HIOKI 9465-90.
HIOKI 9465-90.
    HIOKI(日置)
    HIOKI - HIOKI 9465-90. - Test Accessory, Tip Pin, 9465-10 Measurement Probe
HIOKI 9465-90. 数据手册
RESISTANCE METER RM3544, RM3548 Easy to use with high-accuracy Resistance Meters for Production Lines and MRO The Resistance Meters RM3544/RM3548 can measure the winding resistance of devices such as motors and transformers, the contact resistance of power contacts (relays and switches), and the DC resistance of fuses, resistors, and substrates such as conductive rubber and sheets. It does so quickly and at a high level of accuracy using four-terminal measurement. The RM3544 is well suited to use for adjustment and testing on production lines as well as acceptance inspections, while the RM3548 comprises a portable solution for measuring resistance values ranging in magnitude from microohms to megohms, making it ideal for use in production, maintenance, repair and operation of large equipment. 2 Perform resistance measurement with an ideal combination of equipment depending on your component or equipment and test conditions. Applications Probes suited to manual measurement on production lines Motors, solenoids, choke coils, transformers, wire harnesses Contacts, wire harnesses, relay contacts, switches 4 -TERMINAL LEAD L2104 CLIP TYPE LEAD L2101 Conductive rubber, paint Fuses, resistors, heaters, wires, welds PIN TYPE LEAD L2102 Large motors, large transformers PIN TYPE LEAD L2103 Probes suited to DC measurement of the chassis and bodies of large equipment Temperature rise tests (Motors, choke coils, transformers) 4 -TERMINAL LEAD 9453 CLIP TYPE LEAD L2107 Vehicle grounding lines, conductivity of aircraft fuselages PIN TYPE LEAD 9465-10 PIN TYPE LEAD 9772 LARGE CLIP TYPE LEAD 9467 A Full Line-up of HIOKI Resistance Meters to Suit Your Measurement Range 0.1μΩ 0.01μΩ 0.01μΩ 0.1μΩ 1μΩ RM3544/RM3544-01 RM3548 RM3545 RM3543 RM3542 3.5MΩ 3.5MΩ 1200MΩ 1.2kΩ 120MΩ 1kΩ SM7120 2×1019Ω 3 Robust specifications in a compact package RESISTANCE METER RM3544/RM3544-01 High-accuracy bench-top resistance meter for both manual operation and integration with automatic lines Basic accuracy : 0.02% Max.resolution : 1μΩ Max. measurable current : 300mA Measure from 0.000 mΩ (@ 300 mA) to 3.5 MΩ Probe for guard jack use and increased measurement current yield an instrument that’s more resistant to noise. Optional LED COMPARATOR ATTACHMENT and high-volume judgment tones combine to ensure PASS/FAIL judgments are communicated reliably in the noisy environment of the production floor. EXT I/O interface with NPN/PNP support can accommodate a variety of automated production lines (-01 model). RESISTANCE METER RM3548 High-accuracy portable resistance meter Basic accuracy : 0.02% measures from µΩ to MΩ Max. measurable current : 1A Max.resolution : 0.1μΩ Measure from 0.0 µΩ (@ 1 A) to 3.5 MΩ Temperature correction Easily record up to 1,000 data points in memory simply by applying the instrument’s probes. Smoothly capture temperature-rise test data using interval measurement. Portable design is ideal for maintenance and testing of large equipment. Generally, the resistance of copper wiring changes with temperature by 0.4% per degree Celsius. The RM3544/RM3544-01/RM3548 provides a temperature correction function to convert the observed resistance value Rt at the current temperature t to the resistance value Rto at the reference temperature t0. *Requires temperature sensor (Z2001 or Z2002). Reference temperature setting range:-10 ℃ to 99.9 ℃ Temperature coefficient setting range:-9,999 ppm to +9,999 ppm Resistance value Rt R t0 Correction t0 t Temperature 4 Easy-to-use RESISTANCE METER suits both manual operation and integration with automatic lines Features RM3544/RM3544-01 Simple, intuitive functions, screens, and operation for applications, including on production lines and in acceptance inspections High-durability probes with guard jack and increased