CC-7000
CC-7000
    AMPROBE(安博)
    CASE,CARRYING, FOAM INSERT,AT-70
CC-7000 数据手册
AT-7000-R Receiver AT-7000 Advanced Wire Tracer Wire Tracing Reinvented Get accurate results in minutes with new features and technologies that simplify wire tracing and breaker identification. The Receiver’s patented Smart Sensor,™ with its innovative new antenna design and advanced signal processor, clearly displays the location and orientation of energized wires in walls, floors and ceilings on the large color TFT LCD screen. The powerful Transmitter utilizes two optimal frequencies for both energized and de-energized wire and breaker tracing, delivering consistently accurate results for novice users and experts alike. The new Scan and Locate feature clearly identifies the one correct breaker or fuse, eliminating the confusion from multiple false positive readings common in older technology tracing tools. AT-7000-T Transmitter AT-7000 Features •• Traces wires in walls, ceilings, floors and corners Tip Sensor •• Locates breakers and fuses •• Pinpoints shorts and opens •• High resolution 3.5” TFT LCD color display Smart Sensor™ (Back) Large bright TFT LCD full color display Non-Contact Voltage (NCV) Signal sensitivity adjustment (-/+) Enter key for selecting functions 4-way navigation keys •• Three power modes ––”High”power mode for normal circuits ––”Low”power mode for precision tracing in difficult areas ––”Clamp” power mode provides a boosted signal using signal clamp •• Two automatically selected frequency modes for optimal tracing on energized and de-energized circuits • Clamp-on attachment (SC-7000) for inducing signal into wires without access to bare conductors • Embedded help screens make set-up easy and error free Hot Stick attachment adapter (TIC 410A) AT-7000-R Receiver Amprobe® | info@amprobe.com | Fluke Corporation, Everett, WA 98203 | Tel: 877-AMPROBE (267-7623) ©2017 Amprobe® For detailed specifications and ordering go to amprobe.com 6003703 C AT-7000 Features and Functions Tip Sensor Smart Sensor™ Power Mode Buttons (High, Low, Clamp) AT-7000-R Receiver AT-7000-R Receiver Tip Sensor The shape of the tip sensor allows tracing in hard to reach areas, corners & tight spaces, as well as precise circuit breaker and fuse identification. By utilizing two different types of antennas (inductive coil and capacitive), the tip sensor enables optimal tracing results of both energized and de-energized circuits, which are automatically selected by operating mode. AT-7000-T Transmitter Smart Sensor™ Quickly and easily determine the precise direction and location of energized wires in walls, floors and ceilings with the patented Smart Sensor™. Combined with a fast signal processor that measures small changes in the detected signal multiple times per second, this new technology provides unmatched precision and ease of use for tracing energized wires. Signal Clamp SC-7000 Signal Clamp When there’s no access to bare conductors, use the SC-7000 signal clamp to induce a signal into either energized or de-energized circuits for wire tracing and load locating. The AT-7000-T transmitter’s “clamp” mode provides a boosted 6 kHz signal through the clamp to further improve accuracy and performance. AT-7000-T Transmitter Featuring three power modes “high”, “low”, and “clamp” and two output frequencies (6kHz and 33 kHz), the AT-7000-T incorporates the best technologies available for optimal wire tracing and breaker identification on both energized and de-energized circuits. The AT7000-T automatically sets the frequency based on detected voltage, and prompts the user to set the power level based on their application. The color TFT LCD screen displays the detected voltage, frequency output and power mode. The AT-7000 Advanced Wire Tracer is available in two feature-packed kits Features AT-7020 Kit AT-7030 Kit Traces Energized and De-Energized Wires ⚫ ⚫ Locates Energized and De-Energized Breakers ⚫ ⚫ Pinpoints Shorts and Opens Three Power Modes •• ”High” power mode for normal circuits •• ”Low” power mode for precision tracing in difficult areas •• ”Clamp” power mode provides a boosted induction signal via the signal clamp ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ (optional) ⚫ Two Frequency Modes for Optimal Tracing •• 6 kHz for energized circuits •• 33 kHz for de-energized circuits Signal Clamp (SC-7000) •• Clamp-on attachment for inducing signal into wires without access to bare conductors Amprobe® | info@amprobe.com | Fluke Corporation, Everett, WA 98203 | Tel: 877-AMPROBE (267-7623) ©2017 Amprobe® For detailed specifications and ordering go to amprobe.com 6003703 C AT-7000 Features and Functions Quick and Easy Wire Tracing with the Smart Sensor™ Tracing Wires in Walls, Ceilings and Floors Tracing wires can be a challenge. The Amprobe AT-7000 makes tracing energized wires easier and more accurate than ever before. The Smart Sensor’s™ patented sensor array and advanced signal processor provides instant feedback of wire location and direction on the large TFT LCD color display. Easily determine the direction and orientation of wires in walls, floors and ceilings up to 2 in/5 cm accuracy. Energized wire AT-7000-R Receiver Large dynamic TFT LCD color display guides you in the direction and orientation of the energized wire. Display shows when the Smart Sensor™ is centered over the location of the energized wire and indicates its precise direction and orientation. AT-7000-T Transmitter  Grounded Test Lead Clear and Accurate Breaker Identification Identifying breakers and fuses Combined with our powerful transmitter utilizing optimal frequencies for energized and de-energized tracing, the new Scan and Locate feature identifies the one correct breaker or fuse with the highest recorded signal. This eliminates the confusion from multiple false positive readings common in older technology tracing tools. AT-7000-R Receiver The solid green arrow and audible alert indicates the target breaker has been found. AT-7000-T Transmitter Amprobe® | info@amprobe.com | Fluke Corporation, Everett, WA 98203 | Tel: 877-AMPROBE (267-7623) ©2017 Amprobe® For detailed specifications and ordering go to amprobe.com 6003703 C AT-7000 Features and Functions Trace Wires Inside Conduit Trace energized and de-energized wires enclosed in metal conduit by removing the junction box cover and using the AT-7000-R Receiver’s Tip Sensor to identify the specific wire carrying the transmitted signal generated by the AT-7000-T Transmitter. Wires in non-metal conduit can be traced directly without opening the junction box and using the AT-7000-R Receiver’s Smart Sensor™. Trace energized or de-energized wires by removing the junction box cover. Trace energized wires without access to exposed conductors The SC-7000 signal clamp accessory can be used with the AT-7000-T Transmitter to induce a signal into energized and de-energized wires when there is no access to bare conductors. Simply clamp around the desired wire to induce the signal, then begin tracing. Induce signal with the signal clamp when there is no bare conductor. Use the Tip Sensor to trace wires in hard to reach areas When used with the AT-7000-T Transmitter, the Tip Sensor pinpoints the location of energized and de-energized wires in tight, hard to reach spaces. It easily and accurately traces the targeted energized and de-energized wires in junction boxes, corners, walls, floors and ceilings to a depth of up to 20 feet. Use the Tip Sensor to trace wires in hard to reach areas. Non-contact voltage (NCV) detection The NCV feature extends functionality of the AT-7000-R Receiver by detecting energized wires from 90 to 600 V and 40 to 400 Hz without the use of the AT-7000-T Transmitter. Its adjustable sensitivity fits a range of applications, from detecting presence of voltage (higher sensitivity) to precisely pinpointing a hot wire in a bundle (lower sensitivity). Non-contact voltage (NCV) detection. Hot Stick attachment The optional TIC 410A Hot Stick accessory enables easier tracing of wires in high ceilings, walls and along floors. TIC 410A Hot Stick Attachment Trace wires in hard to reach places with the TIC 410A. Amprobe® | info@amprobe.com | Fluke Corporation, Everett, WA 98203 | Tel: 877-AMPROBE (267-7623) ©2017 Amprobe® For detailed specifications and ordering go to amprobe.com 6003703 C AT-7000 Advanced Wire Tracer Specifications AT-7000-R Receiver AT-7000-T Transmitter SC-7000 Signal Clamp TFT LCD Color Display size TFT LCD Color Display Dimensions TFT LCD Color Display Resolution TFT LCD Color Display type TFT LCD Color Display 3.5 in (8.89 cm) 2.76 x 2.07 in (7.01 x 5.26 cm) 320px x 240px TFT LCD • 1.77 in (4.5 cm) 1.1 x 1.38 in (2.79 x 3.51 cm) 128px x 160px RGB x TFT • – – – – – Backlight • • – mDDR 64 MB 64 MB – FLASH memory 128 MB 128 MB – 95 dB 0 to 120˚F (-17.77 ˚C to 49˚C) -40 to 150˚F (-40 to 65.5˚C) 95% R.H max 2000 m CAT IV 600 V – 2 3.28 ft (1 m) – 0 to 120˚F (-17.77˚C to 