D2-2012-23-5024-WTL
D2-2012-23-5024-WTL
    DURAKOOL
D2-2012-23-5024-WTL 数据手册
D2 industrial relays 12 A / 250 V AC • Miniature dimensions • Cadmium - free contacts • AC and DC coils • For plug-in sockets, 35 mm DIN rail mount, EN 50022 or on panel mounting • For PCB and soldering connections - option • General purpose relays • WT (mechanical indicator + lockable front test button) - standard features of relays for plug-in sockets. Relays may be provided with the test buttons type P (no latching) and plugs. • Recognitions, certificates, directives: RoHS, R VDE Contacts Contact number & arrangement Contact material Max. switching voltage Min. switching voltage Rated load AC/DC AC1 DC1 Min. switching current Max. inrush current Rated current Max. breaking capacity Min. breaking capacity Resistance Max. operating frequency • at rated load • no load Coil Rated voltage AC1 AC1 50/60 Hz AC DC Must release voltage Operating range of supply voltage Rated power consumption AC DC Insulation Insulation category Insulation rated voltage Rated surge voltage Overvoltage category Insulation pollution degree Dielectric strength • coil - contact • contact - contact • pole - pole Contact - coil distance • clearance • creepage 1 200 cycles/hour 18 000 cycles/hour 6...240 V 5...220 V AC: ≥ 0.2 Un DC: ≥ 0.1 Un see Tables 1, 2 1,6 VA 0,9 W C250 250 V AC 4 000 V AC III IEC 61810-5 (PN-IEC 664-1) 3 2 500 V AC 1 500 V AC 2 500 V AC ≥ 2.5 mm ≥ 4 mm General data Operating time (typical value) Release time (typical value) Electrical life • resistive AC1 • cosφ Mechanical life (cycles) Dimensions (L x W x H) Weight Ambient temperature • storage • operating Cover protection category Environmental protection Shock resistance Vibration resistance Solder bath temperature Soldering time 2C/O AgNi, AgNi/Au 0.2 um, AgNi/Au 5 um 250 V / 250 V 5V 12 A / 250 V AC ❶ 10 A / 250 V AC ❷ 12 A / 24 V DC ❶10 A / 24 V DC ❷ 5 mA AgNi, 5 mA AgNi/Au 0.2 um, 2 mA AgNi/Au 5 um 24 A 12 A ❶ 10 A ❷ 3 000 VA ❶ 2 500 VA ❷ 0.3 W AgNi, 0.3 W AgNi/Au 0.2 um, 0.1 W AgNi/Au 5 um ≤ 100 mΩ AC: 10 ms AC: 8 ms DC: 13 ms DC: 3 ms ≥ 105 12 A, 250 V AC see Fig. 2 ≥ 2 x 107 27.5 x 21.2 x 35.6 mm ❶ 27.5 x 21.1 x 33.5 mm ❷ 27.5 x 21.2 x 33 mm ❸ 35 g (NO/NC) -40...+85 oC AC: -40...+55 oC DC: -40...+70 oC IP 40 RTI IEC 61810-7 10 g / 5 g 5 g 10...150 Hz max. 270 oC max. 5 s Standard contact materials are marked with bold type. ❶ For plug-in sockets version: standard (WT) ❷ For PCB version ❸ For version with threaded bolt Page 1 of 5 www.aecsensors.com Sales Department Tel: (888) 847-6552 D2 industrial relays Coil data - DC voltage version Coil code 1005 1006 1012 1024 1048 1060 1080 1110 1125 1220 Table 1 Rated voltage V DC 5 6 12 24 48 60 80 110 125 220 Coil resistance (±10%) at 20 °C Ω 28 40 160 640 2 600 4 000 7 100 13 600 16 000 54 000 Coil operating range V DC min. (at 20 °C) 4.0 4.8 9.6 19.2 38.4 48.0 64.0 88.0 100.0 176.0 max. (at 55 °C) 5.5 6.6 13.2 26.4 52,8 66.0 88.0 121.0 137.5 242.0 Standard coil rated voltages marked with bold type. Coil data - AC 50/60 Hz voltage version Coil code 5006 5012 5024 5042 5048 5060 5080 5110 5120 5127 5220 5230 5240 Rated voltage V AC 6 12 24 42 48 60 80 110 120 127 220 230 240 Table 2 Coil resistance (±10%) at 20 °C Ω 9.8 39.5 158.0 470.0 640.0 930.0 1 720.0 3 450.0 3 770.0 4 000.0 15 400.0 16 100.0 16 800.0 Coil operating range V AC min. (at 20 °C) 4.8 9.6 19.2 33.6 38.4 48.0 64.0 88.0 96.0 101.6 176.0 184.0 192.0 Standard coil rated voltages marked with bold type. Page 2 of 5 www.aecsensors.com Sales Department Tel: (888) 847-6552 max. (at 55 °C) 6.6 13.2 26.4 46.2 52.8 66.0 88.0 121.0 132.0 139.0 242.0 253.0 264.0 D2 industrial relays 35.6 35.6 6.5 6.6 6.6 21.2 6.5 6.2 6.3 6.3 4.1 27.5 Dimensions - plug-in version (WT), with test button type P (no latching) or with plug (no manual operation) 6.2 6.3 6.3 4.1 27.5 Dimensions - plug-in version (WT), with lockable front test button type T 2.2x0.5 6.6 6.6 21.2 2.2x0.5 Test buttons type P and plugs need to ordered separately. They substitute buttons type T. To exchange by Customer themselves. Information on buttons type P and plugs. Dimensions - version with threaded bolt Dimensions - PCB version (without WT) 21.2 6.5 6 4 33 33.5 27.5 1 13.2 0.5 6.2 21.1 6.3 6.3 4.1 M2.5 27.5 6.8 Dimensions - version with mounting flange in the upper wall of the cover (without WT) 43 8 3.5 38 22 6.5 33 2 28.4 