measurement current for noise-resistant*1 measurement Quickly identifiable PASS/FAIL judgments with sound and light *1 Compared to previous model (3540). High-precision specs in a compact package Convenient range options Measure from 0.000 mΩ to 3.5000 MΩ 1μΩ max. resolution, 0.02% basic accuracy Max. measurable current of 300mA As inverter-equipped power supply equipment uses increasingly high currents and frequencies, increasingly low-resistance and low-loss inductors are being used in their circuitry, prompting a need for the ability to measure lower resistance levels with a high level of stability. With a resolution of 1 μΩ, the RM3544/ RM3544-01 satisfies these needs. Electronic components make extensive use of high-resistance substrates such as conductive sheets and rubber, and the RM3544/ RM3544-01 delivers the ability to measure up to 3.5 MΩ. Moreover, the instrument’s maximum accuracy of 0.02% allows it to be used in testing current detectors with a precision of 0.1%. No warmup period or zero adjustment The RM3544/RM3544-01 has no warmup time, meaning it’s ready to use for measurement as soon as you turn it on. Accuracy is guaranteed immediately after the instrument is powered up (assuming temperature and humidity conditions that satisfy the accuracy guarantee conditions). Footprint of just 215 × 166 mm Compared to previous the previous model (HIOKI 3540), the RM3544/RM3544-01 takes up approximately 25% less installation space. The smaller footprint creates work space in front of the instrument, and its compact size allows it to be easily and unobtrusively embedded in other equipment. High-durability probes HIOKI offers a line of probes designed to accommodate the full range of measurement targets. Flex resistance has been dramatically improved (based on HIOKI comparisons). 5 Advanced functionality that’s as easy to use as it is easy to understand Measurement jacks with guard jack By connecting a probe to the guard jack, you can minimize the effects of external noise on measurements. Simple control over basic settings Range and measurement speed can be controlled directly. Loud, user-selectable judgment tones High-volume judgment tones of at least 85 dB inform the operator of test results, ensuring that they remain audible even in the vicinity of noisy machinery. The ability to choose from various tones ensures operators won’t confuse judgment results on lines where multiple RM3544 units are in use. LED COMPARATOR ATTACHMENT (Option) The LED Comparator Attachment indicates judgment results with green and red LEDs, eliminating the need to look at the instrument’s screen and increasing work efficiency. Since the lamps do not light up when the measurement leads are open, the attachment can also be used to verify the connection status. Green light IN state Red light HI/LO state Material- and temperature-independent temperature correction function The temperature correction function can be used to convert resistance values that vary with the ambient temperature to a reference value at a reference temperature using the Temperature Sensor Z2001 and a user-specified resistance temperature coefficient. Scaling The scaling function can be used to convert resistance values into physical properties such as length. Conversion formula : Rs = A × R + B A, B : Constants, R : Measurement value Rs : Resistance value Intuitive, graphical LCD Panel save and load functionality for up to 10 sets of parameters Panel save and load functionality provides the ability to save and subsequently load up to 10 sets of instrument setting conditions for range, comparator, and other parameters. Naming each set of panel data lets you make setup changes among production lots and lines smoothly and effortlessly. Comparator Function The comparator function compares measured values to a previously set reference value or range and then displays and outputs the judgment result. The RM3544-01 can also output comparator results via its EXT I/O interface. 