DZ11-0031
DZ11-0031
    DURAKOOL
DZ11-0031 数据手册
Plug-in sockets and accessories Connection diagrams DZM80 Dimensions For DM84, DM85, DM87L, DM87P Screw terminals 1.37 in (35 mm) DIN snap on rail mounting, or direct panel mounting 3.07 in (78.1) x 0.63 (15.9) x 2.4 in (61) [2.64 in (67)] ✪ Double pole 0.2 in (5 mm) pin layout 12 A, 300 V DM85 DM84 Accessories ❷ DZT80-0035 ❶ DM87L DM87P Module type DM6.. DZT80-0040 Connection diagram DZM92 Dimensions For DM87N, DM87N sensitive Screw terminals 1.37 in (35 mm) DIN snap on rail mounting, or direct panel mounting 3.07 in (78.1) x 0.63 (15.9) x 2.4 in (61) [2.64 in (67)] ✪ Single pole 0.138 in (3.5 mm) pin layout 12 A, 300 V DZT80-0040 Accessories ❷ DZT80-0035 Module type DM6.. Dimensions Connection diagram DZM2 For D2 Screw terminals 1.37 in (35 mm) DIN snap on rail mounting, or direct panel mounting 2.95 in (75) x 1.06 (27) x 2.4 in (61) [3.23 in (82)] ✪ Double pole 12 A, 300 V DZT4-0040 Accessories ❷ DZT4-0035 DG4 1052 Module type DM6.. ❶ For DM85: loads up to 12 A do not require bridging of common terminals. Loads above 12 A require bridging pairs of terminals: 11 with 21, 12 with 22, 14 with 24 [clamp bridge Cu wire minimum 14 AWG (1.5 mm2)]. ❷ Signalling / protection modules type DM6... For plug-in sockets type: DZM80, DZM92, DZM2, DZM4 DM61G : 6/24 V AC/DC DM62G : 24/60 V AC/DC DM63G : 110/230 V AC/DC LED green color. AC/DC voltage allowed. Coil energized indicator. ❸ DUC11 limits max switching voltage up to 250 V AC/DC and coil rated voltage up to 240 V AC. ✪ The height of sockets with retainer / retractor clip is shown in square brackets. www.aecsensors.com American Electronic Components Inc., Tel: toll free (USA) 888-847-6552 Intl 574-295-6330 Plug-in sockets and accessories DZM4 Dimensions Connection diagram For D4 Screw terminals 1.37 in (35 mm) DIN snap on rail mounting, or direct panel mounting 2.95 in (75) x 1.06 (27) x 2.4 in (61) [3.23 in (82)] ✪ Four pole 6 A, 300 V Accessories ❷ DZ8 DZT4-0040 DG4 1052 DZT4-0035 Module type DM6.. Dimensions Connection diagram For D15 DPDT Screw terminals 1.37 in (35 mm) DIN snap on rail mounting, or direct panel mounting 2.68 in (68.2) x 1.5 (38) x 0.94 in (24.2) 10 A, 250 V Accessories ❷ DZ11 DZ11 0031 Dimensions Connection diagram For D15 3PDT Screw terminals 1.37 in (35 mm) DIN snap on rail mounting, or direct panel mounting 2.68 in (68.2) x 1.5 (38) x 0.94 in (24.2) 10 A, 250 V Accessories ❷ DUC11 ❸ DZ11 0031 Dimensions Connection diagram For DUC Screw terminals 1.37 in (35 mm) DIN snap on rail mounting, or direct panel mounting 3.23 in (82) x 1.66 (42.2) x 1.04 in (26.5) 16 A, 250 V Accessories ❷ DMBA American Electronic Components Inc., Tel: toll free (USA) 888-847-6552 Intl 574-295-6330 www.aecsensors.com
DZ11-0031 价格&库存
很抱歉,暂时无法提供与“DZ11-0031”相匹配的价格&库存,您可以联系我们找货
