DDE184
DDE184
    AMSOSRAM(艾迈斯半导体)
    Module
    OSRAM - DDE184 - LAMP, DULUX, DE, HF, CW, 18W
DDE184 数据手册
Product datasheet DULUX D/E 18 W/840 OSRAM DULUX D/E | CFLni, 2 tubes, with 4-pin base for ECG operation Areas of application Offices, public buildings Shops Supermarkets and department stores Hotels, restaurants Industry __ Product benefits Extremly economical Good quality of light Excellent luminous flux Long service life Improved maintenance OSRAM System+ Guarantee in combination with OSRAM QUICKTRONIC ECG Product features Average life: 20,000 h (with QUICKTRONIC) Color rendering index R : 80…89 a Dimmable (3…100 %) Short and compact pin-base lamp with double-turn tubes Single-ended four-pin plug-in G24q base Operates on battery, solar and AC power with suitable electronic control gear August 25, 2014, 17:40:42 DULUX D/E 18 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 1 of 7 Product datasheet Technical data Electrical data Nominal wattage 18.00 W Rated wattage 18.00 W Rated lamp efficacy (HF data 25 °C) Under clarification by authority and standardization body Energy consumption 20 kWh/1000h Photometrical data __ Nominal luminous flux 1200 lm Rated luminous flux 1200 lm Color temperature 4000 K Light color 840 Light color as per EN 12464-1 LUMILUX Cool White Color rendering index Ra 80…89 Luminous flux at 25 °C 1200 lm Rated LLMF at 4,000 h 0.84 Rated LLMF at 6,000 h 0.82 Rated LLMF at 8,000 h 0.81 Rated LLMF at 12,000 h 0.79 Rated LLMF at 16,000 h 0.78 Rated LLMF at 20,000 h 0.76 Luminance 4.5 cd/cm² Color rendering group 1B Dimensions & weight August 25, 2014, 17:40:42 DULUX D/E 18 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 2 of 7 Product datasheet Product line drawing __ Base Overall length 146.0 mm Product weight 44.00 g Tube diameter 12 mm Length 146.0 mm Length acc. to IEC standard 140 mm Length with base excl. base pins/connection 130.00 mm Colors & materials Lamp mercury content 1.9 mg Temperatures Rated ambient temp.w.max.luminous flux 25.0 °C Lifespan Nominal lamp life time 20000 h Rated lamp life time 20000 h Service life 13000 h 1) Rated lamp survival factor at 2,000 h 0.99 Rated lamp survival factor at 4,000 h 0.99 Rated lamp survival factor at 6,000 h 0.99 Rated lamp survival factor at 8,000 h 0.98 Rated lamp survival factor at 12,000 h 0.95 Rated lamp survival factor at 16,000 h 0.81 Rated lamp survival factor at 20,000 h 0.50 Operation mode LLMF/LSF HF Lifespan 20000 h 1) August 25, 2014, 17:40:42 DULUX D/E 18 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 3 of 7 Product datasheet 1) With preheat ECG Additional product data __ Spectral power distribution Base (standard designation) G24q-2 Appropriate disposal acc. to WEEE Yes Capabilities Dimmable Yes Suitable for indoor Yes Certificates & standards Energy efficiency class A Country specific categorizations ILCOS FSQH-18/840-/P/-G24q-2 Country specific information Product code METEL code SEG number STK number UK Org 4050300017617 OSRDDE18840 8330190 4933930 - August 25, 2014, 17:40:42 DULUX D/E 18 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 4 of 7 Product datasheet Lamp-ECG combination (System) Product name Product name ECG DULUX D/E 18W/840 G24Q-2 __ EAN Nominal current Nominal wattage + Power loss Luminous flux at 25 °C Number of lighting outlets DT-T/E 18/230-240 C 0.10 A 20.00 W 1200 lm 1 DT-T/E 18/230-240 L 0.10 A 20.00 W 1200 lm 1 DT-T/E 18/230-240 P 0.10 A 20.00 W 1200 lm 1 QT-ECO 1x18-21/220-240 S 4050300794907 0.14 A 19.00 W 1150 lm 1 QT-ECO T/E 2x18/220-240 4050300803982 0.18 A 36.00 W 2*1150 lm 2 QTP-T/E (1X18), 2X18 4008321537065 0.16 A 36.00 W 2*1200 lm 2 QTP-T/E 1X18, (2X18) 4008321537065 0.09 A 19.00 W 1*1200 lm 1 0.09 A 19.00 W 1200 lm 1 QTP-T/E 1x18 August 25, 2014, 17:40:42 DULUX D/E 18 W/840 QTP-T/E 2x18 4008321181619 0.16 A 38.00 W 2*1200 lm 2 QTi DALI-T/E 1x18-57 DIM 4008321060808 0.09 A 20.00 W 1200 lm 1 QTi DALI-T/E 2x18-42 DIM 4008321060822 0.17 A 38.00 W 2*1200 lm 2 QTi-T/E 1x18-57 DIM 4008321060860 0.09 A 20.00 W 1200 lm 1 QTi-T/E 2x18-42 DIM 4008321060846 0.17 A 38.00 W 2*1200 lm 2 © 2014, OSRAM GmbH. All rights reserved. Page 5 of 7 Product datasheet Guarantee Equipment / Accessories Suitable for operation on electronic control gear Safety advice In case of lamp breakage: www.osram.com/brokenlamp __ Circuit diagram Circuit diagram Logistical Data Product code Product description Packaging unit (Pieces/Unit) Dimensions (height x width x length) 4008321546227 DULUX D/E 18 W/840 Folding carton box 1 - x - x - 4008321546234 DULUX D/E 18 W/840 Shipping carton box 80 4050300017617 DULUX D/E 18 W/840 Folding carton box 1 August 25, 2014, 17:40:42 DULUX D/E 18 W/840 Volume Gross weight 169 mm x 296 mm x 371 mm 18.56 dm³ 4425.00 g 36 mm x 36 mm x 160 mm 0.21 dm³ 54.00 g © 2014, OSRAM GmbH. All rights reserved. Page 6 of 7 Product datasheet 4050300326030 DULUX D/E 18 W/840 Shipping carton box 10 120 mm x 173 mm x 151 mm 3.13 dm³ 615.00 g The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. References / Links For more information on QUICKTRONIC electronic control gear go to www.osram.com/QUICKTRONIC Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. __ August 25, 2014, 17:40:42 DULUX D/E 18 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 7 of 7
DDE184 价格&库存
很抱歉,暂时无法提供与“DDE184”相匹配的价格&库存,您可以联系我们找货