6 Acquiring measurement results (data) (RM3544-01) RM3544 -01 rear panel RS-232C/PRINTER EXT I/O polarity (Select NPN/PNP) EXT I/O Pr ote c t i ve f us e for measurement circuitry Maintenance jack for HIOKI use only (This jack is provided for maintenance use. It cannot be used by the customer.) USB Temperature sensor jack *The RM3544 does not include EXT I/O or communications interfaces (RS-232C or USB). Connecting the instrument to a computer via RS-232C or USB • The full range of RM3544 -01 functionality can be controlled from a computer, which can also be used to acquire measurement results. (This capability does not include turning the instrument on and off or configuring certain interface settings.) • By connecting the instrument to a commercially available RS-232C printer, it you can print measured values, including judgment results. • Measured values can be automatically output. By using the instrument’s USB keyboard mode, measured values can be entered into applications such as spreadsheets and text editors without the need to install a special USB driver in the computer. • The sample PC application provides functionality for capturing data based on trigger signals, performing interval measurement, conducting communication tests, and loading captured data into Microsoft® Excel or outputting it as a CSV file. The application can be downloaded from Hioki’s website (http://www.hioki. com). USB/RS-232C Applications screen Communications Monitor screen Communications monitor function for smooth system development The communications monitor function displays communications data (received commands and sent data) on the screen, providing valuable support for programming of programmable logic controllers (PLCs). Enlarged view of communications data Universal power supply for robust accommodation of supply voltage fluctuations and automatic power supply frequency detection (RM3544/RM3544 -01) Measuring in sync with the power line frequency is important for achieving accurate measurements. To avoid measurement problems due to incorrect settings, the power line frequency is automatically sensed and selected (50 or 60 Hz). The universal AC input (90 to 264 V) is practically unaffected by voltage fluctuations, so stable measurements are possible even in poor power environments. 50 Hz / 60 Hz 90 to 264 V 7 Easy integration into automatic testing equipment (RM3544-01) High-speed, comprehensive productivity support Measurement time*1 Measurement speed (ms) FAST MED SLOW • The RM3544-01 delivers the speed demanded by automatic testing equipment at a sophisticated level. The entire process from the start of measurement to outputting of the judgment result takes as little as 18 ms. One cycle of operation, lasting from measurement to judgment output, completes within this time. • The RM3544-01 supports RS-232C data communications at up to 115.2 kbps. • The instrument’s USB interface can also be used. • The EXT I/O output mode can be switched between judgment mode and BCD mode. 50Hz 60Hz 21 18 101 401 Tolerance: ±10% ±2 ms *1 With TC set to ON and the comparator set to ON Functionality for verifying the EXT I/O connection status and testing EXT I/O In addition to allowing you to check EXT I/O signal input on the instrument’s screen, this functionality allows you to turn output signals on or off as desired. This capability simplifies verification work during PLC programming. EXT I/O test function screen When designing a control system using the EXT I/O interface, be sure to read the instruction manual and check the necessary technical information. Handler (EXT I/O) interface The handler interface (EXT I/O) is isolated from measurement circuitry, control circuitry, and the protective ground (chassis ground), providing a high level of noise resistance.   