AM-510
AM-510
    AMPROBE(安博)
    AM-510
AM-510 数据手册
www.Amprobe.com AM-500 DIY-PRO Digital Multimeter AM-500 Digital Multimeter Series Easy to use digital multimeter designed for the homeowner or office space maintenance person to check for voltage in receptacles, extension cords, light fixtures, batteries and other electrical circuits. Check fuses, light bulbs and continuity of the electrical connections. Verify voltage level of the automotive batteries and troubleshoot electrical problems of the cars. • Measurements: Voltage up to 600V AC/DC, AC/DC Current and Resistance • Low battery warning • Safety: CAT III 600V • Audible continuity • Diode Test • Data hold • Auto power off AM-500 Detailed Specifications Specifications Range Accuracy AC Voltage 2.000 / 20.00 / 200.0 / 600 V ±(1.0% Rdg + 3 LSD) @ 45 Hz to 400 Hz, 2 V to 200 V ranges DC Voltage 200 mV 2.000 / 20.00 / 200.0 / 600 V ±(0.8% Rdg + 1 LSD) @ 2 V to 200 V ranges Resistance 200.0 Ohms 2.000 / 20.00 / 200.0 kOhms 2.000 / 20.00 MOhms ±(1.0% Rdg + 2 LSD) @ 2 kOhms to 200 kOhms ranges AC Current 200.0 / 2000 µA 20.00 / 200.0 mA 2.000 / 10.00 A ±(1.2% Rdg + 2 LSD) DC Current 200.0 / 2000 µA 20.00 / 200.0 mA 2.000 / 10.00 A ±(1.0% Rdg + 2 LSD) Battery Test 1.5 V, 9 V ±(1.0% Rdg + 3 LSD) For current range from 8-10A, do not measure current for more than one (1) minute. Wait for 10 minutes before taking another measurement. For more detailed specifications see instruction manual. ©2012 Amprobe Test Tools. All rights reserved. For detailed specifications and ordering info go to www.amprobe.com 4105653 B www.Amprobe.com AM-500 series selection guide Multimeter Type AM-500 AM-510 AM-520 AM-530 AM-560 AM-570 Autoranging Com / Res HVAC Electrical Adv. HVAC Industrial CAT III 600V CAT III 600V CAT III 600V CAT III 600V CAT IV 600V CAT III 1000V CAT IV 600V CAT III 1000V Events Display Features Functions Application: Safety Rating Safety Measure voltage in noisy environments True-rms Electrical panels, AC outlets AC Voltage (V) 600 600 600 600 1000 1000 DC systems, auto/marine batteries DC Voltage (V) 600 600 600 600 1000 1000 AC Current - electrical panels, appliances AC Current (A) 10 10 10 10 10 10 DC Current - electronics, DC motors DC Current (A) 10 10 10 10 10 10 Specified resistance and continuity Resistance (MOhms) 20 40 40 40 60 60 Flame sensors Micro Amps ■ ■ ■ ■ ■ ■ Diodes in ac to dc converters Diode test ■ ■ ■ ■ ■ ■ Fuses, light bulbs, wire connections Continuity ■ ■ ■ ■ ■ ■ Household batteries Battery test ■ ■ ■ ■ Motor startup or run capacitors Capacitance ■ ■ ■ ■ ■ Frequency verification Frequency ■ ■ ■ ■ ■ VolTectTM Non-contact voltage detection Non-contact voltage ■ ■ ■ ■ ■ Electrical load-time on vs. time off Duty cycle ■ ■ ■ Temp of air vents, fuses, transformers Temperature inputs Automatically selects measurement range Autoranging Manually select measurement range Manual ranging Voltage on variable frequency drives Low pass filter Detect stray voltages Low Z Dimly lit areas Built-in flashlight ■ 1 1 2 2 ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ Meter resolution LCD Counts Dimly lit areas Backlight Monitoring fast changing signals Bar graph Two relative measurements on one screen Dual display 2,000 ■ Data memory Data hold Difference between two measurements Relative reading Max/min peak measurement Max/min hold Specialized signal measurements Peak hold (crest) ■ ■ ■ ■ ■ 4,000 4,000 4,000 6,000 6,000 ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ Included Accessories Batteries (Installed) Test Leads AM-500 AAA x2 ■ AM-510 9V (6F22) x1 ■ AM-520 9V (6F22) x1 ■ K-type probe x1 ■ ■ ■ AM-530 9V (6F22) x1 ■ K-type probe x1 ■ ■ ■ AM-540 9V (6F22) x1 ■ K-type probe x2 ■ ■ ■ ■ AM-550 9V (6F22) x1 ■ K-type probe x2 ■ ■ ■ ■ Amprobe® info@amprobe.com Everett, WA 98203 Tel: 877-AMPROBE (267-7623) ©2012 Amprobe Test Tools. All rights reserved. Temperature Probe Temperature Adaptor Model Velcro Strap Carrying Case User’s Manual ■ ■ Amprobe® Europe In den Engematten 14, 79286 Glottertal, Germany Tel.: +49 (0) 7684 8009 - 0 For detailed specifications and ordering info go to www.amprobe.com 4105653 B
AM-510
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一款高速光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,包括输入、输出和电源引脚。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号隔离,适用于高速数字信号传输。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装。
AM-510 价格&库存
很抱歉,暂时无法提供与“AM-510”相匹配的价格&库存,您可以联系我们找货