Page 3 of 5 www.aecsensors.com Sales Department Tel: (888) 847-6552 D2 industrial relays Connections diagram (pin side view) 12 (1) 42 (4) 14 (5) 44 (8) 11 (9) 41 (12) Electrical life at AC resistive load Fig. 1 A2 (14) A1 (13) 2C/O Relay terminals for PCB 0.5 x 1 mm Drilling hole: • for relays • for sockets Ø 1.3 + 0.1 mm Ø 1.5 + 0.1 mm 3 Electrical life reduction factor at AC inductive load Fig. 2 Fig. 3 50 F 1 Max. DC resistive load breaking capacity Reduction factor 0 .8 12 10 0.6 5 2 0.4 1 0.5 1 0.8 0.6 0.4 0.2 Power factor 0.1 10 20 30 40 50 100 200 300 Mounting Relays D2 are offered in versions: • standard WT (mechanical indicator + lockable front test button), for plug-in sockets. In standard version of relays (WT) is possibility self-exchange of button type T for: button type P (no latching) or plug (no manual operation). Buttons type P and plugs need to ordered saparately • for PCB (without WT) • with threaded bolt • with mounting flange in the upper wall of the cover (without WT). Relays D2 are designed for: • screw terminals plug-in sockets DZT2 and DZM2 with clip DZT4-0040 or D4 1052; plug-in sockets DZR2 with clip D4 1052, 35 mm DIN rail mount, EN 50022 or on panel mounting. Signalling / protecting modules type DM... are available with sockets DZT2 and DZM2 (see page 240) • plug-in sockets for PCB mounting DU4/2D with clip D4 1053 (WT) or D4 1050 (without WT) • solder terminals sockets DU4/2L with clip D4 1053 (WT) or D4 1050 (without WT) and spring clamp D4 1040 • solder terminals sockets D4/2 with clip D4 1053 (WT) or D4 1050 (without WT) • direct PCB mounting. Page 4 of 5 www.aecsensors.com Sales Department Tel: (888) 847-6552 D2 industrial relays Contact material selection for different load types • AgNi - for resistive or inductive loads, • AgNi/Au 0.2 um - contact surface protection against oxidation during storage, • AgNi/Au 5 um - for small resistive loads in control circuits. Ordering codes Cover protection category Type Contact Contact number & material arrangement Connection mode Coil code Additional features D 2 Contact material 20 - AgNi 21 - AgNi/Au 0.2 um 23 - AgNi/Au 5 um see Tables 1, 2 Contact number & arrangement 12 - 2C/O Cover protection category 2 - in cover, IP 40 version 4 - in cover with mounting flange, IP 40 version Connection mode 3 - for plug-in sockets 5 - for PCB 7 - for PCB, with threaded bolt 9 - for plug-in sockets, with threaded bolt Additional features ❶ without marks - without additional features ❷ WT - mechanical indicator + lockable front test button WTL - mechanical indicator + lockable front test button + LED diode (light indicator) WTD - mechanical indicator + lockable front test button + D diode (element for limiting reverse voltage peaks) WTLD - mechanical indicator + lockable front test button + LED diode (light indicator) + D diode (element for limiting reverse voltage peaks) ❶ WT - standard features of relays for plug-in sockets. WTD, WTLD - only for DC coils ❷ Refer relays for PCB; with threaded bolt; with mounting flange in the upper wall of the cover Test buttons type P and plugs need to ordered separately. They substitute buttons type T. To exchange by Customer themselves. Information on buttons type P and plugs . • Button R4P-0001-A - orange colour (AC coils) • Button R4P-0001-D - green colour (DC coils) • Plug R4W-0003-A - orange colour (AC coils) • Plug R4W-0003-D - green colour (DC coils) Note: For relays with DC coils and additional features inclusive: D - D diode (element for limiting reverse voltage peaks) and L - LED diode (light indicator) coil supply polarity is fixed. Terminal A1 (13) ”+”; terminal A2 (14) ”-”. Supply polarity is marked on relay cover. Colour of lockable front test button type T represents type of coil supply current: orange - AC coil, green - DC coil. Examples of ordering codes: D2-2012-23-1024-WT D2-2012-25-1024 relay D2, contact material AgNi, with two changeover contacts, in cover IP 40, for plug-in sockets, voltage version 24 V DC, with mechanical indicator and lockable front test button relay D2, contact material AgNi, with two changeover contacts, in cover IP 40, for PCB, voltage version 24 V DC American Electronic Components, Inc. 1101 Lafayette Street, Elkhart, IN 46516 Page 5 of 5 www.aecsensors.com Sales Department Tel: (888) 847-6552
D2-2012-23-5024-WTL 价格&库存
很抱歉,暂时无法提供与“D2-2012-23-5024-WTL”相匹配的价格&库存,您可以联系我们找货