Example of Typical Input Signals Example of Typical EXT I/O Timing (EOM output hold) TRIG 0ADJ PRINT KEY_LOCK BCD_LOW : External trigger : Zero-Adjust : Print : Key-Lock : Lower digit specification when set to BCD output LOAD0 to LOAD3 : Panel number to load IN0, IN1 : General-purpose input pins ON TRIG OFF t0 t1 OFF During processing Measurement processing t2 t3 INDEX OFF EOM OFF ON OFF HI,IN,LO ERR,BCDm-n OFF ON/OFF OFF OFF ON t4 Output Signals HI, IN, LO EOM INDEX ERR HILO BCDm-n t0 : Trigger pulse ON time (0.1 ms or more) t1 : Trigger pulse OFF time (1 ms or more) t2 : Measurement start time (max. 1 ms) t3 : Capture processing time ; FAST(50Hz): 20.0 ms, FAST(60Hz): 16.7 ms, MEDIUM: 100 ms, SLOW: 400 ms t4 : Calculation time ; 1 ms EXT I/O Input and Output Circuits RM3544-01 2kΩ PNP EXT I/O MODE SELECTOR EXT I/O polarity (Select NPN/PNP) Output Circuit RM3544-01 10Ω 1kΩ Input ISO_COM NPN Internally Isolated Common RNG_OUT0 to RNG_OUT3 ISO_5V ISO_COM   EXT I/O Electrical Specifications A switch on the rear panel is used to toggle the input signal polarity between NPN (sink output support) and PNP (source output support) settings depending on the PLC common polarity. Input Circuit (Case of NPN type) OUT0 to OUT2 : Comparator Hi, IN, LO : End of Measurement : End of Import : Measurement Fault Output : Outputs HI or LO when set to BCD output. : Outputs the nth bit of the mth digit when set to BCD output. : General-purpose output pins when set to judgment mode : Outputs range information when set to BCD output. : Internally Isolated 5 V : Internally Isolated Common Output Max. 50 mA DC Zener voltage = 30 V ISO_COM Internally Isolated Common Inputs: Photocoupler isolation: Non-voltage contact inputs (support for current sink output) Input ON: Residual voltage: Max. 1 V @4 mA Input OFF: Open Max. 100 μA Outputs: Photocoupler-isolated open drain output (no-polarity) DC30Vmax, DC50mAmax/ch Residual voltage: Max. 1 V @50 mA, or 0.5 V @10 mA External power output: Output voltage: Sink output support: 5.0V±10%, Source output support: -5.0V±10% Max. output current: 100mA 8 High-accuracy portable RESISTANCE METER measures from µΩ to MΩ RM3548 Features High-precision specs in a portable package(high accuracy of 0.02% rdg.) Design is ideal for maintenance and testing/measurement of large equipment. No warmup period or zero adjustment required. Dramatically improved overvoltage resistance (protection up to 70 V DC) High-precision specs in a portable package Expansive range options Measure from 0.0 μΩ to 3.5000 MΩ 0.1μΩ max. resolution, 0.02% basic accuracy Max. measurable current of 1A Continuity and resistance measurement in large transformers, motors, and power supply equipment The RM3548 uses a high current of 1 A to measure lower resistance values more reliably at a resolution of 0.1 μΩ in applications including measuring resistance in large transformers and motors as well as wiring, busbars and connections in power supply equipment. Verification of continuity of ground lines in automobiles and fuselage welds and caulking in aircraft The RM3548 can be used to check ground connections* in automobiles and fuselage welds and caulking in aircraft using a measurement current of 300 mA (300 mΩ range). 9 Portable, easy to use, and easy to understand Design is ideal for maintenance and testing/ measurement of large products The included strap can be looped around the neck to support the instrument, leaving the operator’s hands free to hold probes for measurement. The meter uses eight AA alkaline batteries, which provide enough power for approximately 10 hours of testing under normal operating conditions. (Operating times vary with measurement conditions.) Auto-hold and auto-memory functionality The RM3548 features auto-hold and auto-memory functionality to automatically hold and record data simply by placing the probes in contact with the desired measurement location. This functionality allows measured values to be recorded automatically