32000508E
32000508E
    MIPOT
32000508E 数据手册
HI-TECH COMPANY FSK TRANSMITTER 50 Ω Output 433.92 MHz – 3 V version / cod. 3-2000508 DESCRIPTION: FSK Transmitter, with crystal locked oscillator, manufactured in SMT technology on printed circuit. Booster stage to improve output power. HIGHLIGHTS: High output power with low supply voltage. Developed according to I-ETS 300 220 and ETS 300 683 European Standard. APPLICATIONS: Domestic Security, Surveillance Systems, Data Transmission, perfect for battery supply systems. M E C H A N I C A L C H A R AC T E R I S T I C S Pin functions 1 = GND 2 = Tx DATA 3 = NOT CONNECTED 4 = GND 11 = RF OUTPUT (50Ω) 13 = GND 14 = Tx ENABLE (Note4) 15 = +Vcc A B S . M A X . R AT I N G S Power Supply, +Vcc, pin 15: Storage Temperature: Operating Temperature: + 4 Volt - 40 ÷ + 100 °C - 20 ÷ + 70 °C E L E C T R I C A L C H A R A C T E R I S T I C S AT 2 5 ° C : Parameter MIPOT S.P.A. Via Corona, n. 5 (Zona Ind.) 34701 Cormons (GO) Italy Tel.+39 0481 630200 r.a. Fax +39 0481 62387 mipot@mipot.com Power Supply ( +Vcc ) Supply Current Carrier Frequency FSK Modulation Output Power (50Ω load) Second Harmonic Level (load 50Ω) Start-up Time Logic Low Logic High Baud Rate Note 1: Note 2: Note 3: Note 4: Min. Tip. Max Unit 2.4 433.42 +10 -0.7 2.0 - 3 28 433.92 ± 25 +12 - 3.6 434.42 -36 1.5 0.4 3.5 38400 Volt mA MHz kHz dBm dBm ms Volt Volt Baud +Vcc = 3V, 1 kHz square wave modulation 0-3 V, duty-cycle 50% a 434.42 MHz version is available on request power supply versions from 5V to 12V are available on request Tx ENABLE is available only on 5V to 12 V versions with voltage regulator. Mipot S.p.A. reserves the right to modify the specifications without notice. Notes Note 1 Note 1 Note 1
32000508E 价格&库存
很抱歉,暂时无法提供与“32000508E”相匹配的价格&库存,您可以联系我们找货
