ACD-14-PRO
ACD-14-PRO
    AMPROBE(安博)
    1XMULTIMETER,1XTESTLEADS,1X
ACD-14-PRO 数据手册
www.Amprobe.com ACD-14-PRO Dual Display 600 A TRMS Clamp Multimeter Test Voltage and Amperage Simultaneously The ACD-14-PRO offers a complete range of measuring functions for both HVAC and electrical applications. This modern clamp meter features a large backlit LCD dual display and is capable of simultaneously displaying voltage and amps. The ACD-14-PRO is packed with features including TRMS, low pass filter, in-rush current, frequency, resistance, capacitance, temperature, DC micro-amps, Amp-Tip and non-contact voltage detection. The Amp-Tip function allows for precise measurement of current down to the tenth of an amp for reliable, accurate current measurement of both large and small diameter wires. The low pass filter allows measurement of current and voltage on variable frequency drives (motors with speed controlled by frequency). The meter features a rubber overmold enclosure that provides extra durability and is safety rated to CAT III 600 V. Non-Contact Voltage Detection (NCV) ACD-14-PRO Features Amp-Tip function for precise Low Current Measurement • Large LCD with dual display that can display voltage and amps concurrently • True-RMS for accurate voltage measurements in noisy environments • Low pass filter for current and voltage measurements on variable frequency drives Rotary Switch for one-hand operation • Amp-Tip function for precise low current measurement down to 0.1 amp • HVAC applications with temperature, DC micro-amps and capacitance • In-rush current Large LCD Dual Display with Backlight TRMS Function provides accurate measurements Upper Display: Reading for AC current • Temperature • Non-contact voltage detection (NCV) Lower Display: Reading for V, Hz, Ω, μF and μA and Temperature • Audible continuity and diode test • Data hold • Auto ranging • Auto power off Rubber Overmold for extra durability Data Hold Button Built-in low pass filter • Low battery indicator • Safety rated CAT III 600 V Input Terminals ACD-14-PRO Dual Display 600 A TRMS Clamp Multimeter Amprobe® | info@amprobe.com | Fluke Corporation, Everett, WA 98203 | Tel: 877-AMPROBE (267-7623) ©2015 Amprobe® For detailed specifications and ordering go to www.Amprobe.com 6006537 A www.Amprobe.com ACD-14-PRO Key Applications The Amprobe ACD-14-PRO features low profile jaws to test in tight spaces with TRMS for accurate measurements. The Amprobe ACD-14-PRO can test and display voltage and current measurements simultaneously with the large backlit LCD dual display, for voltage drop tests and other applications. Voltage drop test - dual display allows user to view voltage and current simultaneously to assess voltage drop for current changing from zero to a maximum value. Voltage drop test is required by National Electrical Code (NEC) to ensure normal operation and efficiency. It defines the maximum percentage of the voltage drop between maximum voltage at zero current and minimum voltage at maximum current. This assures that electrical equipment and motors are working within specified voltage to avoid potential damage to electrical components. Functions for core HVAC applications: Temperature measurement (with included thermocouple), capacitance for start-up and run capacitors, and DC micro-amps for flame sensors testing. Accurate measurement of current, voltage and frequency on all electrical systems including distorted, nonsinusoidal signals (True-RMS function). Amp-Tip is a small wire guide that is built into the tip of the main clamp meter jaws. It allows for precise measurement of low-current down to the tenth of an amp on small diameter wires, to provide reliable, accurate measurements. Testing variable frequency drives with low