37XR-A
37XR-A
    AMPROBE(安博)
    37XR-A
37XR-A 数据手册
Data Sheet 37XR-A True RMS Digital Multimeter True RMS digital multimeter with component and logic test for troubleshooting electronics at the bench or on the job site. ■■ Inductance to 40 H, frequency to 40 MHz, capacitance to 400 μF, logic to 20 MHz ■■ Input warning tone when test leads are in wrong jack ■■ 10,000 ■■ 1000 ■■ 10 No hassle warranty No waiting. No shipping charges. Our commitment to high-quality products and customer service is demonstrated by our industry exclusive “No Hassle” warranty. In the unlikely event that an Amprobe Test Tool requires warranty service, any of our local dealers are authorized to replace it, on the spot. count, 0.1 % accuracy V/750 V DC/AC True RMS Amps AC/DC, fully safety fused ■■ Resistance to 40 MW ■■ Continuity beeper ■■ Min/Max, ■■ Auto Average, Relative, Peak, and Data Hold power off to save battery life ■■ Separate door for easy battery and fuse access ■■ Magne-Grip™ ■■ CAT Holster with magnetic hanging strap III 600 V, CAT II 1000 V rated ■■ UL (CULUS) listed ■■ Three-year warranty (note: $500 MSLP limit) 1000V Amprobe® Test Tools 600V www.Amprobe.com Data Sheet 37XR-A Digital Multimeter General Specifications Autoranging; Display: Display Update Rate: Battery Life: Operating Temperature: Storage Temperature: Temperature Coefficient: Altitude: Dimensions: Weight: 4-3/4 digit LCD, 10,000 counts with 41-segment analog bar graph 2/sec, nominal; Power Battery: 9 V NEDA 1604, JIS 006P, IEC 6F22 150 hrs typical (alkaline) frequent use of backlight will decrease battery life 0 °C to 45 °C at < 70 % R.H. -20 °C to 60 °C, 0 to 80 % R.H. with battery removed from meter; 0.1 x (specified accuracy) per °C ( 0 °C to 18 °C , 28 °C to 45 °C) 2000 m (6562 ft) 195 x 92 x 60 mm (7.75” x 3.55” x 2.4”) 400 gr (1 lb) without holster, including battery Specifications (23 °C ± 5 °C,
37XR-A 价格&库存
很抱歉,暂时无法提供与“37XR-A”相匹配的价格&库存,您可以联系我们找货
37XR-A
库存:38
37XR-A
    库存:9
