GW CSHPM1.EM-LQLS-XX53-1-350-R18
    AMSOSRAM(艾迈斯半导体)
    SMD3030
    发光二极管/LED 白色
GW CSHPM1.EM-LQLS-XX53-1-350-R18 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 GW CSHPM1.EM   GW CSHPM1.EM OSLON ® SSL 150 Higher performance. Lower thermal resistance. Extended range of driving conditions. This OSLON SSL family new generation LED provides a wide radiation pattern allowing perfect interaction and various designs including color mixing LED clusters. Applications ——Highbay Retail ——Downlights/Spotlights ——Highbay Industrial Features: ——Package: SMT ceramic package with silicone lens ——Typ. Radiation: 150° ——Color temperature: 2500K - 5000K ——CRI: 80 (min.), 82 (typ.) ——Lumen maintenance: Test results according to IESNA LM-80 available   ——ESD: 8 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B) 1 Version 1.8 | 2020-02-28 GW CSHPM1.EM   Ordering Information  Type Color temperature  Luminous Flux 1) IF = 350 mA ΦV Ordering Code GW CSHPM1.EM-KULQ-A939-1 2500 K 104 ... 130 lm Q65112A0492 GW CSHPM1.EM-KULQ-XX59-1 2500 K 104 ... 130 lm Q65112A0491 GW CSHPM1.EM-LPLR-A838-1 2700 K 112 ... 140 lm Q65112A0489 GW CSHPM1.EM-LPLR-XX58-1 2700 K 112 ... 140 lm Q65112A0487 GW CSHPM1.EM-LPLR-A737-1 3000 K 112 ... 140 lm Q65112A0490 GW CSHPM1.EM-LPLR-XX57-1 3000 K 112 ... 140 lm Q65112A0488 GW CSHPM1.EM-LPLR-A636-1 3500 K 112 ... 140 lm Q65111A7874 GW CSHPM1.EM-LPLR-XX56-1 3500 K 112 ... 140 lm Q65111A7879 GW CSHPM1.EM-LQLS-A535-1 4000 K 121 ... 150 lm Q65112A0485 GW CSHPM1.EM-LQLS-XX55-1 4000 K 121 ... 150 lm Q65112A0483 GW CSHPM1.EM-LQLS-A434-1 4500 K 121 ... 150 lm Q65112A0486 GW CSHPM1.EM-LQLS-XX54-1 4500 K 121 ... 150 lm Q65112A0484 GW CSHPM1.EM-LPLR-A333-1 5000 K 112 ... 140 lm Q65112A0931 GW CSHPM1.EM-LPLR-XX53-1 5000 K 112 ... 140 lm Q65112A0940 GW CSHPM1.EM-LQLS-A333-1 5000 K 121 ... 150 lm Q65111A6938 GW CSHPM1.EM-LQLS-XX53-1 5000 K 121 ... 150 lm Q65111A7878   2 Version 1.8 | 2020-02-28 GW CSHPM1.EM   Maximum Ratings Parameter Symbol Values Operating Temperature Top min. max. -40 °C 125 °C Storage Temperature Tstg min. max. -40 °C 125 °C Junction temperature absolute ** Tj,abs max. 160 °C Junction Temperature Tj max. 135 °C Forward Current TJ = 85 °C IF min. max. 100 mA 1300 mA Surge Current t ≤ 10 µs; D = 0.005 ; TJ = 85 °C IFS max. 2000 mA Reverse current 2) IR max. 200 mA ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B) VESD ** This is verified by testing 30 pieces. Pass criteria: No catastrophic failures allowed, luminous flux must be better than L70B50 after 1000 h.   3 Version 1.8 | 2020-02-28 8 kV GW CSHPM1.EM   Characteristics IF = 350 mA; TJ = 85 °C Parameter Symbol Viewing angle at 50% IV 2φ typ. 150 ° Forward Voltage 3) VF min. typ. max. 2.70 V 2.85 V 3.20 V Reverse voltage (ESD device) VR ESD min. 45 V Reverse voltage 2) IR = 20 mA VR max. 1.2 V Color Rendering Index 4) CRI min. typ. 80 82 Electrical thermal resistance junction/solderpoint with efficiency ηe = 20 % RthJS elec. typ. 4.2 K / W   4 Version 1.8 | 2020-02-28 Values GW CSHPM1.EM   Brightness Groups  Group Luminous Flux 1) IF = 350 mA min. ΦV Luminous Flux 1) IF = 350 mA max. ΦV KU 104 lm 112 lm LP 112 lm 121 lm LQ 121 lm 130 lm LR 130 lm 140 lm LS 