DG57BM-5011-76-1012
DG57BM-5011-76-1012
    DURAKOOL
    DURAKOOL - DG57BM-5011-76-1012 - AUTOMOTIVE RELAY, SPDT, 12VDC, 60A/PANEL
DG57BM-5011-76-1012 数据手册
DG57BM Series automotive / electric vehicle relay • General Purpose automotive or industrial relay • Good inrush current resistance • Ideal for DC motor control • High continuous DC current capability • Optimised for up to 110VDC switching • Magnet arc blowout feature • Industry standard terminal layout ROHS Compliant Contacts Contact arrangement Contact material Max. switching voltage Min. switching current / voltage Rated load - see Fig. 1 Ordering Code SPST-NO (1 Form A), SPDT (1 Form C) AgSnO2 Initial Contact resistance 100mA / 12VDC make 120A @ 12.8VDC (3secs) Coil code: See table 1 Contact material 50: AgSnO2 Contact arrangement DC 6 ... 50V ≥0.1Un Operating range See Table 1 Rated power consumption 1.6W; 1.8W with resistor Insulation Dielectric strength 11: SPDT (1 C/O, 1 Form C) 21: SPST-NO (1 N/O, 1 Form A) Environmental protection 7: In cover, dust cover - IP54 100MΩ at 500VDC, 50%RH 9: Cover with mounting bracket coil to contact 750Vrms, 1min contact to contact 500Vrms, 1min General Data Connection Mode 5: PCB Terminals Operating time typ. 7ms Release time typ. 2ms Electrical life ops. 1 x 105 Options 1 (metal mounting bracket) Mechanical life ops. 1 x 107 Nil: No option Environmental Ambient temperature operating -40 to +125°C (above 85°C - consult factory) functional 20g, 11ms destructive 100g Vibration resistance Dimensions Weight DG57BM 031320FW 6: Flat Blades M1: Metal mounting bracket fitted storage -40 to +155°C Shock resistance D R
DG57BM-5011-76-1012 价格&库存
很抱歉,暂时无法提供与“DG57BM-5011-76-1012”相匹配的价格&库存,您可以联系我们找货
