DG85C-8021-96-1024-M1
    DURAKOOL
DG85C-8021-96-1024-M1 数据手册
DG85 automotive / industrial relays • General purpose automotive or industrial relays • High resistance to inrush current • PCB mounting versions available • Ideal for DC motor control • Industry standard size and footprint • High continuous DC current capacity • RoHS Compliant Contacts Contact number & arrangement Contact material Max. switching voltage SPST-NO (1NO), SPDT (1 C/O) AgNi, AgNi0.15, AgSnOInO, AgCdO 30VDC - current dependent - see curve Fig 2 DG85A DG85B DG85C DG85D SPST-NO SPDT (NO / NC) 30A 30A/30A 60A 60A/40A 80A 80A/60A 100A --- SPST-NO SPDT 120A 120A/45A 120A 120A/45A 240A 240A/180A 240A --- SPST-NO SPDT 40A 40A/30A 60A 60A/40A 80A 80A/60A 100A --- 0.5A 12VDC 0.5A 12VDC Max. continuous current Max. switching current - make Max. switching current - break Min. switching current Resistance 0.1A 12VDC 0.5A 12VDC < 100mΩ at 0.1A / 6VDC Coil Rated voltage Must release voltage Operating range of supply voltage Rated power consumption 6, 12 & 24VDC ≥ 0.01Un See Table 1 1.6W (1.81W with resistor) Insulation Dielectric strength coil - contact 500Vrms / 1min General data Operating time (typical value) Release Time Electrical Life resistive Mechanical life Dimensions (L x W x H) Weight Ambient Temperature storage operating Cover protection category Shock resistance Vibration resistance ≤7msec ≤2msec 5 5 > 2 x10 (DG85A, DG85B); >10 (DG85C, DG85D) 7 > 10 various - see dimensional drawings 35g approx. -40... + 155°C -40... + 125°C - see also Fig 1 IP40, IP67 depending on version 20g, 11ms 10-40Hz: DA 1.27mm; 70-100Hz: DA 0.5mm; 100-500Hz: 10g Page 1 of 4 American Electronic Components Inc., 1101 Lafayette St., Elkhart, IN 46516 Toll Free: (888) 847-6552, Tel: (574)-295-6330 www.aecsensors.com DG85 automotive / industrial relays Max. DC resistive load breaking capacity Fig. 1 Max. DC resistive load breaking capacity DG85A, DG85B Series Fig. 2 DG85C, DG85D Series 100A 80A Coil Data - DC voltage version Rated voltage V DC Coil code 1006 1012 1024 6 12 24 Table 1 Coil resistance ± 10% at 20ºC Ω 22 90 330 Must Operate Voltage Max VDC 3.6 7.2 14.3 Fig. 3 Wiring diagrams SPST-NO (1NO) Must Release Voltage Min VDC 0.6 1.2 2.4 SPST-NO (1NO) with Double 87 terminals (D) ( DR ) Page 2 of 4 American Electronic Components Inc., 1101 Lafayette St., Elkhart, IN 46516 Toll Free: (888) 847-6552, Tel: (574)-295-6330 www.aecsensors.com SPDT (1C/O) DG85 automotive / industrial relays Fig. 4 Dimensions - plug-in types SPST-NO SPST-NO SPDT (1C/O) SPST-NO SPDT (1C/O) DG85A, DG85B DG85C, DG85D All dimensions in mm Fig. 5 Dimensions - PCB types Overall Dimensions DG85A, DG85B SPST-NO PCB Mounting Holes SPST-NO DG85C, DG85D SPDT (1C/O) SPST-NO DG85A, DG85B SPDT (1C/O) DG85C, DG85D SPDT (1C/O) SPST-NO SPDT (1C/O) All dimensions in mm Page 3 of 4 American Electronic Components Inc., 1101 Lafayette St., Elkhart, IN 46516 Toll Free: (888) 847-6552, Tel: (574)-295-6330 www.aecsensors.com DG85 automotive / industrial relays Fig. 6 Dimensions - optional covers & brackets All dimensions in mm Ordering Codes Type Contact Contact Number & Material Arrangement Cover protection category Coil Code Terminal type Special Features D G 8 5 Series A - 30A B - 60A C - 80A D - 100A see Table 1 Contact Materials 10 - AgCdO - standard for DG85B 20 - AgNi - standard for DG85A 70 - AgSnOInO - standard for DG85C & DG85D 80 - AgNi0.15 Contact number & arrangement 11 - SPDT (1 C/O) 21 - SPST-NO (1 NO) Cover Protection Category 3 - Covered, sealed IP67 (not available for DG85C & DG85D, nor with any metal bracket mounting) 7 - Covered, dust cover IP54 9 - Cover with mounting bracket Special Features 1 Nil - No options M1 - Metal Bracket M2 - Bent metal bracket S1 - Skirted cover & metal bracket S2 - Skirted cover & bent metal bracket Special Features 2 Nil - No options R - Integral resistor D - Integral diode + 85, - 86 DR - Integral diode reversed - 85, + 86 BD - Bi-directional diode Connection Mode Page 4 of 4 American Electronic Components Inc., 1101 Lafayette St., Elkhart, IN 46516 Toll Free: (888) 847-6552, Tel: (574)-295-6330 www.aecsensors.com E&OE. DG85040706 5 - PCB 6 - flat blades D - Double 87 flat blades (DG85A & DG85B only)
DG85C-8021-96-1024-M1 价格&库存
很抱歉,暂时无法提供与“DG85C-8021-96-1024-M1”相匹配的价格&库存,您可以联系我们找货
