 W/NDL 100 90 HQI-E 70 W NDL coated for open luminaires UVS MES/UB-70/38/ 1B-H-E27-55/144 73 95 3.6/5 1 5100 70 NDL 4000 70 > 50 < 0.05 E27 55 144 – universal 6000 330 190 12 HQI-E 70W/NDL coated 4050300397849 20 2 2/5 90 50 8000 Survival rate HQI 70 W/NDL 100 Survival rate in % 2000 HQI-E 70 W NDL clear for open luminaires UVS MCS/UB-70/40/ 1B-H-E27-55/144 73 95 3.6/5 1 5500 75 NDL 4200 70 > 50 < 0.05 E27 55 144 92 universal 6000 330 190 12 HQI-E 70W/NDL clear 4050300397825 20 1 2/5 Luminous flux behaviour HQI-E 70 W/WDL 100 90 50 HQI-E 70 W WDL coated for open luminaires UVS MES/UB-70/30/ 1B-H-E27-55/144 73 95 3.6/5 0.95 4700 64 WDL 2900 70 > 50 < 0.06 E27 55 144 – universal 9000 330 190 12 HQI-E 70W/WDL coated 4050300397801 20 2 2/5 Survival rate HQI 70 W/WDL 100 12 HQI-E 70 W WDL clear for open luminaires UVS MCS/UB-70/32/ 1B-H-E27-55/144 73 95 3.6/5 0.95 5200 71 WDL 3000 70 > 50 < 0.06 E27 55 144 92 universal 9000 330 190 12 HQI-E 70W/WDL clear 4050300397788 20 1 2/5 90 80 70 60 50 0 2000 4000 Hours burned POWERSTAR ® HQI®-E 1 2 Type ILCOS Lamp wattage W Lamp voltage V Ignition voltage min./max. kVs Lamp current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm² · 1000 lx Base Diameter d mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. base edge temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. Luminous flux in % Survival rate in % 80 70 60 0 2000 4000 Hours burned 6000 Survival rate HQI 100 W/NDL 100 Luminous flux in % 80 70 60 50 0 2000 80 70 60 0 4000 Hours burned 6000 8000 2000 4000 Hours burned 6000 8000 6000 8000 Luminous flux behaviour HQI 100 W/NDL 100 90 HQI-E 100 W NDL coated for open luminaires UVS MES/UB-100/38/ 1B-H-E27-55/144 100 95 3.6/5 1.1 7700 77 NDL 4000 70 > 50 < 0.04 E27 55 144 – universal 6000 330 190 16 HQI-E 100W/NDL coated 4050300345833 20 2 2 90 50 8000 HQI-E 100 W NDL clear for open luminaires UVS MCS/UB-100/40/ 1B-H-E27-55/144 100 95 3.6/5 1.1 8400 84 NDL 4200 70 > 50 < 0.03 E27 55 144 92 universal 6000 330 190 16 HQI-E 100W/NDL clear 4050300345871 20 1 2 Luminous flux behaviour HQI 100 W/WDL 100 90 50 HQI-E 100 W WDL coated for open luminaires UVS MES/UB-100/29/ 1B-H-E27-55/144 100 95 3.6/5 1.1 7900 79 WDL 2900 80 > 50 < 0.04 E27 55 144 – universal 9000 330 190 16 HQI-E 100W/WDL coated 4050300351551 20 2 2 Survival rate HQI 100 W/WDL 100 Survival rate in % HQI-E 100 W WDL clear for open luminaires UVS MCS/UB-100/30/ 1B-H-E27-55/144 100 95 3.6/5 1.1 8500 85 WDL 3000 85 > 50 < 0.04 E27 55 144 92 universal 9000 330 190 16 HQI-E 100W/WDL clear 4050300351537 20 1 2 90 80 70 60 50 0 2000 4000 Hours burned 13 POWERSTAR ® HQI®-E 1 2 Type ILCOS Lamp wattage W Lamp voltage V Ignition voltage min./max. kVs Lamp current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm² · 1000 lx Base Diameter d mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. base edge temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. Luminous flux in % Survival rate in % 80 70 60 0 4000 Hours burned 6000 Luminous flux in % 80 70 60 50 0 2000 4000 Hours burned 80 70 60 0 6000 8000 2000 4000 Hours burned 6000 8000 6000 8000 Luminous flux behaviour HQI-E 150 W/NDL 100 90 HQI-E 150 W NDL coated for open luminaires UVS MES/UB-150/38/ 1B-H-E27-55/144 150 85 3.6/5 1.8 11500 77 NDL 4000 86 > 50 < 0.03 E27 55 144 – universal 6000 330 190 20 HQI-E 150W/NDL coated 4050300434032 20 2 2/5 90 50 8000 Survival rate HQI-T, E 150 W/NDL 100 Survival rate in % 2000 HQI-E 150 W NDL clear for open luminaires UVS MCS/UB-150/40/ 1B-H-E27-55/144 150 85 3.6/5 1.8 12500 83 NDL 4200 80 > 50 < 0.17 E27 55 144 92 universal 6000 330 190 20 HQI-E 150W/NDL clear 4050300434018 20 