140 lm 150 lm Forward Voltage Groups  Group Forward Voltage 3) min. VF Forward Voltage 3) max. VF K2 2.70 V 2.80 V L1 2.80 V 2.90 V L2 2.90 V 3.00 V M1 3.00 V 3.10 V M2 3.10 V 3.20 V   5 Version 1.8 | 2020-02-28 GW CSHPM1.EM   Chromaticity Coordinate Groups   6 Version 1.8 | 2020-02-28 5) GW CSHPM1.EM   Chromaticity Coordinate Groups 3500 K CCT Center Cx Center Cy Ø 2500 K 0.4804 0.4138 0.0076 0.0041 0.0126 0.0068 53.1 2700 K 0.4577 0.4098 0.0080 0.0041 0.0133 0.0068 54.1 3000 K 0.4339 0.4032 0.0086 0.0042 0.0142 0.0069 53.7 3500 K 0.4077 0.3929 0.0093 0.0042 0.0155 0.0069 53.9 4000 K 0.3818 0.3796 0.0094 0.0041 0.0157 0.0068 53.4 4500 K 0.3613 0.3669 0.0089 0.0038 0.0148 0.0063 57.0 5000 K 0.3446 0.3551 0.0081 0.0035 0.0135 0.0059 59.8   7 Version 1.8 | 2020-02-28 GW CSHPM1.EM     1 CCT 2500 K 2700 K 3000 K 3 4 5 Group Cx Cy Cx Cy Cx Cy Cx Cy Cx Cy A 0.4917 0.4328 0.4811 0.4315 0.4701 0.4128 0.4723 0.4130 0.4867 0.4245 B 0.4917 0.4328 0.5044 0.4344 0.4917 0.4149 0.4885 0.4146 0.4867 0.4245 C 0.4917 0.4149 0.4798 0.3967 0.4695 0.3954 0.4741 0.4031 0.4885 0.4146 D 0.4741 0.4031 0.4723 0.4130 0.4701 0.4128 0.4591 0.3941 0.4695 0.3954 E 0.4867 0.4245 0.4723 0.4130 0.4755 0.4133 0.4842 0.4202 F 0.4867 0.4245 0.4885 0.4146 0.4853 0.4143 0.4842 0.4202 G 0.4885 0.4146 0.4741 0.4031 0.4766 0.4074 0.4853 0.4143 H 0.4766 0.4074 0.4755 0.4133 0.4723 0.4130 0.4741 0.4031 A 0.4675 0.4285 0.4561 0.4259 0.4467 0.4076 0.4491 0.4081 0.4637 0.4212 B 0.4675 0.4285 0.4811 0.4315 0.4698 0.4123 0.4663 0.4115 0.4637 0.4212 C 0.4698 0.4123 0.4591 0.3941 0.4482 0.3917 0.4517 0.3984 0.4663 0.4115 D 0.4517 0.3984 0.4491 0.4081 0.4467 0.4076 0.4372 0.3892 0.4482 0.3917 E 0.4637 0.4212 0.4491 0.4081 0.4526 0.4088 0.4613 0.4166 F 0.4637 0.4212 0.4663 0.4115 0.4628 0.4108 0.4613 0.4166 G 0.4663 0.4115 0.4517 0.3984 0.4541 0.4030 0.4628 0.4108 H 0.4541 0.4030 0.4526 0.4088 0.4491 0.4081 0.4517 0.3984 A 0.4418 0.4211 0.4302 0.4171 0.4226 0.3995 0.4246 0.4002 0.4393 0.4153 B 0.4418 0.4211 0.4561 0.4259 0.4465 0.4073 0.4432 0.4062 0.4393 0.4153 C 0.4465 0.4073 0.4372 0.3892 0.4261 0.3856 0.4285 0.3911 0.4432 0.4062 D 0.4285 0.3911 0.4246 0.4002 0.4226 0.3995 0.4149 0.3819 0.4261 0.3856 E 0.4393 0.4153 0.4246 0.4002 0.4283 0.4014 0.4371 0.4105 F 0.4393 0.4153 0.4432 0.4062 0.4395 0.4050 0.4371 0.4105 G 0.4432 0.4062 0.4285 0.3911 0.4307 0.3960 0.4395 0.4050 H 0.4307 0.3960 0.4283 0.4014 0.4246 0.4002 0.4285 0.3911 A 0.4131 0.4093 0.4003 0.4034 0.3949 0.3871 0.3977 0.3883 0.4118 0.4054 B 0.4131 0.4093 0.4302 0.4171 0.4227 0.3997 0.4177 0.3975 0.4118 0.4054 C 0.4227 0.3997 0.4149 0.3819 0.4022 0.3763 0.4036 0.3804 0.4177 0.3975 D 0.4036 0.3804 0.3977 0.3883 0.3949 0.3871 0.3895 0.3707 0.4022 0.3763 E 0.4118 0.4054 0.3977 0.3883 0.4017 0.3902 0.4102 0.4004 F 0.4118 0.4054 0.4177 0.3975 0.4137 0.3956 0.4102 0.4004 G 0.4177 0.3975 0.4036 0.3804 0.4052 0.3854 0.4137 0.3956 H 0.4052 0.3854 0.4017 0.3902 0.3977 0.3883 0.4036 0.3804   3500 K 2 8 Version 1.8 | 2020-02-28 GW CSHPM1.EM   4000 K 4500 K 0.3853 0.3947 0.3737 0.3879 0.3704 0.3731 0.3714 0.3737 0.3845 0.3913 B 0.3853 0.3947 0.4003 0.4034 0.3949 0.3871 0.3922 0.3855 0.3845 0.3913 C 0.3949 0.3871 0.3895 0.3707 0.3783 0.3645 