as soon as they stabilize without the need for the user to operate any switches. LED COMPARATOR ATTACHMENT By installing the LED COMPARATOR ATTACHMENT close to a probe, you can capture judgment results without moving your eyes away from the measurement location and probe. No zero adjustment Accuracy is defined without any need to perform zero-adjustment. Measurement can be performed as soon as the instrument is turned on. Dramatically improved overvoltage resistance Green light IN state Red light HI/LO state Protection is provided against overvoltage input of up to 70 V, preventing damage caused by connecting the instrument to an electrical charge or by the effects of the counter-EMF from inductance. Offset Voltage Compensation(OVC) Thermal EMF occurs at the contact point of different metals. This voltage affects measurements, and if large enough, can cause measurement errors. The offset voltage compensation function minimizes the effect of thermal EMF to maintain measurement accuracy. Particularly when measuring low resistances where the detection voltage is small, and during low-power resistance measurements, OVC is essential to maintain accuracy. Length conversion function By setting a resistance value per meter, it is possible to convert resistance values into lengths. This capability is useful when managing cable inventory or estimating PCB pattern lengths. Circuit protection detection state (Alerts the operator to overvoltage input with a screen display and an audible warning.) Acquire measured values recorded in the instrument’s memory over a USB connection By connecting the RM3548 to a computer with a USB cable*, you can download measured values stored in the instrument’s memory. *Since the RM3548 provides a mass storage class (read-only) USB interface, there is no need to install special driver software on the computer Temperature conversion function and interval measurement: Useful in temperature-rise testing Temperature increase (Δt) is obtained and displayed by converting resistance measurements and ambient temperature. The maximum temperature increase needs to be determined when current is applied especially for verifying motor windings or transformers.The interval measurement function can be used to take measurements at a user-specified interval from the start of measurement. Since measured values can be recorded in the instrument’s memory, the maximum temperature can be easily estimated. *The temperature conversion function cannot be used simultaneously with the temperature correction function and length conversion function. ➀ When a motor or coil has thermally stabilized at room temperature, measure the resistance (r0) and ambient temperature (t0) before applying current. ➁ Excite the coil, and when the temperature increase appears to saturate, remove the excitation. ➂ After removing excitation, determine the temperature (∆t1 to ∆tn) from the resistance (rt) measured at each specific time (t), and the ambient temperature. ➃ Project the curve through the collected temperature data (∆t1 to ∆tn) to estimate the maximum temperature increase (∆t). 10 Measurement accuracy Resistance measurement accuracy Conditions of guaranteed accuracy • Temperature & humidity: 23 ˚C ±5 ˚C, 80% rh or less (non-condensating) • Accuracy guaranteed for 1 year, Post-adjustment accuracy guaranteed for 1 year • From 0°C to 18°C and from 28°C to 40°C, add (temperature coefficient ±[1/10 measurement accuracy] / °C). RM3544/RM3544 -01 Accuracy = ±(% rdg. + % f.s.) (f.s. = calculated 30,000 dgt., where 0.010% f.s. = 3 dgt.) Max. measurement display*1,*2 35.000 mΩ 350.00 mΩ 3.500 0 Ω 35.000 Ω 350.00 Ω 3.500 0 kΩ 35.000 kΩ 350.00 kΩ 3.500 0 MΩ Range 30 mΩ 300 mΩ 3Ω 30 Ω 300 Ω 3 kΩ 30 kΩ 300 kΩ 3 MΩ (Example) 0.020 + 0.007 ....... 