1 2/5 Luminous flux behaviour HQI-E 150 W/WDL 100 90 50 HQI-E 150 W WDL coated for open luminaires UVS MES/UB-150/29/ 1B-H-E27-55/144 150 95 3.6/5 1.8 11600 77 WDL 2900 70 > 50 < 0.17 E27 55 144 – universal 9000 330 190 20 HQI-E 150W/WDL coated 4050300433998 20 2 2/5 Survival rate HQI-T, E 150 W/WDL 100 14 HQI-E 150 W WDL clear for open luminaires UVS MCS/UB-150/29/ 1B-H-E27-55/144 150 95 3.6/5 1.8 12900 86 WDL 3000 70 > 50 < 0.17 E27 55 144 92 universal 9000 330 190 20 HQI-E 150W/WDL clear 4050300433974 20 1 2/5 90 80 70 60 50 0 2000 4000 Hours burned POWERSTAR ® HQI®-E/P 1 Type ILCOS Lamp wattage W Lamp voltage V Ignition voltage min./max. kVs Lamp current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm² · 1000 lx Base Diameter d mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. base edge temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. Luminous flux in % 80 70 60 0 2000 4000 6000 Hours burned 8000 10000 12000 HQI-E/P 400 W D coated for open luminaires UVS, HQI-VG MES/UB-400/45=50/1A-H-E40-120/290 400 115 3/5 3.5 25000 71 D 5200 90 > 50 < 0.11 E40 120 290 – universal 12000 400 250 35 HQI-E/P 400W/D 4050300637433 12 1 2 Luminous flux behaviour HQI 400 W/D 100 90 50 HQI-E/P 400 W D coated for open luminaires UVS, NAV-VG MES/UB-400/45=50/1A-H-E40-120/290 400 110 3/5 3.8 31000 76 D 4700 90 > 50 < 0.11 E40 120 290 – universal 12000 400 250 45 HQI-E/P 400W/D 4050300637433 12 1 2 Survival rate HQI 400 W/D 100 Survival rate in % HQI-E/P 250 W D coated for open luminaires UVS MES/UB-250/52/1A-H-E40-90/226 250 100 3/5 3 17000 71 D 5200 90 > 50 < 0.12 E40 90 226 – universal 6000 400 250 32 HQI-E/P 250W/D 4050300637457 12 1 2 90 80 70 60 50 0 2000 4000 6000 Hours burned 8000 10000 12000 15 POWERSTAR ® HQI®-E 1 HQI-E 250 W D coated Type ILCOS ME/UB-250/52/ 1A-H-E40-90/226 Lamp wattage W 250 Lamp voltage V 100 Ignition voltage min./max. kVs 3/5 Lamp current A 3 Nominal gear current A Nominal luminous flux lm 19000 Luminous efficacy lm/W 78 Light colour/Colour appearance D Colour temperature K 5200 Colour rendering index Ra 90 NIOSH Skin h > 27 ACGIH UV output mW/lm² · 1000 lx < 0.31 Base E40 Diameter d mm 90 Length max. I mm 226 LCL a mm – Burning position universal Average lamp life h 12000 Max. perm. outer bulb temp. °C 400 Max. perm. base edge temp. °C 250 PF corr. cap. at 50 Hz µF 32 Lamp reference HQI-E 250W/D EAN 4050300015248 Standard pack Qty 12 Figure No. 1 Circuit (see page 22) Fig. no. 2 Survival rate HQI 250 W/D 90 80 70 60 0 6000 Hours burned 8000 10000 80 70 60 0 2000 4000 80 70 60 0 6000 Hours burned 8000 10000 12000 2000 4000 6000 Hours burned 8000 10000 12000 8000 10000 12000 Luminous flux behaviour HQI 400 W/D 100 90 50 90 50 12000 Luminous flux in % Survival rate in % 4000 Survival rate HQI 400 W/D 100 16 2000 HQI-E 400 W D coated HQI-VG ME/UB-400/53=55/ 1A-H-E40-120/290 400 110 3/5 3.6 3.5 26000 72 D 5500 90 > 18 < 0.46 E40 120 290 – universal 12000 400 250 35 HQI-E 400W/D 4050300019727 12 1 2 Luminous flux behaviour HQI 250 W/D 100 Luminous flux in % Survival rate in % 100 50 HQI-E 400 W D coated NAV-VG ME/UB-400/53=55/ 1A-H-E40-120/290 460 130 3/5 3.8 4.6 34000 81 D 5300 90 > 18 < 0.46 E40 120 290 – universal 12000 400 250 45 HQI-E 400W/D 4050300019727 12 1 2 90 80 70 60 50 0 2000 4000 6000 Hours burned POWERSTAR ® HQI®-E 1 2 Type ILCOS Lamp wattage W Lamp voltage V Ignition voltage min./max. kVs Lamp current A Nominal gear current A Nominal luminous flux lm Luminous efficacy lm/W Light colour/Colour appearance Colour temperature K Colour rendering index Ra NIOSH Skin h ACGIH UV output mW/lm2 · 1000 lx Base Diameter d mm Length max. I mm LCL a