A1B-003
A1B-003
    DURAKOOL
A1B-003 数据手册
Part No: A1B–003 A1 Series Tilt Switch – Non Mercury Features: * Insulated * Form: NO/NC/SPST/Mount dependent * Angles Referenced from Horizontal * Hermetically Sealed * Small Package Size * Narrow Included Angle * Low Contact Resistance * Long Life Drawing dimensions in inches. Tilt switches “make” when the electrode is tilted below horizontal and “break” when tilted above the horizontal. Total travel from “make” to “break” is the “Maximum included angle” shown below. The component to which the switch is attached must have a total tilt angle greater than the “Maximum included angle” for proper operation. Typical Operating Angle * : Maximum included Angle: 8º - 12º * Make/break angles are electrode + (above) / - (below) 0° horizontal reference Switch Ratings: Max Switching Voltage: Max Switching Current: Initial Contact Resistance (Max): Stand Off Voltage (contact to contact): Operating Temperature: Storage Temperature: Typical number of operations at specified load: G-Force Activation G-Level/Range: Dimensions: Weight per 100pcs. Lbs / Kgs: Body Length (less leads). Inches / Millimeters: Maximum Diameter. Inches / Millimeters: Materials: Lead Wire Type: Lead wire length/skive/termination: Finish: Clip: © American Electronic Components Inc 2006 Specifications are subject to change without notice. E&OE. 120VAC / 24VDC 120VAC / 1mA; 12VDC / 100mA; 24VDC / 50mA 200 Ohms 1 kV AC -38º to 220º F / -38º to 105º C -40º to 356º F / -40º to 180º C 10,000,000 N/A 3.04 / 1.38 1.31 / 33.27 0.501 / 12.73 #20 AWG Silicone 6 inches, ring terminals for #8 screw Case: PBT (30% Glass Filled) Use P/N 2023 Mounting Clip American Electronic Components Inc., 1101 Lafayette Street, Elkhart, Indiana. USA Tel: +1-574-295-6330 Fax: +1-574-293-8013 Email: sales@aecsensors.com http://www.aecsensors.com A1B003 200606
A1B-003 价格&库存
很抱歉,暂时无法提供与“A1B-003”相匹配的价格&库存,您可以联系我们找货