0.3791 0.3679 0.3922 0.3855 D 0.3791 0.3679 0.3714 0.3737 0.3704 0.3731 0.3671 0.3583 0.3783 0.3645 E 0.3845 0.3913 0.3714 0.3737 0.3756 0.3760 0.3834 0.3866 F 0.3845 0.3913 0.3922 0.3855 0.3880 0.3832 0.3834 0.3866 G 0.3922 0.3855 0.3791 0.3679 0.3802 0.3726 0.3880 0.3832 H 0.3802 0.3726 0.3756 0.3760 0.3714 0.3737 0.3791 0.3679 A 0.3634 0.3809 0.3550 0.3752 0.3538 0.3664 0.3629 0.3779 B 0.3634 0.3809 0.3737 0.3879 0.3709 0.3753 0.3629 0.3779 C 0.3695 0.3690 0.3671 0.3583 0.3593 0.3532 0.3597 0.3559 D 0.3597 0.3559 0.3524 0.3555 0.3514 0.3480 0.3593 0.3532 E 0.3629 0.3779 0.3538 0.3664 0.3532 0.3616 0.3557 0.3632 0.3623 0.3735 F 0.3629 0.3779 0.3709 0.3753 0.3703 0.3728 0.3669 0.3706 0.3623 0.3735 G 0.3703 0.3728 0.3695 0.3690 0.3597 0.3559 0.3603 0.3603 0.3669 0.3706 H 0.3603 0.3603 0.3557 0.3632 0.3532 0.3616 0.3524 0.3555 0.3597 0.3559 A 0.3452 0.3678 0.3375 0.3619 0.3372 0.3528 0.3451 0.3648 B 0.3452 0.3678 0.3550 0.3752 0.3532 0.3614 0.3530 0.3612 0.3451 0.3648 C 0.3532 0.3614 0.3514 0.3480 0.3440 0.3426 0.3441 0.3454 0.3530 0.3612 D 0.3441 0.3454 0.3369 0.3445 0.3366 0.3372 0.3440 0.3426 E 0.3451 0.3648 0.3372 0.3528 0.3371 0.3496 0.3396 0.3514 0.3449 0.3609 F 0.3451 0.3648 0.3530 0.3612 0.3496 0.3588 0.3449 0.3609 G 0.3530 0.3612 0.3441 0.3454 0.3443 0.3493 0.3496 0.3588 H 0.3443 0.3493 0.3396 0.3514 0.3371 0.3496 0.3369 0.3445 0.3441 0.3454   5000 K A 9 Version 1.8 | 2020-02-28 GW CSHPM1.EM   Group Name on Label  Example: KU-33-K2 Brightness Color Chromaticity KU 33   10 Version 1.8 | 2020-02-28 Forward Voltage K2 GW CSHPM1.EM   Relative Spectral Emission 6) Irel = f (λ); IF = 350 mA; TJ = 85 °C Φrel GW CSHPM1.EM 1,0 : Vλ : white 0,8 0,6 0,4 0,2 0,0 350 400 450 500 550 600 650 700 750 800 λ [nm] Radiation Characteristics 6) Irel = f (ϕ); TJ = 85 °C GW CSHPM1.EM ϕ [°]  -40° -50° -20° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° 1,0 -30° 0,8 0,6 -60° -70° -80° -90°  -100° 11 Version 1.8 | 2020-02-28 0,4 0,2 0,0 Irel GW CSHPM1.EM   Forward current Relative Luminous Flux 6), 7) IF = f(VF); TJ = 85 °C Φv/Φv(350 mA) = f(IF); TJ = 85 °C Chromaticity Coordinate Shift ΔCx, ΔCy = f(IF); TJ = 85 °C   12 Version 1.8 | 2020-02-28 6) 6), 7) GW CSHPM1.EM   Forward Voltage Relative Luminous Flux 6) ΔVF = VF - VF(85 °C) = f(Tj); IF = 350 mA ∆VF [V] Φv/Φv(85 °C) = f(Tj); IF = 350 mA GW CSHPM1.EM 0,3 Φv GW CSHPM1.EM 1,2 Φv(85°C) 0,2 1,0 0,1 0,8 0,0 0,6 -0,1 0,4 -0,2 0,2 -0,3 -40 -20 0 20 40 60 80 100 120 Tj [°C] Chromaticity Coordinate Shift 6) ΔCx, ΔCy = f(Tj); IF = 350 mA ∆Cx ∆Cy 6) GW CSHPM1.EM 0,03 : Cx - white : Cy - white  0,02 0,01 0,00 -0,01 -0,02 -0,03 -40 -20 0 20 40 60 80 100 120  Tj [°C] 13 Version 1.8 | 2020-02-28 0,0 -40 -20 0 20 40 60 80 100 120 Tj [°C] GW CSHPM1.EM   Max. Permissible Forward Current IF = f(T) IF [mA] GW CSHPM1.EM 1400 1300 1200 1100 1000 900 800 700 600 500 400 300 200 100 0 Do not use below 100 mA 0 20 40 60 80 100 120 Ts [°C]   14 Version 1.8 | 2020-02-28 GW CSHPM1.EM   Dimensional Drawing 8) Further Information: Approximate Weight: 25.0 mg ESD advice: The device is protected by ESD device which is connected in parallel to the Chip.   15 Version 1.8 | 2020-02-28 GW CSHPM1.EM   Recommended Solder Pad IRRWSULQW 8) &XDUHD VROGHUUHVLVW VROGHUVWHQFLO For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Further information can be found in our Application Note: “Handling and Processing Details for Ceramic LEDs”.   