mm Burning position Average lamp life h Max. perm. outer bulb temp. °C Max. perm. base edge temp. °C PF corr. cap. at 50 Hz µF Lamp reference EAN Standard pack Qty Figure No. Circuit (see page 22) Fig. no. Survival rate HQI 400 W/N 100 90 80 70 60 50 0 2000 4000 Luminous flux behaviour HQI 400 W/N 100 Luminous flux in % Survival rate in % HQI-E HQI-E HQI-E HQI-E HQI-E 400 W 400 W 400 W 400 W 1000 W N N N N N clear clear coated coated coated NAV-VG HQI-VG NAV-VG HQI-VG MC/UB-400/40=46/ MC/UB-400/40=46/ ME/UB-400/38=44/ ME/UB-400/38=44/ ME-1000/37/ 2B-H-E40-120/285/H45 2B-H-E40-120/285/H45 2B-H-E40-120/285/H45 2B-H-E40-120/285/H45 2B-H-E40-165/380/H45 440 380 440 380 1050 120 120 120 120 130 3.6/5 3.6/5 3.6/5 3.6/5 4/5 4 3.4 4 3.4 9.0 4.6 3.5 4.6 3.5 9.5 42000 34000 40000 34000 100000 94 90 94 90 91 N N N N N 4000 4600 3800 4400 3800 65 60 65 60 65 > 5.7 > 5.7 > 5.7 > 5.7 > 15 < 1.5 < 1.5 < 1.5 < 1.5 < 0.56 E40 E40 E40 E40 E40 120 120 120 120 165 285 285 285 285 380 198 198 – – – h45 h45 h45 h45 h 45 12000 12000 12000 12000 9000 500 500 500 500 400 250 250 250 250 250 45 35 45 35 85 HQI-E HQI-E HQI-E HQI-E HQI-E 400W/N clear 400W/N 400W/N 1000W/N 400W/N clear 4050300292632 4050300292632 4050300305431 4050300305431 4050300015279 12 12 12 12 6 1 1 2 2 2 2 2 2 2 2 6000 Hours burned 8000 10000 12000 90 80 70 60 50 0 2000 4000 6000 Hours burned 8000 10000 12000 17 Please note: The values and curves published in this document are for guidance only. The basic data was determined under controlled laboratory conditions for a switching cycle of 11 h on/1 h off. There may be considerable differences in actual practice. The highlighted areas around the curves represent a 90% confidence range based on our test conditions. NIOSH threshold and ACGIH UV output: The radiated energy of a lamp is indicated by the defined NIOSH curve. The NIOSH effective radiated output calculated from this is converted into permitted exposure times with defined limit values. The ACGIH UV output value correlates directly with the NIOSH value and represents the current required value for UV exposure. PF correction capacitor: The pf correction capacitors are designed so that cos w ≥ 0.9 is achieved at rated voltage. Operating instructions Supply voltage: The lamps must be connected via suitable control gear. A 240 V / 50 Hz ac supply is generally required. If a different supply voltage is used (e.g. 400 V / 50 Hz) control gear with appropriate taps must be used. Permitted mains voltage deviation: ± 3% Sudden fluctuations in mains voltage of more than 10% may cause the lamps to go out. If the deviation from rated supply voltage (230 V or 400 V) is permanent, high-pressure discharge lamps may exhibit changes in colour or luminous flux. Lamp life may also be reduced. The following lamps with integrated igniters will start on mains voltage: c HQI®-T 2000 /D/I c HQI®-T 2000 /N The lamps must not be operated with integrated igniters in luminaires equipped with igniters. Suitable igniters and control gear for POWERSTAR ® are available from the electrical industry. Control gear: In the case of igniters equipped with OSRAM switching element SE 600 (built-in spark gap), SE 600 must be replaced each time the lamp is replaced. Conventional control gear: Choke, igniter and pf correction capacitor. Operating temperatures: The right igniter for the particular lamp type must be used to ensure reliable and safe ignition. Igniters must always be installed close to the lamp. The choke may be installed any distance from the lamp, provided the permissible voltage drop is not exceeded. For power supplies with a neutral conductor the