0.020% rdg. + 0.007% f.s. FAST MED/SLOW 0.030+0.080 0.025+0.017 0.025+0.017 0.020+0.010 0.020+0.010 0.020+0.010 0.020+0.010 0.040+0.010 0.200+0.010 0.030+0.070 0.025+0.014 0.025+0.014 0.020+0.007 0.020+0.007 0.020+0.007 0.020+0.007 0.040+0.007 0.200+0.007 Measurement Current*3 300 mA 300 mA 30 mA 10 mA 1 mA 1 mA 100 μA 5 μA 500 nA Open-Circuit Voltage 5.5 Vmax. *1 For negative values, to -10% f.s. *2 The maximum display range is 99,999dgt. *3 Measurement current accuracy is ±5%. RM3548 Accuracy = ±(% rdg. + % f.s.) (f.s. = calculated 30,000 dgt., where 0.010% f.s. = 3 dgt.) 3 mΩ 30 mΩ Max. measurement display*4,*5 3.500 0 mΩ 35.000 mΩ 300 mΩ 350.00 mΩ 3Ω 30 Ω 300 Ω 3 kΩ 30 kΩ 300 kΩ 3 MΩ 3.500 0 Ω 35.000 Ω 350.00 Ω 3.500 0 kΩ 35.000 kΩ 350.00 kΩ 3.500 0 MΩ Range (Example) 0.020 + 0.007 ....... 0.020% rdg. + 0.007% f.s. Accuracy*6 0.100 + 0.200 (0.100 + 0.020) 0.100 + 0.020 (0.100 + 0.010) 0.100 + 0.010 (0.100 + 0.010) 0.020 + 0.020 (0.020 + 0.010) 0.020 + 0.007 (0.020 + 0.007) 0.020 + 0.007 (0.020 + 0.007) 0.020 + 0.007 (0.020 + 0.007) 0.020 + 0.007 0.020 + 0.007 0.040 + 0.007 0.200 + 0.007 Measurement Current*7 Open-Circuit Voltage 1A 300 mA 100 mA 100 mA 10 mA 5.5 Vmax. 1 mA 100 μA 5 μA 500 nA *4 For negative values, to -10% f.s. *5 The maximum display range is the same as the maximum measurement range. *6 Measurement accuracy values assume offset voltage correction (OVC) is ON. *7 Measurement current accuracy is ±5%. * During temperature correction, the value calculated below is added to the rdg. error for resistance measurement accuracy: - αt Δt 0 1 + αt 0 × (t + Δt - t 0) × 100 [%] t 0 : Reference temperature. [ºC] t : Ambient temperature. [ºC] Δt : Temperature. measurement accuracy αt 0 : Temperature. coefficient at t0 is [1/ºC] Temperature measurement accuracy • Temperature • Temperature Sensor Z2001 (for RM3544/RM3544-01) Sensor Z2002 (for RM3548) Range of guaranteed accuracy -10.0 to 99.9 ºC Approx. 2 s Display refresh rate Guaranteed accuracy period 1 year • Temperature Sensor Z2001 and RM3544/RM3544-01 combined accuracy • Temperature Sensor Z2002 and RM3548 combined accuracy Temperature -10.0 ºC to 9.9 ºC 10.0 ºC to 30.0 ºC 30.1 ºC to 59.9 ºC 60.0 ºC to 99.9 ºC t: Temperature measurement values [ºC] Accuracy ± (0.55 + 0.009 × |t-10| ) ºC ± 0.50 ºC ± (0.55 + 0.012 × |t-30| ) ºC ± (0.92 + 0.021 × |t-60| ) ºC Standalone instrument accuracy: ± 0.2 ºC 11 RM3544/RM3544 -01/RM3548 Specifications RM3544/RM3544-01 RM3548 General specifications RM3544/RM3544-01 RM3548 Measurement types Measurement method Range switching Temperature correction Zero-adjustment Trigger Measurement speed Display refresh rate Delay Functions Measurement fault detection functions Averaging Panel store, panel load Memory storage Interfaces Communication interfaces Communication function RS-232C USB Printer Operating temperature and humidity Storage temperature and humidity Operating environment Power supply Continuous operating time Rated power consumption Resistance measurement: 0.000 mΩ (30 mΩ range) to Resistance measurement: 0.0000 mΩ (3 mΩ range) to 3.500 0 MΩ (3 MΩ range), 9 ranges 3.500 0 MΩ (3 MΩ range), 10 ranges Temperature measurement (thermistor): -10.0 to 99.9°C Temperature measurement (thermistor): -10.0 to 99.9°C 4-terminal direct current (constant current), banana plug,with 4-terminal direct current (constant current), banana plug guard terminal Auto or Manual Reference temperature setting range: -10°C to 99.9°C, Temperature coefficient setting range: -9999 ppm/°C to +9999 ppm/°C Within -3% to 50% f.s. of each range. (f.s.= 30000 dgt.) Within ±3% f.s. of each range (f.s.= 30000 dgt.) Internal trigger RM3544: Internal trigger, RM3544 -01: Internal or external FAST (50 Hz:21 ms, 60 Hz:18 ms) / MED (101 ms) / SLOW (401 ms) Fixed N/A Without OVC: approx. 100 ms, With OVC: approx. 