Product datasheet
DULUX T/E PLUS 42 W/840
OSRAM DULUX T/E PLUS | CFLni, 3 tubes, with 4-pin base for ECG operation
Areas of application
Offices, public buildings
Shops
Supermarkets and department stores
Hotels, restaurants
Industrial lighting
__
Product benefits
Extremly economical
Good quality of light
Excellent luminous flux
Long service life
Improved maintenance
OSRAM System+ Guarantee in combination with OSRAM QUICKTRONIC ECG
Product features
Average life: 20,000 h (with QUICKTRONIC)
Color rendering index R : 80…89
a
Dimmable (3…100 %)
Short and compact pin-base lamp with triple-turn tubes
Single-ended four-pin plug-in GX24q base with shortened base casing
August 25, 2014, 16:39:36
© 2014, OSRAM GmbH. All rights reserved.
Page 1 of 7
Product datasheet
Technical data
Electrical data
Nominal wattage
43.00 W
Rated wattage
43.00 W
Rated lamp efficacy (HF data 25 °C)
Under clarification by authority and standardization
body
Energy consumption
51 kWh/1000h
Photometrical data
__
Nominal luminous flux
3200 lm
Rated luminous flux
3200 lm
Color temperature
4000 K
Light color
840
Light color as per EN 12464-1
LUMILUX Cool White
Color rendering index Ra
80…89
Luminous flux at 25 °C
3200 lm
Rated LLMF at 4,000 h
0.86
Rated LLMF at 6,000 h
0.84
Rated LLMF at 8,000 h
0.82
Rated LLMF at 12,000 h
0.79
Rated LLMF at 16,000 h
0.78
Rated LLMF at 20,000 h
0.76
Luminance
7 cd/cm²
Color rendering group
1B
Dimensions & weight
Page 2 of 7
Product datasheet
Product line drawing
__
Base
Overall length
169.0 mm
Product weight
79.80 g
Tube diameter
12 mm
Length
169.0 mm
Length acc. to IEC standard
155 mm
Length with base excl. base pins/connection
153.00 mm
Colors & materials
Lamp mercury content
2.6 mg
Temperatures
Rated ambient temp.w.max.luminous flux
25.0 °C
Lifespan
Nominal lamp life time
20000 h
Rated lamp life time
20000 h
Service life
13000 h
Rated lamp survival factor at 2,000 h
0.99
Rated lamp survival factor at 4,000 h
0.99
Rated lamp survival factor at 6,000 h
0.99
Rated lamp survival factor at 8,000 h
0.99
Rated lamp survival factor at 12,000 h
0.95
Rated lamp survival factor at 16,000 h
0.81
Rated lamp survival factor at 20,000 h
0.50
Operation mode LLMF/LSF
HF
Lifespan
20000 h 1)
Page 3 of 7
Product datasheet
1) With preheat ECG
Additional product data
__
Spectral power distribution
Base (standard designation)
GX24q-4
Appropriate disposal acc. to WEEE
Yes
Footnote only for product
For ECG operation only
Capabilities
Dimmable
Yes
Suitable for indoor
Yes
Certificates & standards
Energy efficiency class
A
Country specific categorizations
ILCOS
FSMH-42/840-/P/-GX24q-4
Country specific information
Product code
METEL code
SEG number
STK number
UK Org
4050300425627
OSRDTE42840
8330296
4934050
Page 4 of 7
Product datasheet
Lamp-ECG combination (System)
Product name
Product name ECG
EAN
Nominal current
Nominal wattage
+ Power loss
Luminous flux at
25 °C
Number of
lighting outlets
DULUX T/E 42W/840 PLUS
GX24Q
QT-M 2x26-42/220-240 S
4008321110022
0.39 A
92.00 W
3200 lm
2
QTP-M 1x26-42
4008321329134
0.20 A
46.00 W
3200 lm
1
QTP-M 2x26-32
4008321329158
0.20 A
46.00 W
3200 lm
1
QTP-T/E 1x26-42, (2x26)
4008321537089
0.20 A
45.00 W
3200 lm
1
QTi DALI-T/E 1x18-57 DIM
4008321060808
0.21 A
47.00 W
3200 lm
1
QTi DALI-T/E 2x18-42 DIM
4008321060822
0.39 A
90.00 W
3200 lm
2
QTi-T/E 1x18-57 DIM
4008321060860
0.21 A
47.00 W
3200 lm
1
QTi-T/E 2x18-42 DIM
4008321060846
0.39 A
90.00 W
3200 lm
2
__
Page 5 of 7
Product datasheet
Guarantee
Equipment / Accessories
Suitable for operation on electronic control gear
Safety advice
In case of lamp breakage: www.osram.com/brokenlamp
__
Circuit diagram
Logistical Data
Product code
Product description
Packaging unit
(Pieces/Unit)
Dimensions (height x
width x length)
Volume
Gross weight
4050300425627
DULUX T/E PLUS 42
W/840
Folding carton box
1
49 mm x 46 mm x
175 mm
0.39 dm³
91.00 g
4050300425634
DULUX T/E PLUS 42
W/840
Shipping carton box
10
139 mm x 191 mm x
222 mm
5.89 dm³
999.00 g
The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or
more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit.
Page 6 of 7
Product datasheet
References / Links
For more information on QUICKTRONIC electronic control gear go to
www.osram.com/QUICKTRONIC
Disclaimer
Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release.
__
Page 7 of 7
很抱歉,暂时无法提供与“DTE424”相匹配的价格&库存,您可以联系我们找货