choke should be connected to the live conductor. In the case of luminaires in which there are no lamps installed, the ignition equipment (igniter, ignition pulser) must be disabled when voltage is applied otherwise the igniters may produce radio interference. The chokes and pf correction capacitors generally needed for operating discharge lamps may, under certain conditions, create oscillating circuits. These circuits may then produce excessive currents and voltages, which in turn can destroy the lamps, ballasts and capacitors. Such resonance phenomena must be avoided by appropriate circuits and fuses. When high-pressure discharge lamps come to the end of their lives a rectifier effect may occur (see IEC 62035). This is not manufacturer-specific. Because of the excessive dc current components the ballasts and igniters may become overheated. 18 High-pressure discharge lamps should therefore only be operated with control gear with thermal protection. This applies also to control gear with the option of power reduction. Only high-pressure discharge lamps with external igniters are suitable for low-temperature applications down to – 50 °C. Such applications call for special (heatable) igniters such as MZN 400 SU-LT from BAG Turgi (for lamps from 100 to 400 W). Power factor: CCG: Because of the series connected choke this is around 0.5 to 0.7 (without compensation) ECG: If POWERTRONIC ® is used the power factor is greater than 0.96. Compensation is therefore not needed here. Switching on: Full luminous flux is reached only a few minutes after the lamp is switched on. The start-up current may be up to twice the operating current depending on the control gear. (See also the graphs on p. 21) Fusing: Guarantee: HQI® lamps must be protected by slow acting fuses. If fuse wire is used it is sufficient for it to be rated at twice the rated current of the lamp. If automatic cutouts are used they should have characteristic “C”. If adjusted to the upper limit value of 10 x rated current there will be no triggering if fuse protection is at twice the rated lamp current. A guarantee can only made if suitable control gear is used and the defined operating conditions are met. Restarting: The lamps will restart only after they have cooled down for 2 to 15 minutes. For POWERSTAR ® HQI®-TS = 1000 W and HQI®-TS 2000 /D/S, instant restarting is possible with suitable igniters. The necessary surge voltage is 25 to 60 kVs. Lampholders: Safety: OSRAM high-pressure lamps meet the safety requirements defined in IEC 62035. All HQI lamps up to 400 W are of UV-reduced design. The lamp packaging will indicate this fact until there is any change. Because of their high operating pressure all HQI-lamps may only be used in fully enclosed luminaires designed to take them: c All HQI®-TS c All HQI®-T c All HQI®-E ≥ 250 W As we cannot completely rule out the possibility of the bulb bursting, luminaires for the lamps mentioned above must be equipped with sealed shatter-proof shields that can withstand wide fluctuations in temperature. Because of the high voltages involved in ignition the lampholders must be designed for these high voltages. Lampholders that meet these requirements are available from appropriate manufacturers. Operating lamps with a damaged outer bulb is dangerous and therefore not permitted. Exception: HQI®-TS ... without an outer bulb. Power reduction: Lamp operation: Dimming metal halide lamps is not recommended. OSRAM cannot provide a guarantee for dimmed lamps. Dimming adversely affects colour rendering. The colour location shifts towards colder light colours and the colour spread increases. Dimmed