Product datasheet
DULUX S 7 W/840
OSRAM DULUX S | Short CFLni, with 2-pin base for CCG operation
Areas of application
Ideal for cost-effective creative illumination and
decoration
Offices, public buildings
Shops
Supermarkets and department stores
Hotels, restaurants
__
Product benefits
Extremly economical
Good quality of light
Extremely low profile
Long service life
Improved maintenance
Product features
Average life: 10,000 h
Color rendering index R for lamps with white light: 80…89
a
Also available in red, green and blue
Short and compact pin-base lamps with single-turn tubes
Single-ended two-pin plug-in G23 base
August 25, 2014, 16:43:43
DULUX S 7 W/840
© 2014, OSRAM GmbH. All rights reserved.
Page 1 of 6
Product datasheet
Technical data
Electrical data
Nominal wattage
7.10 W
Rated wattage
7.10 W
Energy consumption
10 kWh/1000h
Photometrical data
__
Nominal luminous flux
400 lm
Rated luminous flux
402 lm
Color temperature
4000 K
Light color
840
Light color as per EN 12464-1
LUMILUX Cool White
Color rendering index Ra
80…89
Luminous flux at 25 °C
400 lm
Rated LLMF at 4,000 h
0.78
Rated LLMF at 6,000 h
0.76
Rated LLMF at 8,000 h
0.75
Luminance
2.6 cd/cm²
Color rendering group
1B
Dimensions & weight
Product line drawing
Base
Overall length
137.0 mm
Product weight
25.00 g
Tube diameter
12 mm
Length
137.0 mm
DULUX S 7 W/840
Page 2 of 6
Product datasheet
Length acc. to IEC standard
115 mm
Length with base excl. base pins/connection
114.00 mm
Colors & materials
Lamp mercury content
1.4 mg
Temperatures
Rated ambient temp.w.max.luminous flux
25.0 °C
Lifespan
__
Nominal lamp life time
8000 h
Rated lamp life time
8000 h
Service life
6500 h
Rated lamp survival factor at 2,000 h
0.98
Rated lamp survival factor at 4,000 h
0.98
Rated lamp survival factor at 6,000 h
0.86
Rated lamp survival factor at 8,000 h
0.50
Operation mode LLMF/LSF
50 Hz
Lifespan
10000 h 1)
1) With CCG/LLCG
Additional product data
DULUX S 7 W/840
Page 3 of 6
Product datasheet
Spectral power distribution
__
Base (standard designation)
G23
Appropriate disposal acc. to WEEE
Yes
Capabilities
Suitable for indoor
Yes
Certificates & standards
Energy efficiency class
B
Country specific categorizations
ILCOS
FSD-7/840-I-G23
Country specific information
Product code
METEL code
SEG number
STK number
UK Org
4050300010571
OSRDS7840
8330012
4933848
DULUX S 7 W/840
Page 4 of 6
Product datasheet
Guarantee
Equipment / Accessories
Suitable for operation on conventional control gear
__
Circuit diagram
Circuit diagram
Circuit diagram
Logistical Data
Product code
Product description
Packaging unit
(Pieces/Unit)
Dimensions (height x
width x length)
Volume
Gross weight
4050300010571
DULUX S 7 W/840
Folding carton box
1
36 mm x 23 mm x
139 mm
0.12 dm³
31.00 g
4050300240886
DULUX S 7 W/840
Shipping carton box
10
82 mm x 140 mm x
135 mm
1.55 dm³
347.00 g
4052899213333
DULUX S 7 W/840
Folding carton box
1
- x - x -
4052899213340
DULUX S 7 W/840
Shipping carton box
50
153 mm x 190 mm x
240 mm
6.98 dm³
1987.00 g
The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or
more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit.
DULUX S 7 W/840
Page 5 of 6
Product datasheet
Disclaimer
Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release.
__
DULUX S 7 W/840
Page 6 of 6
很抱歉,暂时无法提供与“DS7840”相匹配的价格&库存,您可以联系我们找货
