DP6-OC-24VAC/DC
DP6-OC-24VAC/DC
    DURAKOOL
DP6-OC-24VAC/DC 数据手册
DP6-OC industrial relays • Relays DP6-OC - with transistor output, rated load up to 0.5 A / 70 V DC • 35 mm DIN rail mount, EN 50022, wires connection with screw terminals - 0.2...4 mm2 • Adapted for the co-operation with interconnection strip type ZG20 • Equipped in LED green • Recognitions, certificates, directives: Transistor - output Max. switching voltage Min. switching voltage Rated load Min. switching current DC DC DC1 70 V 5V 0.5 A / 70 V DC 1 mA Input control circuit Rated voltage Turn-off voltage Rated power consumption DC AC/DC 5...32 V 24-230 V AC: 50/60 Hz AC: ≥ 0.2 Un DC: ≥ 0.1 Un 0.3 W 0.3 VA / 0.3 W 24 V AC/DC 1.0 VA / 1.0 W 230 V AC/DC 5...32 V DC at 24 V Insulation Insulation category Insulation rated voltage Rated insulation voltage I/O Insulation pollution degree C250 600 V AC 3 000 V AC 2 General data Max. switching frequency Dimensions (L x W x H) Weight Ambient temperature • storage • operating Protection category Environmental protection Page 1 of 2 www.aecsensors.com 10 kHz ------80 x 6.2 x 40 g 5...32 V DC (for load up to 24 V DC - 15 KHz) 24 V AC/DC 230 V AC/DC 93.8 mm -40...+70 oC -40...+55 oC IP 20 RTI IEC 61810-7 Sales Department Tel: (888) 847-6552 DP6-OC industrial relays Table 1 Input data Relay code Nominal input voltage Un Power of input - control circuit DP6-OC-5...32VDC DP6-OC-24VAC/DC 5...32 V DC 24 V AC/DC 0.3 W at 24 V 0.3 VA / 0.3 W DP6-OC-230VAC/DC 230 V AC/DC 1.0 VA / 1.0 W Dimensions DP6-OC-5...32VDC +13 +Vcc +A1 +13 80 LOAD -A2 93.8 DP6-OC-24VAC/DC DP6-OC-230VAC/DC +Vcc LOAD +13 +13 6.2 +A1 -A2 Mounting Ordering codes Ordering codes DP6-OC are specified in Table 1, "Relay code" column. Relays DP6-OC are designed for 35 mm DIN rail mount, EN 50022. DP6-OC are adapted for the co-operation with interconnection strip type DG20. Interconnection strip DG20 allows to common bridging outputs or inputs. Colours of strips: DG20-1 red, DG20-2 black, DG20-3 blue. 2.8 American Electronic Components, Inc. 1101 Lafayette Street, Elkhart, IN 46516 Page 2 of 2 www.aecsensors.com Sales Department Tel: (888) 847-6552 21 12 123.7 2.8 2.8 0.8
DP6-OC-24VAC/DC 价格&库存
很抱歉,暂时无法提供与“DP6-OC-24VAC/DC”相匹配的价格&库存,您可以联系我们找货