49˚C) -40 to 150˚F (-40 to 65.5˚C) 95% R.H max 2000 m CAT IV 600 V – 2 3.28 ft (1 m) – Audio Operating Temperature range Storage Temperature Operating Humidity Operating altitude Measurement Category Transient protection Pollution degree Drop test Charging voltage (BR-7000-T) Charging duration (BR-7000-T) Power up time Non-Rechargeable Battery lifetime Rechargeable Battery lifetime (BR-7000-T) – – 30 s 9h – 0 to 120˚F (-17.77˚C to 49˚C) -40 to 150˚F (-40 to 65.5˚C) 95% R.H max 2000 m CAT IV 300 V 8.00 kV (1.2/50 uS surge) 2 3.28 ft (1 m) 90-270 V AC/DC, 40-400 Hz AT-7030: BR-7000-T: LI-ION, 7.2 V, 2.2 Ah AT-7020: 6x AA Alkaline Battery AT-7030: BR-7000-T battery: 2W AT-7020: 6xAA battery:2W AC line voltage (Charging state): 10W AC line voltage: 3W 85-270 V 16 h 20 s 9h – 10 h Leakage current (non-rechargeable) 1.1 to 2.6 uA 6 to 14 uA – – 1.2 to 4 uA – IP52 6.25 kHz Signal: 62.5 kSPS 32.768 kHz: 256 kSPS NCV: 62.5 kSPS Audible beep, bargraph display, numeric display Smart mode: 750 ms Tip Sensor Energized: 300 ms Tip Sensor De-Energized: 750 ms NCV: 500 ms, Battery monitoring: 5 s – 90-600 V AC IP40 – 62.5 kSPS – Numeric display – Voltage measurement: 1.5 s Battery monitoring: 5 s Instantaneous Power Supply Power consumption Leakage current (rechargeable) IP Rating Sampling rate Signal Response Response time Voltage Measurement Non-Contact Voltage (NCV) LED Indicator Operating Frequency Acoustic Indication Range Detection (Open air) Smart mode TIP Sensor: Energized TIP Sensor: De-Energized NCV 4xAA Alkaline battery 4xAA battery: 2W Green Flashing: Signal Detection Energized: 6.25 kHz De-Energized: 32.768 kHz 1 kHz Piezo Buzzer – Pinpointing: Around 1.97 in (5 cm) radius Direction indication: Up to 5 ft (152.4 cm) 9-300 V, DC to 400 Hz – Red: Energized OFF: De-Energized Orange: Over voltage – – – – – – – – – Voltage measurement: 40-400 Hz Energized: 6.25 kHz De-Energized: 32.768 kHz Energized: 6.25 kHz De-Energized: 32.768 kHz – – – – – – Pinpointing: Around 1.97 in (5 cm) Detection: Up to 22 ft (670.56 cm) – – Pinpointing: Around 1.97 in (5 cm) radius Detection: Up to 14 ft (426.72 cm) – – Detection: Up to 4 ft (121.92 cm) – – Current Output (Low) Energized – 53 mA rms – Current Output (High) Energized – 92 mA rms – – 53 mA rms – Current output (Low) with BR-7000-T Energized Current output (High) with BR-7000-T Energized – 120 mA rms – Voltage output (Low) De-Energized – 60 Vp-p – Voltage output (High) De-Energized – 120 Vp-p – Voltage output (Clamp) De-Energized – 180 Vp-p – Jaw Opening – – 2 in (5.08 cm) Fuse Dimensions Weight – 3.15A, 600V MAX, SLOW 5X20MM – 10.92 x 4.43 x 2.55 in (27.75 x 11.25 x 6.483 cm) 8.5 x 4 x 2.2 in (21.59 x 10.16 x 5.59 cm) 8.2 x 3.2 x 1.68 in (20.83 x 8.13 x 4.27 cm) 1.20 lb (0.544 kg) 1.30 lbs (0.593 kg) 0.648 lb (0.294 kg) Amprobe® | info@amprobe.com | Fluke Corporation, Everett, WA 98203 | Tel: 877-AMPROBE (267-7623) ©2017 Amprobe® For detailed specifications and ordering go to amprobe.com 6003703 C AT-7020 Advanced Wire Tracer Kit AT-7030 AT-7030 Advanced Wire Tracer Kit AT-7000 Wire Tracer Kits AT-7020 Kit AT-7030 Kit ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ (optional) ⚫ (optional) ⚫ – 3 AA Batteries 10 – Rechargeable AA Batteries – 10 8.95 lbs (4.06 kg) 10.30 lbs (4.67 kg) 16 x 13 x 7 in (40.6 x 33 x 17.8 cm) 16 x 13 x 7 in (40.6 x 33 x 17.8 cm) AT-7000-R Receiver AT-7000-T Transmitter TL-7000 Test Leads CC-7000 Carrying Case SC-7000 Signal Clamp HS-1 Hanger Battery Charger Description Receiver unit with Smart Sensor, Tip Sensor and color TFT LCD display Transmitter with two transmission frequencies (6 kHz and 33 kHz) and three power modes (High, Low, Clamp) Test Lead Set with alligator clips (Black & Red), 30 ft. grounding lead, power cord, plug adaptors and light socket adapter Custom Amprobe hard carrying case that securely holds transmitter, receiver, signal clamp, test leads and accessories Signal Clamp accessory for inducing a signal into wires without access to bare conductors Three-way magnetic hanger for AT-7000-T transmitter, allowing for convenient hanging of unit, placement on belt or as a stand Kit Specifications Kit Weight Case Size Amprobe® info@amprobe.com Fluke Corporation, Everett, WA 98203 Tel: 877-AMPROBE (267-7623) For complete information about Amprobe test tools, visit amprobe.com © 2017 Amprobe | Specifications subject to change without notice. Printed In U.S.A. 6003703 C
CC-7000 价格&库存
很抱歉,暂时无法提供与“CC-7000”相匹配的价格&库存,您可以联系我们找货
