HALHYDROKITRBRNI35
HALHYDROKITRBRNI35
    AMSOSRAM(艾迈斯半导体)
    OSRAM - HALHYDROKITRBRNI35 - DOWNLIGHT KIT,35W,GU5.3,NICKEL,IP24
HALHYDROKITRBRNI35 数据手册
Kit Halo Pro Hydro LUM – Technical Information A recessed spot for orientate illumination. Tender text • Professional solution, ready to install, kit version (all components inside the packaging) • Interior illuminating with comfortable atmosphere. For bathroom lighting, showers, humidity areas, kitchens, locker rooms, gymnasiums… • False ceiling integration, safety class 3, IP24, IK02 • Mains voltage 230/240V, mains frequency 50–60Hz • Equipped with Halogen DECOSTAR® DR51 Energy Saver, 35W 12V, color temperature 3100 K, lifetime 5000 h • Equipped with electronic control gear dimmable: Trailing edge phase control. Table of contents: Tender text..................................................................................................... 1 A) Technical Information .............................................................................. 2 1) Housing, Mounting and Accessories .......................................................................2 2) Electrical Installation .................................................................................................3 3) Optical features ..........................................................................................................4 4) Control ........................................................................................................................5 B) Logistic Data............................................................................................. 5 LUM – Technical Information Subject to modification Kit Halo Pro Hydro Status as of 06.08.2009 Page 1 / 5 Kit Halo Pro Hydro A) Technical Information 1) Housing, Mounting and Accessories Body material Color of the luminaire (RAL) Form Kit Halo Pro Hydro S 3x35W Brushed Nickel Die casted aluminum White RAL 9016 Brushed Nickel White RAL 9016 Round Glass cover Reflector type Reflector included into the lamp Fixing of the lamp Twist & lock system Adjustable Number of lighting outlets Diameter [mm] Yes 1 3 Brushed Nickel Square Cover material 1 3 1 3 1 3 91 91 x 91 (square) Length x width [mm] LUM – Technical Information Subject to modification Recessed, with 2 spring clips on the false ceiling 80 Min. 150 into the false ceiling 250 250 250 250 GU5.3 square 3xlamps GU5.3 round 3xlamps GU5.3 square 1xlamp Type of installation Mounting diameter [mm] Mounting height [mm] Net weight (with lamp, ECG and cables) [g] GU5.3 round 1xlamp Kit Halo Pro Hydro S 1x35W Brushed Nickel Kit Halo Pro Hydro S 3x35W White Kit Halo Pro Hydro S 1x35W White Product name Kit Halo Pro Hydro R 3x35W Brushed Nickel IP24, for humidity area Kit Halo Pro Hydro R 1x35W Brushed Nickel • Kit Halo Pro Hydro R 3x35W White Lamp is fixed into the spot with a twist & lock system, very easy installation and maintenance Kit Halo Pro Hydro R 1x35W White • Kit Halo Pro Hydro Status as of 06.08.2009 Page 2 / 5 Kit Halo Pro Hydro S 3x35W White Kit Halo Pro Hydro S 1x35W Brushed Nickel Kit Halo Pro Hydro S 3x35W Brushed Nickel Kit Halo Pro Hydro S 1x35W White Kit Halo Pro Hydro S 3x35W White Kit Halo Pro Hydro S 1x35W Brushed Nickel Kit Halo Pro Hydro S 3x35W Brushed Nickel 35 105 35 105 35 105 35 105 Kit Halo Pro Hydro S 1x35W White Kit Halo Pro Hydro R 3x35W Brushed Nickel Kit Halo Pro Hydro