lamps also tend to flicker. Luminous flux maintenance is significantly worse as a result of dimming. Dimming can shorten the life of the lamps. Operating high-pressure lamps for short periods in combination with frequent on/off switching will shorten their life. This applies to both cold starting and hot restarts. The lamps should be operated for at least 3 hours and should remain off for at least 30 minutes. This applies in particular to HQI® = 1000 W. Exceptions: The following lamps are suitable for open luminaires: c All HQI®-E 70 W to 150 W c All HQI®-E/P The use of shields should be considered for safety reasons in each case. End of life: To protect the control gear and to avoid radio interference, high-pressure discharge lamps must be replaced as soon as they come to the end of their life. These lamps reach their end of life when c the light colour of the lamp changes dramatically c there is a significant loss of brightness c the lamp no longer ignites c the lamp starts to cycle (periodically goes out and ignites again). At end of lamp life the risk of a broken burner rises. This phenomena is caused by effects not dependent on the manufacturer like the rectifying effect mentioned earlier. Because of this we strongly recommend to change the lamp latest after average lifetime has been reached or if one of the above mentioned effects are shown. Luminaire design: Luminaire design (thermal design and fuse protection) should be based on the EN 60598-1 standard. HQI® 1000 W to 2000 W lamps should be held without pressure or by means of a lamp support close to the base-free end. Notes on disposal: All metal halide lamps contain small quantities of mercury. If they break, poisonous mercury vapour may be released. The lamps must be treated as waste requiring special supervision with EEC code 20 01 21* for waste or residue containing mercury and should be passed to a relevant collection or recycling company. 19 Photometric and electrical data: All lamp-specific electrical and photometric data is measured after 100 hours of operation under laboratory conditions on reference equipment. Unless otherwise indicated, the data relates to the horizontal burning position for T and TS types and to the base up burning position for E types. If different burning positions are used in actual practice there may be considerable changes in the lamp data, particularly with regard to luminous flux, colour temperature and lamp life. The luminous flux is virtually unaffected by the ambient temperature outside the luminaire. At low ambient temperatures down to around – 50 °C special igniters are needed. Detailed information on heat accumulation tubes (luminaire simulators) for determining lamp data for HQI®-TS and HCI®-TS is given in IEC 61167, clause 1.7. Colour deviations: With all metal halide lamps there may be differences in colour from one lamp to the next due to external factors such as mains voltage, type of control gear used, burning position and luminaire design. Lamp life There are a confusing number of definitions for lamp life, and these differ from one region to the next and from one application to the next. The basic definitions for the most common types are given below. Minimum life: Minimum period of time in which a lamp remains in operation under laboratory conditions. This document refers explicitly only to the average life. Economical life: Average life: Average number of hours burned over several groups in which in the group in question half the lamps have failed as the result of a defect (50% failure). Period of time between group relamping of an installation under the condition