DL1884
DL1884
    AMSOSRAM(艾迈斯半导体)
    Module
    OSRAM - DL1884 - LAMP, DULUX, L, CW, 18W
DL1884 数据手册
Product datasheet DULUX L 18 W/840 2G11 OSRAM DULUX L LUMILUX | CFLni, with 4-pin 2G11 base for ECG/CCG operation Areas of application Offices, public buildings Shops Supermarkets and department stores Hotels, restaurants Industry __ Product benefits Very economical Outstanding luminous flux Outstanding luminous efficiency Long service life OSRAM System+ Guarantee in combination with OSRAM QUICKTRONIC ECG Less than half as long as tubular fluorescent lamps Improved maintenance Product features Short and compact pin-base lamp with double-turn tubes Single-ended four-pin plug-in 2G11 base Dimmable (1…100 % with QUICKTRONIC QTi DALI/DIM) Color rendering index R : 80…89 a Average life: 20,000 h (with QUICKTRONIC) Operates on battery, solar and AC power with suitable electronic control gear Also available in blue August 25, 2014, 12:57:04 DULUX L 18 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 1 of 7 Product datasheet Technical data Electrical data Nominal wattage 18.00 W Rated wattage 18.00 W Energy consumption 20 kWh/1000h Photometrical data __ Nominal luminous flux 1200 lm Rated luminous flux 1200 lm Color temperature 4000 K Light color 840 Light color as per EN 12464-1 LUMILUX Cool White Color rendering index Ra 80…89 Luminous flux at 25 °C 1200 lm Rated LLMF at 4,000 h 0.90 Rated LLMF at 6,000 h 0.88 Rated LLMF at 8,000 h 0.86 Rated LLMF at 12,000 h 0.84 Rated LLMF at 16,000 h 0.81 Rated LLMF at 20,000 h 0.80 Luminance 2.1 cd/cm² Color rendering group 1B Dimensions & weight Product line drawing Overall length August 25, 2014, 12:57:04 DULUX L 18 W/840 2G11 Base 217.0 mm © 2014, OSRAM GmbH. All rights reserved. Page 2 of 7 Product datasheet Product weight 55.00 g Tube diameter 17.5 mm Length 217.0 mm Length acc. to IEC standard 225 mm Length with base excl. base pins/connection 217.00 mm Colors & materials Lamp mercury content 1.7 mg Temperatures Rated ambient temp.w.max.luminous flux 25.0 °C Lifespan __ Nominal lamp life time 20000 h Rated lamp life time 20000 h Service life 13000 h 1) Rated lamp survival factor at 2,000 h 0.99 Rated lamp survival factor at 4,000 h 0.99 Rated lamp survival factor at 6,000 h 0.99 Rated lamp survival factor at 8,000 h 0.99 Rated lamp survival factor at 12,000 h 0.95 Rated lamp survival factor at 16,000 h 0.81 Rated lamp survival factor at 20,000 h 0.50 Operation mode LLMF/LSF HF Lifespan 20000 h 1) 1) With preheat ECG Additional product data August 25, 2014, 12:57:04 DULUX L 18 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 3 of 7 Product datasheet Spectral power distribution __ Base (standard designation) 2G11 Appropriate disposal acc. to WEEE Yes Footnote only for product For ECG and CCG operation Capabilities Suitable for indoor Yes Certificates & standards Energy efficiency class A Country specific categorizations ILCOS FSD-18/840-E-2G11-43,9/217 Country specific information Product code METEL code SEG number STK number UK Org 4050300010724 OSRDL18840 8330444 4933880 - August 25, 2014, 12:57:04 DULUX L 18 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 4 of 7 Product datasheet Lamp-ECG combination (System) Product name Product name ECG EAN Nominal current Nominal wattage + Power loss Luminous flux at 35 °C Number of lighting outlets DULUX L 18W/840 2G11 QT 1x18 DIM 4008321645647 0.08 A 18.90 W 1350 lm 1 QT 2x18 DIM 4008321645852 0.17 A 37.70 W 1350 lm 2 QT-ECO 1x18-24/220-240 L 4050300660417 0.13 A 18.00 W 1200 lm 1 QT-ECO 1x18-24/220-240 S 4050300638560 0.13 A 18.00 W 1200 lm 1 QTP-DL 1x18-24 4008321117861 0.085 A 18.00 W 1200 lm 1 QTP-DL 2x18-24 4008321117885 0.16 A 36.00 W 1200 lm 2 QTP-M 1x26-42 4008321329134 0.09 A 18.00 W 1150 lm 1 QTP-M 2x26-32 4008321329158 0.16 A 36.00 W 1150 lm 2 QTP-OPTIMAL 1x18-40 4008321873743 0.09 A 19.00 W 1150 lm 1 QTP-OPTIMAL 2x18-40 4008321873767 0.16 A 36.00 W 1150 lm 2 QTi 1x18 DIM 4050300870601 0.08 A 19.00 W 1200 lm 1 QTi 2x18 DIM 4050300870960 0.16 A 37.00 W 1200 lm 2 QTi 3x18 DIM 4008321069931 0.24 A 53.60 W 1200 lm 3 QTi 4x18 DIM 4008321070012 0.31 A 69.30 W 1200 lm 4 QTi DALI 1x18 DIM 4050300870403 0.08 A 18.00 W 1200 lm 1 QTi DALI 2x18 DIM 4050300870526 0.16 A 37.00 W 1200 lm 2 QTi DALI 3x18 DIM 4008321069979 0.24 A 53.60 W 1200 lm 3 QTi DALI 4x18 DIM 4008321070050 0.31 A 69.30 W 1200 lm 4 __ August 25, 2014, 12:57:04 DULUX L 18 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 5 of 7 Product datasheet Guarantee Equipment / Accessories Suitable for standard control gears and starters Suitable for operation on electronic and conventional control gear __ Circuit diagram Circuit diagram Circuit diagram Circuit diagram August 25, 2014, 12:57:04 DULUX L 18 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 6 of 7 Product datasheet Logistical Data Product code Product description Packaging unit (Pieces/Unit) Dimensions (height x width x length) Volume Gross weight 4050300010724 DULUX L 18 W/840 2G11 Folding carton box 1 46 mm x 27 mm x 246 mm 0.31 dm³ 67.67 g 4050300242125 DULUX L 18 W/840 2G11 Shipping carton box 10 136 mm x 103 mm x 260 mm 3.64 dm³ 903.00 g The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. References / Links For more information on QUICKTRONIC electronic control gear go to www.osram.com/QUICKTRONIC For more information on the system guarantee and the terms and conditions of the guarantee visit www.osram.com/system-guarantee Disclaimer __ Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. August 25, 2014, 12:57:04 DULUX L 18 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 7 of 7
DL1884 价格&库存
很抱歉,暂时无法提供与“DL1884”相匹配的价格&库存,您可以联系我们找货
