www.osram-os.com
Produktdatenblatt | Version 1.1
BPW 34 S
BPW 34 S
DIL SMT
Silicon PIN Photodiode
Applications
——LIDAR, Pre-Crash, ACC
——Rain Sensors
Features:
——Package: clear epoxy
——Corrosion Robustness Class: 3B
——Qualifications: The product qualification test plan is based on the guidelines of AEC-Q101-REV-C,
Stress Test Qualification for Automotive Grade Discrete Semiconductors.
——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2)
——Suitable for reflow soldering
——Especially suitable for applications from 400 nm to 1100 nm
——Short switching time (typ. 20 ns)
——DIL plastic package with high packing density
Ordering Information
Type
Photocurrent 1)
Ev = 1000 lx; Std. Light A; VR = 5 V
IP
≥ 55 µA
BPW 34 S-Z
1 Version 1.6 | 2019-12-05
Photocurrent
typ.
IP
80 µA
Ordering Code
Q65110A1209
BPW 34 S
Maximum Ratings
TA = 25 °C
Parameter
Symbol
Operating Temperature
Top
min.
max.
-40 °C
100 °C
Storage temperature
Tstg
min.
max.
-40 °C
100 °C
Reverse voltage
t ≤ 2 µs; TA = 25 °C
VR
max.
32 V
Total power dissipation
Ptot
max.
150 mW
ESD withstand voltage
VESD
max.
2 kV
2 Version 1.6 | 2019-12-05
Values
BPW 34 S
Characteristics
TA = 25 °C
Parameter
Symbol
Wavelength of max sensitivity
λS max
typ.
920 nm
Spectral range of sensitivity
λ10%
typ.
420 ... 1120
nm
Radiant sensitive area
A
typ.
7.02 mm²
Dimensions of active chip area
LxW
typ.
2.65 x 2.65
mm x mm
Half angle
φ
typ.
60 °
Dark current
VR = 10 V
IR
typ.
max.
Spectral sensitivity of the chip
λ = 850 nm
Sλ
typ.
0.62 A / W
Quantum yield of the chip
λ = 850 nm
η
typ.
0.90 Electrons
/ Photon
Open-circuit voltage
Ev = 1000 lx; Std. Light A; VR = 0 V
VO
min.
typ.
300 mV
365 mV
Short-circuit current
ISC
typ.
80 µA
Rise time
VR = 5 V; RL = 50 Ω; λ = 850 nm
tr
typ.
0.02 µs
Fall time
tf
typ.
0.02 µs
Forward voltage
IF = 100 mA; E = 0
VF
typ.
1.3 V
C0
typ.
72 pF
Temperature coefficient of voltage
TCV
typ.
-2.6 mV / K
Temperature coefficient of short-circuit current
Std. Light A
TCI
typ.
0.18 % / K
Noise equivalent power
VR = 10 V; λ = 850 nm
NEP
typ.
0.041 pW /
Hz1/2
Detection limit
D*
typ.
6.5e12 cm x
Hz1/2 / W
Capacitance
VR = 0 V; f = 1 MHz; E = 0
3 Version 1.6 | 2019-12-05
Values
2 nA
30 nA
BPW 34 S
Relative Spectral Sensitivity
2), 3)
Srel = f (λ)
100
80
60
40
Directional Characteristics
600
800
1000
λ[ ]
2), 3)
Srel = f (φ)
40
30
50
ϕ
0.8
60
0.6
70
0.4
80
0.2
1.0
0.8
100
OHF01402
4 Version 1.6 | 2019-12-05
0.6
0.4
60
80
100
120
BPW 34 S
Photocurrent/Open-Circuit Voltage
IP (VR = 5 V) / VO = f (Ev)
ΙP
2), 3)
Dark Current
2), 3)
IR = f (VR); E = 0
OHF01066
10 3
µA
10 2
10 4
mV
OHF00080
4000
VO
ΙR
pA
10 3
3000
10 2
2000
10 1
1000
10 0
VO
10 1
ΙP
10 0
10 -1
10 0
10
1
10
2
10
3
lx 10 4
EV
Capacitance
2), 3)
C = f (VR); f = 1MHz; TA = 25°C
OHF00081
100
C
pF
80
70
60
50
40
30
10 -1
10 0
10 1
0 -2
10
5 Version 1.6 | 2019-12-05
V 10 2
VR
10
15
V
VR
BPW 34 S
Dark Current
2)
IR = f (TA); E = 0; VR = 10 V
OHF05717
104
IR
nA
103
102
101
100
10-1
60
80 ˚C 100
TA
