DG34-1021-36-1012
DG34-1021-36-1012
    DURAKOOL
    DURAKOOL - DG34-1021-36-1012 - POWER RELAY, 12VDC, 30A, SPST-NO, PANEL
DG34-1021-36-1012 数据手册
DG34 automotive/ industrial relays • General purpose automotive or industrial relays • High resistance to inrush current • For pcb or chassis mounting • Flat insert faston terminal options • AC and DC coils • High Current automotive optimized version available • Recognitions, certificates, directives: RoHS, Contacts Contact number & arrangement Contact material Max. switching voltage Min. switching voltage Rated Load Min. switching current Max. inrush current Rated current Max. breaking capacity Min. breaking capacity Resistance Max. operating frequency at rated load no load AC / DC AC1 DC1 SPST-NO (1NO), SPST-NC (1NC), SPDT (1 C/O) AgSnOInO, AgCdO 277VAC / 30VDC 10V 7200VA 30A 30V 10mA 80A (SPST-NO), 50A/20A (SPDT) SPST-NO: 30A, SPST-NC: 15A / 277VAC, 10A / 30VDC, SPDT: 20A (NO), 15A (NC) AC1 30A 1W < 50mΩ at 0.1A / 6VDC AC1 1200 cycles / hour 10,000 cycles / hour Coil Rated voltage Must release voltage Operating range of supply voltage Rated power consumption AC DC 12... 220VAC 50/60Hz 5... 110VDC DC: ≥ 0.05Un AC: ≥ 0.15Un See Tables 1, 2, 3 AC: 2VA (approx.) DC: 1W std, 0.9W sensitive Insulation Insulation category Insulation rated voltage Dielectric strength coil - contact contact - contact pole - pole Contact - coil distance clearance creepage C250 250VAC AC Coils: 1500Vrms / 1min 1500Vrms / 1 min DC Coils: 2500Vrms / 1min 3 mm 3 mm General data Operating time (typical value) Release Time Electrical Life resistive AC1 cos Ø ≤15msec ≤15msec Mechanical life Motor Load Dimensions (L x W x H) Weight Ambient Temperature storage operating Cover protection category Shock resistance Vibration resistance > 10 2hp (NO), 1hp (NC) various - see dimensional drawings 20...25g 5 > 10 7 -55... + 130°C -55... + 85°C IP00, IP40, IP67 depending on version 20g, 11ms DA 1.5mm, 20-200Hz Page 1 of 4 American Electronic Components Inc., 1101 Lafayette St., Elkhart, IN 46516 Toll Free: (888) 847-6552, Tel: (574)-295-6330 www.aecsensors.com DG34 automotive and industrial relays Coil Data - standard DC voltage version Rated voltage V DC Coil code 1005 1006 1009 1012 1015 1018 1022 1024 1048 1110 5 6 9 12 15 18 22 24 48 110 Table 1 Coil resistance ± 10% at 20ºC Ω 25 36 81 144 225 324 484 576 2304 12100 Must Operate Voltage Max VDC 3.75 4.50 6.75 9.00 11.25 13.50 16.50 18.00 36.00 82.50 Must Release Voltage Min VDC 0.5 0.6 0.9 1.2 1.5 1.8 2.2 2.4 4.8 11.0 Coil Data - sensitive 0.9W DC voltage version Rated voltage V DC Coil code S005 S006 S009 S012 S015 S018 S022 S024 S048 S110 5 6 9 12 15 18 22 24 48 110 Table 2 Coil resistance ± 10% at 20ºC Ω 27 40 97 155 256 380 545 660 2560 13450 Must Operate Voltage Max VDC 3.75 4.50 6.75 9.00 11.25 13.50 16.50 18.00 36.00 82.50 Must Release Voltage Min VDC 0.5 0.6 0.9 1.2 1.5 1.8 2.2 2.4 4.8 11.0 Standard coil rated voltages marked with bold type, some types may be subject to special order quantities Coil Temperature Rise - Covered type Coil Temperature Rise - Open Type T e m p e r a t u r e R i s e ° C T e m p e r a t u r e 9 0 7 0 30A 5 0 20A R i s e 3 0 0 80 100 120 140 % of Nominal Coil Voltage Page 2 of 4 ° C 10A 1 0 160 9 0 30A 7 0 20A 5 0 10A 3 0 1 0 0 80 100 120 140 % of Nominal Coil Voltage American Electronic Components, Inc. 1101 Lafayette St., Elkhart, IN 46516 Tel: (888) 847-6552 www.aecsensors.com 160 DG34 automotive and industrial relays Coil Data - AC 50/60Hz voltage version Coil resistance ± 10% at 20ºC Ω 26 106 2750 11000 Rated voltage V DC Coil code 5012 5024 5110 5220 Table 3 5 6 9 12 Must Operate Voltage Max VDC 10.2 20.4 93.5 187.0 Must Release Voltage Min VDC 1.8 3.6 16.0 33.0 Ordering Codes Type Contact Material Contact Number & Arrangement Cover protection category Terminal type Coil Code D G 3 4 Contact Materials 10 - AgCdO 70 - AgSnOInO Contact number & arrangement 11 - SPST (1 C/O) 21 - SPNO (1 NO) 31 - SPNC (1 NC) see Tables 1, 2 & 3 Cover Protection Category 1 - Open type, no cover IP00 3 - Covered, sealed IP67 7 - Covered, dust cover IP54 Connection Mode 0 - PCB coil and contacts + flat blades for contacts 5 - PCB only, all terminals 6 - Flat blades for all terminals - chassis mount Life Expectancy - Covered type Life Expectancy - Open Type 100 O p e r a t i o n s 100 O p e r a t i o n s 10 x 10 4 x 10 4 0 0 0 5 10 15 Load Current (A) Page 3 of 4 10 20 25 30 0 5 10 15 20 Load Current (A) American Electronic Components, Inc. 1101 Lafayette St., Elkhart, IN 46516 Tel: (888) 847-6552 www.aecsensors.com 25 30 DG34 automotive and industrial relays Dimensions Dimensions in mm 3 x 6.4 QC 3 x 6.4 QC 2 x 4.8 QC PCB Mounting Holes Dimensions Wiring Diagrams SPST-NO 1 C/O PCB SPST-NC 1 NO SPDT 1 NC PCB + QC * mounting hole not needed for SPST-NO ** mounting hole not needed for SPST-NC Page 4 of 4 American Electronic Components, Inc. 1101 Lafayette St., Elkhart, IN 46516 Tel: (888) 847-6552 www.aecsensors.com
DG34-1021-36-1012 价格&库存
很抱歉,暂时无法提供与“DG34-1021-36-1012”相匹配的价格&库存,您可以联系我们找货