R 3x35W Brushed Nickel Kit Halo Pro Hydro R 1x35W Brushed Nickel Kit Halo Pro Hydro R 1x35W Brushed Nickel Kit Halo Pro Hydro R 3x35W White Kit Halo Pro Hydro R 3x35W White Kit Halo Pro Hydro R 1x35W White Product name Kit Halo Pro Hydro R 1x35W White Kit Halo Pro Hydro III Protection class Type of protection (IP code) Protection against ignition and fire Glow Wire Test according to IEC 6952-1 (> 650°C) Shock resistance (IK code) Approval marks Photometric Classification DIN 5040 IP24 F 960 °C IK02 CE – SEMCO - EMC See “Optical features” Kit Halo Pro Hydro can be mounted in volume 1 2) Electrical Installation Product name Nominal wattage [W] 220 to 240 Mains voltage [V] Rated current [A] 0,24 0,24 LUM – Technical Information Subject to modification 0,24 50 / 60 Mains frequency [Hz] Type of connector 0,24 Into the ECG, 2 screws binders connector Kit Halo Pro Hydro Status as of 06.08.2009 Page 3 / 5 Kit Halo Pro Hydro Kit Halo Pro Hydro S 3x35W White Kit Halo Pro Hydro S 1x35W Brushed Nickel Kit Halo Pro Hydro S 3x35W Brushed Nickel 1 3 1 3 Yes Equipped with Lamp 1 Number of lamp Kit Halo Pro Hydro S 1x35W White Kit Halo Pro Hydro R 3x35W Brushed Nickel Kit Halo Pro Hydro R 1x35W Brushed Nickel Product name Kit Halo Pro Hydro R 3x35W White Kit Halo Pro Hydro R 1x35W White 3) Optical features 3 1 3 OSRAM DR 51 ES 35W 12V (48865 ES WFL) Lamp type EAN 4050300 516639 Base GU5.3 Lifespan lamp 5 000 h Beam angle [°] 36 3 100 Color temperature [K] Luminous intensity [cd] 2 200 2300 8500 lx Ø 0,35 m 0,5 m 1840 2200 lx Ø 0,70 m 1,0 m 1380 550 lx 920 Ø 1,40 m 2,0 m 460 240 lx Ø 2,10 m 3,0 m cd 0 –90° –60° –30° LUM – Technical Information Subject to modification 0° 30° 60° 90° Kit Halo Pro Hydro –90° –70° –50° –30° –10° 10° 30° 50° 70° 90° Status as of 06.08.2009 Page 4 / 5 Kit Halo Pro Hydro 4) Control Kit Halo Pro Hydro S 3x35W Brushed Nickel Kit Halo Pro Hydro S 1x35W Brushed Nickel Kit Halo Pro Hydro S 3x35W White Kit Halo Pro Hydro S 1x35W White Kit Halo Pro Hydro R 3x35W Brushed Nickel Kit Halo Pro Hydro R 1x35W Brushed Nickel Product name Kit Halo Pro Hydro R 3x35W White Electronic control gear Kit Halo Pro Hydro R 1x35W White • Electronic control gear for 12V lamps Ballast / Control gear Permissible sinusoidal operating voltage [VAC] Mains frequency [Hz] 220 to 240 50 / 60 Secondary voltage 11,5V 11,5V 11,5V 11,5V Wattage range [W] 20 - 60 20 - 60 20 - 60 20 - 60 Dimmable [Yes/No] Trailing edge phase control No Through-wiring ECG certification EMC – CE - SEMCO B) Logistic Data Product name Product number Lamp base Color temperature SU Kit Halo Pro Hydro R 1x35W White 4008321 399045 GU5.3 3100 K 6x1 Kit Halo Pro Hydro R 3x35W White 4008321 445636 GU5.3 3100 K 4x1 4008321 399069 GU5.3 3100 K 6x1 4008321 445650 GU5.3 3100 K 4x1 Kit Halo Pro Hydro S 1x35W White 4008321 399083 GU5.3 3100 K 6x1 Kit Halo Pro Hydro S 3x35W White 4008321 445674 GU5.3 3100 K 4x1 Kit Halo Pro Hydro S 1x35W Brushed Nickel 4008321 399106 GU5.3 3100 K 6x1 Kit Halo Pro Hydro S 3x35W Brushed Nickel 4008321 445698 GU5.3 3100 K 4x1 Kit Halo Pro Hydro R 1x35W Brushed Nickel Kit Halo Pro Hydro R 3x35W Brushed Nickel • Content : spot + lamp + ECG + fixing system + lamp holder & wiring + user manual LUM – Technical Information Subject to modification Kit Halo Pro Hydro Status as of 06.08.2009 Page 5 / 5
HALHYDROKITRBRNI35 价格&库存
很抱歉,暂时无法提供与“HALHYDROKITRBRNI35”相匹配的价格&库存,您可以联系我们找货