pass filter. Variable frequency drives are energy efficient motors where speed is controlled by frequency. These motor drives generate high frequency noise, which may cause standard meters to provide erroneous readings when measuring voltage and current. The low pass filter will remove this noise and provide accurate measurements. Capacitance measurement for start and run motor capacitors. Resistance and continuity functions to verify quality of electrical connections and to check if motor and transformer coils are working properly. In-rush current measurement to verify maximum current surge during motor start-up. Too high of in-rush current can cause gradual damage of components and may cause fuses or circuit breakers to trip. DC micro-amps output for measurement of flame sensors. Test the proper operation of the flame sensor safety system in gas appliances. A broken sensor in a gas appliance will prevent the safety valve from opening and the appliance will not work. All Amprobe tools, including the Amprobe ACD-14-PRO, are rigorously tested for safety, accuracy, reliability, and ruggedness in our state-of-the-art test lab. In addition, Amprobe products that measure electricity are listed by a 3rd party safety lab, either UL or CSA. This system assures that Amprobe products meet or exceed safety regulations and will perform in a tough, professional environment for many years to come. Amprobe® | info@amprobe.com | Fluke Corporation, Everett, WA 98203 | Tel: 877-AMPROBE (267-7623) ©2015 Amprobe® For detailed specifications and ordering go to www.Amprobe.com 6006537 A www.Amprobe.com ACD-14-PRO Dual Display Detailed Specifications Features ACD-14-PRO 600 A TRMS Clamp Multimeter CAT III 600 V Safety Rating AC Voltage Range: 0.0 to 600.0 V Accuracy: ±1.0% + 5LSD (50 to 60 Hz) (with Digital Low-Pass Filter and True-RMS) Range: 0.0 to 600.0 V Accuracy: ±1.0% + 5LSD Range: 0.00 to 600.0 A Accuracy: ±1.8% + 5LSD (50 to 60.00 kΩ to 6000 kΩ Accuracy: ±1.2% + 5LSD Capacitance Range: 200.0 µF, 2500 µF Accuracy: ± (2.0 % + 4 LSD) Diode Test Range: 0.0 to 3.000 V Accuracy: ± (1.5 % + 5 LSD) ON ≤ 10 Ω OFF > 250 Ω Continuity Beeper Range: -40.0 to 752 °F, -40.0 to 400 °C Accuracy: ±1.0% + 1.5 °F (-40.0 to 99.9 °F) ±1.0% + 2 °F (100 to 752 °F) ±1.0% + 0.8 °C (-40.0 to 99.9 °C) ±1.0% + 1 °C (100 to 400 °C) Temperature* (Type K thermocouple) *K-type thermocouple accuracy tolerances not included Non-Contact Voltage 10 to 550 V, 50/60 Hz Jaw Opening Dual Display True-RMS Low Pass Filter Autoranging Inrush Current Data Hold 1.18 in (30 mm) • • • • • • Backlight • Auto Power Off • Low Battery Indication • General Specifications Polarity Automatic Update Rate 5 per second nominal Operating Temperature 32 to 104 °F (0 to 40 °C) Relative Humidity 80 %RH up to 88 °F (31 °C) decreasing linearly to 50 %RH at 104 °F (40 °C) Operating Altitude 6,562 ft (0 to 2000 m) Pollution Degree 2 Storage Temperature Temperature Coefficient -4 °F to 140 °F (-20 °C to 60 °C), < 80 % RH Nominal 0.15 x (specified accuracy)/ °C @ (0 °C to 18 °C or 28 °C to 40 °C) Battery Two AAA 1.5 V battery EMC Safety Compliance Meets EN 61326-1 UL/IEC/EN 61010-1 ed. 3.0, UL/IEC/EN 61010-2-033 ed. 1.0, CAN/CSA C22.2 NO. 61010-1 ed. 3.0, UL/IEC/EN 61010-2-032 ed. 3.0 & IEC/EN 61010-031 ed. 1.1 Certification Dimensions (L x W x H): Weight: 8.62 x 3.03 x 1.46 in (219 x 77 x 37 mm) approx. 0.46 lb (208 g) Accessories included: User manual, Test leads, Carrying case, Batteries AAA (2), Banana plug K-type thermocouple Amprobe® | info@amprobe.com | Fluke Corporation, Everett, WA 98203 | Tel: 877-AMPROBE (267-7623) ©2015 Amprobe® For detailed specifications and ordering go to www.Amprobe.com 6006537 A
ACD-14-PRO 价格&库存
很抱歉,暂时无法提供与“ACD-14-PRO”相匹配的价格&库存,您可以联系我们找货
