D102000
D102000
    DURAKOOL
    DURAKOOL - D102000 - DURAKOOL
D102000 数据手册
Optical Liquid Level Sensors D102 Series Features: • M12 x 1 Thread • Low Power • Low Cost • Compact size • Wide range of commercial and industrial applications • Detect almost any liquid type - oil or water based Standard Temperature Housing Material High Temperature Polysulfone Housing / Mounting M12 Output Type / Logic Push / Pull - Digital High in Air Output Current (sink & source) Up to 100mA (Iout) Pressure° 7 bar / 101 psi max. Supply Current 2.5mA max. (Vs = 15.4 VDC) Supply Voltage 4.5 - 15.4 VDC Temperature - Operating (Storage) -25°C to +80°C (-30°C to +85°) Thread M12 x 1 x 8g with hex nut and washer Tightening Torque 1.5 Nm / 13.26 in-lbs maximum Sensor Termination 24AWG - 250mm PTFE wires - 8mm tinned The minimum load impedance should not exceed Vs/max output current. Shorting the output to VS or OV will result in irreparable damage to the sensor. Before use, check the fluid you wish to use is compatible with Polysulfone. Order Codes: D102000 D102100 Drawing dimensions in millimetres Standard Temperature Range Extended Temperature Range Contact factory for custom terminations and other lead lengths available to special order. American Electronic Components Inc., 1101 Lafayette Street, Elkhart, Indiana. USA Tel: +1-574-295-6330 Fax: +1-574-293-8013 Email: sales@aecsensors.com http://www.aecsensors.com © American Electronic Components Inc 2008 Specifications are subject to change without notice. E&OE. D102 FW092418
D102000 价格&库存
很抱歉,暂时无法提供与“D102000”相匹配的价格&库存,您可以联系我们找货