16 Version 1.8 | 2020-02-28 GW CSHPM1.EM   Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP  All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 17 Version 1.8 | 2020-02-28 °C 480 s K/s s GW CSHPM1.EM   Taping 8)   18 Version 1.8 | 2020-02-28 GW CSHPM1.EM   Tape and Reel 9) Reel Dimensions A 180 mm W Nmin 12 + 0.3 / - 0.1 mm   19 Version 1.8 | 2020-02-28 W1 60 mm W2 max 12.4 + 2 mm 18.4 mm Pieces per PU 600 GW CSHPM1.EM   Barcode-Product-Label (BPL) Dry Packing Process and Materials 8) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 20 Version 1.8 | 2020-02-28 GW CSHPM1.EM   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet falls into the class moderate risk (exposure time 0.25 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. This device is designed for specific/recommended applications only. Please consult OSRAM Opto Semiconductors Sales Staff in advance for detailed information on other non-recommended applications (e.g. automotive). Change management for this component is aligned with the requirements of the lighting market. For further application related information please visit www.osram-os.com/appnotes   21 Version 1.8 | 2020-02-28 GW CSHPM1.EM   Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on the OSRAM OS website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. OSRAM OS products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.   22 Version 1.8 | 2020-02-28 GW CSHPM1.EM   Glossary 1) Brightness: Brightness values are measured during a current pulse of typically 10 ms, with a tolerance of +/- 7%. 2) Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed. 3) Forward Voltage: The Forward voltage is measured during a current pulse duration of typically 1 ms with a tolerance of ± 0.05V . 4) Color reproduction index: Color reproduction index values (CRI-RA) are measured during a current pulse of typically 10 ms and with a tolerance of ±2. 5) Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of typically 25 ms, with an internal reproducibility of ±0.005 and an expanded uncertainty of ±0.01 (acc. to GUM with a coverage factor of k = 3). 6) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 7) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit. 8) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 9) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   23 Version 1.8 | 2020-02-28 GW CSHPM1.EM   Revision History Version Date Change 1.8 2020-02-28 Schematic Transportation Box Dimensions of Transportation Box   24 Version 1.8 | 2020-02-28 GW CSHPM1.EM     Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 25 Version 1.8 | 2020-02-28
GW CSHPM1.EM-LQLS-XX53-1-350-R18 价格&库存
很抱歉,暂时无法提供与“GW CSHPM1.EM-LQLS-XX53-1-350-R18”相匹配的价格&库存,您可以联系我们找货
  • 1+13.389401+1.73770
  • 10+9.4961410+1.23243
  • 100+7.13846100+0.92644
库存:1455
  • 1+14.443931+1.87456
  • 10+9.1520810+1.18778
  • 100+6.45312100+0.83750
库存:1455
  • 600+6.00041600+0.77875
  • 1200+5.674121200+0.73640
库存:1455