Power Consumption
Ptot = f (TA)
OHF00394
160
mW
Ptot
140
120
100
80
60
40
60
6 Version 1.6 | 2019-12-05
80 ˚C 100
TA
BPW 34 S
Chip position
0.9 (0.035)
0.7 (0.028)
4.5 (0.177)
4.3 (0.169)
6.2 (0.244)
0.2 (0.008)
0.1 (0.004)
6.7 (0.264)
0...5
1.1 (0.043)
0.9 (0.035)
1.8 (0.071) ±0.2 (0.008)
1.7 (0.067)
1.5 (0.059)
4.0 (0.157)
3.7 (0.146)
0.3 (0.012)
4)
1.2 (0.047)
1.1 (0.043)
0...0.1
(0...0.004)
Dimensional Drawing
Photosensitive area
Cathode lead
2.65 (0.104) x 2.65 (0.104)
GEOY6863
Further Information:
Approximate Weight:
43.0 mg
Package marking:
Cathode
Corrosion test:
Class: 3B
Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC
60068-2-43)
7 Version 1.6 | 2019-12-05
BPW 34 S
Recommended Solder Pad
8 Version 1.6 | 2019-12-05
4)
BPW 34 S
Reflow Soldering Profile
Product complies to MSL Level 4 acc. to JEDEC J-STD-020E
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
250
s 300
t
Profile Feature
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Recommendation Maximum
Ramp-up rate to preheat*)
25 °C to 150 °C
tS
Time tS
TSmin to TSmax
Ramp-up rate to peak*)
TSmax to TP
Liquidus temperature
60
2
3
100
120
2
3
Unit
K/s
s
K/s
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
3
6
Ramp-down rate*
TP to 100 °C
10
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
9 Version 1.6 | 2019-12-05
°C
480
s
K/s
s
BPW 34 S
Taping
4)
10 Version 1.6 | 2019-12-05
BPW 34 S
Tape and Reel
5)
W1
D0
P0
A
N
F
W
E
13.0 ±0.25
P2
Label
P1
Direction of unreeling
W2
Leader: min. 400 mm *
Trailer: min. 160 mm *
*) Dimensions acc. to IEC 60286-3; EIA 481-D
OHAY0324
Reel Dimensions
A
180 mm
W
Nmin
12 + 0.3 / - 0.1 mm
11 Version 1.6 | 2019-12-05
W1
60 mm
W2 max
12.4 + 2 mm
18.4 mm
Pieces per PU
1500
BPW 34 S
Barcode-Product-Label (BPL)
Dry Packing Process and Materials
4)
Moisture-sensitive label or print
L
E
E
V
l
e be
sela
k,
H
de
L
If
an
bl r co
ba
(R
id
m
ity
H
R
hu
0%
e
e
/6
tiv
˚C
la ared ag
ck
re
fr
30
_
in pa
k
of
to
90
rs
ea
s
d
rs
ou
or
te (p
on
rs
H
de
ou
iti
H
an bjec ng
ou rs
co
˚C
72
si
nd
H ou
5
te
48
˚C su es
e
H
co
24 6
da
e
y
40 be oc
tim
˚C
e
or
ith
tim
ill pr).
or
ct
w
O
w nt
23
tim e
at
lo
or
fa
M TO
F
s
al
tim
at le ˚C at
lo
at
or
e.
P
th
F
l
tic
th va
lo or
ur
O
F lo
s ui
on
be
if: read
en
w
ed
l 4 5
F
m
la
ce eq
id
lo
g, n
oc
l
ve
vi
5a
is
in
or
be
24
de
pr
ve l
6
Le
de ,
nt whe
e
te
co
g:
, w
e
Le ve l
ke
r
ou
se
da
ba ed flo
ur
e
Le ve
m %
ba
e
ba
al
st
ur e
Le
r
en re
ed
e
re> 10
oi
st
e
e
fo
tim
ur
se
al
op
fo
M
se
oi st ur
as
k,
is
or .
33
se
is
M oi st
bed
k,
lo H
an
g ph
-0
M oi
in
an in F R ng ar
rbl
D
M
e
ba
T
r
po If bl ith
lif
ki r C.
(if
S
is
p.
w
ea r ks
lf
J10 ba to et
th va
Y ea
m
rs
m
_
r w,
he
ed
1
ee
te
Y
d, EC
iredicat
S
fte
at
nt
1
W Hou
D
A flody
qu In no ire
1.
d
e
ou
4 8
re
reity is
qu/JE
re
2.
bo
e
M
tim
to es id 2b
re C
16
e
a)
S
tim
is IP
ic
ed loor
tim e
b) ev Humor
or
e
en
F
tim
lo
or
D
2a king
nc
te
F
op
a)
lo or
3.
b) ba re
F lo
da
e
fe
l 1 2
F
If
al
re
tim ve
l
4.