that operating costs are minimised and the installation luminous flux does not fall below a particular value. This will vary according to the application. Survival rate: Service life: Quantity of working lamps of a group of lamps after a defined number of burning hours. Average value of some groups. Simplified practical view of the economical life. This is the operating time after which the installation luminous flux (the product of the relative luminous flux and the lamps still in operation) is still around 70% (sometimes 80%). Operating characteristics in relation to the supply voltage POWERSTAR HQI-T ʺ 150 W POWERSTAR, other versions 10 % 120 10 % 120 110 110 100 PL UL IL Φ UL Φ 80 80 70 PL 70 5 100 105 % 110 Mains voltage 20 IL 0 0 0 100 Φ = Luminous flux PL = Lamp wattage IL = Lamp current UL = Lamp voltage 0 5 100 105 % 110 Mains voltage = Not permitted Start-up behaviour (average value) 180 180 160 160 140 140 120 120 100 100 Rel. operating values POWERSTAR HQI-T ʺ 150 W Rel. operating values POWERSTAR HQI-T ʺ 150 W with POWERTRONIC 80 60 40 20 0 1 IL 80 PL 60 UL 40 20 Φ 0 2  min 4 Start-up time 1 2  min 4 Start-up time POWERSTAR HQI-TS 70 W…1000 W with CCG POWERSTAR Neutral White 1000 W and 2000 W with CCG 180 180 160 160 140 140 IL 100 100 Rel. operating values % 120 Rel. operating values % 120 80 60 PL 40 20 UL 0 Φ 1 2  min 4 Start-up time IL PL UL 80 60 40 20 Φ 0 1 2  min 4 Start-up time POWERSTAR Daylight 2000 W with CCG 180 160 IL 140 120 Rel. operating values % 100 PL UL 80 60 40 Φ 20 0 1 2  min 4 Start-up time 21 Circuit diagrams D ZS L LH UN K F N POWERTRONIC PTU (all) LL LH 2 1 B =6  A fuse, slow acting D = Choke F = Protection on demand K = PF correction capacitor K+S = Time-limiting switch and contactor L = Lamp L H = High-voltage terminal Mp = Neutral conductor Sch = Switch 3 U N = 2  30 V ac mains voltage (for 2000 W = 400 V ac) Z = Igniter to be installed near the lamp ZL = HF igniter lead to contact plate of lamp ZS = Symmetrical hot restrike ignitor with automatic ignition 4 5 For power supplies with a neutral conductor the choke should be connected to the live conductor. The right igniter for the particular lamp type must be used to ensure reliable and safe ignition. Chokes, holder, capacitors and igniters are available from electrical suppliers. Burning positions s5 Permitted Not permitted Base 8.5 G22 IEC 7004-75 22 LH G 8.5 Spectral power distribution of discharge lamps POWERSTAR ® HQI® .../WDL HQI® .../NDL HQI® .../N HQI® .../D Visible range from 380 to 780 nm Vertical scale 400 mW 1000 lm · 10 nm 23 Global presence. OSRAM supplies customers in around 150 countries. • 65 companies and sales offices for 100 countries • 48 countries served by local agents or OSRAM GmbH, Munich OSRAM GmbH Head Office Hellabrunner Strasse 1 81543 MUNICH GERMANY Tel.: +49-(0)89-6213-0 Fax: +49-(0)89-6213-2020 www.osram.com Kazakhstan Kenya Latvia Lithuania Malaysia Mexico Norway Peru Philippines Poland Portugal Rumania Russia Serbia-Montenegro Singapore Slovakia South Africa South Korea Spain Sweden Switzerland Taiwan Thailand Turkey Ukraine United Arab Emirates USA Vietnam 106 T001 GB 06/07 pd OSRAM HID Subject to modification without notice. Errors and omissions excepted Argentina Australia Austria Benelux Bosnia-Herzegovina Brazil Bulgaria Canada Chile China Colombia Croatia Czech Republic Denmark Ecuador Egypt Estonia Finland France Germany Great Britain Greece Hungary India Indonesia Iran Italy Japan z Printed on paper treated with chlorine-free bleach OSRAM associated companies and support centres.
H400D (HQI-T) 价格&库存
很抱歉,暂时无法提供与“H400D (HQI-T)”相匹配的价格&库存,您可以联系我们找货
