ELEMENT-120/220-240/24-G2
    AMSOSRAM(艾迈斯半导体)
    OSRAM - ELEMENT-120/220-240/24-G2 - LED Driver, LED Lighting, 120 W, 24 VDC, 5 A, Constant Voltage, ...
ELEMENT-120/220-240/24-G2 数据手册
Product datasheet ELEMENT 120/220-240/24 G2 ELEMENT G2 | Constant Voltage – Non dimmable Product family features _ Linear form factor _ Power factor: >0.95 at full load _ Total Harmonic Distortion (THD): < 15% _ Output voltage tolerance: < 3% _ Up to 30,000 h @ T max / up to 50,000 h @ T -10 °C c c _ Lifetime: up to 30,000 h (temperature at max. t ) c __ Product family benefits _ High efficiency (up to 91 %) _ Higher quality of light thanks to < 3% output ripple current _ Excellent price/performance ratio _ Class II design for wide application _ 3 years guarantee Areas of application _ Decorative lighting in hospitality, restaurants and Shops _ Shelf lighting _ Cove lighting _ Under cabinet lighting August 19, 2021, 17:01:51 ELEMENT 120/220-240/24 G2 © 2021, OSRAM GmbH. All rights reserved. Page 1 of 5 Product datasheet Technical data Electrical data __ Nominal input voltage 220…240 V Mains frequency 50…60 Hz Input voltage AC 198…264 V Power factor λ 0.95 Efficiency in full-load 89 % Device power loss 14.8 W 2) Inrush current < 32 A 3) Max. ECG no. on circuit breaker 10 A (B) 5 Max. ECG no. on circuit breaker 10 A (C) 8 Max. ECG no. on circuit breaker 16 A (B) 8 Max. ECG no. on circuit breaker 16 A (C) 12 Max. ECG no. on circuit breaker 25 A (B) 12 Surge capability (L-N) 1 kV Nominal output voltage 24 V Nominal output power 120 W Maximum output power 120 W Galvanic isolation primary/secondary 3 kV Output ripple Voltage (100 Hz)
ELEMENT-120/220-240/24-G2 价格&库存
很抱歉,暂时无法提供与“ELEMENT-120/220-240/24-G2”相匹配的价格&库存,您可以联系我们找货