se
d
l 2a
ve
Le
3
an
ve l
ag
e
Le
e
B
ve
ur
e
Le
at
st
ur
e
Le
D
oi
st
ur e
M
oi
st ur
M
oi st
M oi
M
N
E RS
s
in IV O
IT T
S C
nta
N U
TIO
U coSEND
Ais bUagRMEICO
T E
CThIS
S
d
Barcode label
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
12 Version 1.6 | 2019-12-05
BPW 34 S
Schematic Transportation Box
4)
Barcode label
N
O
(Q
)Q
TY
:2
00
D
D
/C
:0
(X
Packing
Sealing label
Length
195 ± 5 mm
195 ± 5 mm
13 Version 1.6 | 2019-12-05
M
Y
DE
-1
+Q
-1
R
18
P
OHA02044
Dimensions of Transportation Box
Width
RO
UP
M
RA
OS
PR
O
D
5
14 2
110 0
G
4
01
4
C:
D/
(9
D)
(Q
)Q
TY
O
TC
P)
(6
T
LO
(1
T)
O
D
PR
D
EM
Y
18
R
-1
Q
P
-1
G
R
O
U
P:
u L
lt S
iT Y
O T6
P 7
L 6
M
14
4
(G
E Bi
D Bi n1
Bi n2 : Pn3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R ditio 0 C R
07
PA 7 na RT
l TE
C
KV
XT
AR
Muster
A
o M
n O
d
u p
cto to
rs
R
34
ic
N
O
O
S
H
12
G
BA
TC
H
(1
T)
LO
T
N
O
:1
(6
P)
23
em
8
2199
2100
5
14 2
110 0
(X
O
M O
PT
O
M
998
NO
CThISTU
SE
S
21
2100
BA
_
s
ur s
Ho ururs s
de
Ho
co
72
Ho ur
te
48
e
Ho
24 6
da
40 be
tim e e
˚C
or
th
r
pr
ll
tim
ct
23
oo r
wi nt
tim e
at
l wi
fa
r
Fl oo
tim
s
at
at le ˚C at
e.
ica
l
Fl
th
oo r
th va
ur
nt
Fl oo
s ui
be
on
if: read
w
ed
l 4 5
Fl
la
m
ide
ce eq
lo
g,
oc
ve l
vi
is
in en
de
be
24 de or
l 5a6
pr
Le ve
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou
se
da
ba ed flo ba
Le ve
tu re
m %
ba
e
al
e
Le
r
en re
e
ed
re 10
ois stu ur e
tim
se
fo
al
op se
fo >
M oi
r
se
st ur
3
is
is ha
se
M
oi st
nk
be
k,
oo .
03
rd
g
M oi
in
an in Fl RH g,
r-p
bla
DM
ba
Ca
po If bl th
kinr
life is
(if
ar
ST
f
p.
wi
10 ba to et
Jel r th va
Ye ar ks s
m
_
cat m d, C
ed
1
Ye ee ur
ire
Sh te w, te
di
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
ou
4 8
re
ed re
qu JE
2.
bo
ity is
M
or
tim e e
16
re C/
es id 2b
r
a)
St
tim
mor
is IP
ed
oo r
tim e
vic
b)
g e
r
Hu
Fl oo
en
tim
De
2a kin nc
te
Fl oo r
a)
op
3.
b) ba re
Fl oo
da
e
fe
l 1
Fl
If
al
re
tim ve l 2
4.
se
d
l 2a3
Le ve
g
an
ve l
e
Le
Ba
te
ur e
Le ve
Le
Da oist stur e
ur e
M
oi
st ur
M
oi st
M oi
H
12
34
RH
0%
/6
˚C
L
e el
selab
H)
nk de
co
(R
bla
r
S S
em R
ic AM
o
n O
d
u p
ct to
o
H
rs
NO
If
23
G
E
V
E
ba
ity
id
m
hu
e
e
d
tiv
re ag
NO
:1
L
la
re
fra ck
30
Nns IVE RS
in pa
k
of
ai IT TO
to
90
ea
d
ntNS
ns
UC
or
TIO
te (p
d
g
itio
ND
U g coSE
an bjec
˚C
sin
nd
O
5
˚C su es
Ais baRE
co
IC
y
M
oc
(G
M
u L
lt S
iT Y
O T6
P 7
L 6
E
D
Muster
Bi
Bi n1
Bi n2 : P-
n3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
Barcode label
Height
30 ± 5 mm
BPW 34 S
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the
eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light
sources have a high secondary exposure potential due to their blinding effect. When looking at bright light
sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
For further application related information please visit www.osram-os.com/appnotes
14 Version 1.6 | 2019-12-05
BPW 34 S
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
OSRAM OS products are not qualified at module and system level for such application.
In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.
15 Version 1.6 | 2019-12-05
BPW 34 S
Glossary
1)
Photocurrent: The photocurrent values are measured (by irradiating the devices with a homogenous
light source and applying a voltage to the device) with a tolerance of ±11 %.
2)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
3)
Testing temperature: TA = 25°C (unless otherwise specified)
4)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
5)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
16 Version 1.6 | 2019-12-05
BPW 34 S
Revision History
Version
Date
Change
1.6
2019-12-03
Characteristics
Electro - Optical Characteristics (Diagrams)
17 Version 1.6 | 2019-12-05
BPW 34 S
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
18 Version 1.6 | 2019-12-05