230 ms N/A Internal fixed value: / 10 to 1000 ms (7 settings) Temperature correction, comparator (ABS/REF%), key-lock Temperature correction, temperature conversion, offset volt(OFF, menu lock, all lock), display digit count selection funcage compensation (OVC), comparator (ABS/REF%), length tion (5 digits/4 digits), automatic power supply frequency setconversion, judgment sound setting, auto hold, auto power tings (AUTO/50 Hz/60 Hz), scaling, judgment sound setting, save (APS) auto hold Over-range detection, current fault detection, fuse trip detec- Over-range detection, current fault detection, circuit protection tion detection function, fuse trip detection OFF, 2 to 100 averaging iterations (variable in 1-iteration steps) OFF, 2/5/10/20 averaging iterations 10 9 Panel save parameters: resistance measurement ranges, measurement speed, average, comparator, judgment sound, scaling, temperature correction(TC), auto hold, zero-adjust Manual, Auto memory, interval memory Number of blocks: 10 Number of recordable data points: (manual/auto) Up to 1000, N/A (interval) Up to 6000 Interval: 0.2 to 10.0 s (0.2 s steps) Acquisition of data from memory: display, USB mass storage (CSV, TXT files) RM3544 -01: EXT I/O, Communication interface Communication interface RM3544 -01: USB Select from RS-232C, PRINTER(RS-232C), or USB Remote function, communications monitor function, data N/A output function Bit rates: 115200 / 38400 / 19200 / 9600 bps N/A Class: CDC (COM mode), HID (USB keyboard mode) Class: USB mass storage class (read-only) Operation: Prints at PRINT signal or PRINT key input. Printed data: Resistance measurement values, temperature measurement values, judgment results, measurement conditions N/A Interval: ON/OFF Interval times: 1 to 3600 s (variable in 1 s steps) Number of print columns per row: 1 or 3 0 to 40ºC, 80% rh or less (non-condensating) –10 to 40ºC, 80% rh or less (non-condensating) Indoors, Pollution Degree 2, up to 2000 m ASL Rated supply voltage: 100 to 240 VAC ±10% Rated supply frequency: 50/60 Hz N/A 15 VA max. 1.62 kV AC for 1 min. (with 10 mA cutoff current) between all mains supply terminals and protective ground, interfaces, and measurement jacks Approx. 215W × 80H × 166D mm (8.46"W × 3.15"H × 6.54"D) Dimensions (without projections) RM3544: Approx. 0.9 kg (31.7 oz) Mass RM3544 -01:Approx. 1.0 kg (35.3 oz) RM3544: Power cord ×1, CLIP TYPE LEAD L2101 ×1, instruction manual ×1, spare fuse ×1 RM3544 -01: Power cord ×1, CLIP TYPE LEAD L2101 ×1, Accessories male EXT I/O connector ×1, instruction manual ×1, application disc ×1, USB cable (A-to-B type) ×1, spare fuse ×1 Safety: EN61010 Applicable standards EMC: EN61326, EN61000-3-2, EN61000-3-3 DC1.5V × 8 (LR6 alkaline battery × 8) 1 s measurements over 10 s in 3 mΩ range: Approx. 10 hours (when using new alkaline batteries) 5 VA max. Insulation withstand potential N/A Approx. 192W × 121H × 55D mm (7.56"W × 4.76"H × 2.17"D) (without projections) Approx. 0.77 kg (27.2 oz.) CLIP TYPE LEAD L2107 ×1, TEMPERATURE SENSOR Z2002 ×1, LR6 alkaline battery × 8, instruction manual ×1, USB cable(A-to-mini B type) ×1, strap ×1, spare fuse ×1 Safety: EN61010 EMC: EN61326 Model Configurations and Options RESISTANCE METER RM3544 Model : RESISTANCE METER RM3544 Model No. (Order Code) (Note) RM3544-01 RM3544 RM3544-01 RM3544-01 (No interfaces) (with EXT I/O, RS-232C, USB) Accessories: [RM3544] Power cord ×1, Clip type lead L2101 ×1, Instruction manual ×1, Spare fuse ×1, [RM3544-01] Power cord ×1, Clip type lead L2101 ×1, Male EXT. I/O connector ×1, Instruction manual ×1, Application disc ×1, USB cable (A-to-B type) ×1, Spare fuse ×1 Caution when considering the use of probes without guard terminals Proper operation of the RM3544 is not guaranteed when using test leads (test probes) that lack guard terminals, for example test leads used with models such as the Resistance HiTester 3541 or mΩ HiTester 3540. Please use the test leads indicated in the RM3544 accessory and option documentation. *The L2101 is bundled with the RM3544 series A: Variable length up to 1.1 m (3.61 ft) Max., B:178 mm (7.01 in), L:1.5 m (4.92 ft) A: Variable length up to 1.1 m (3.61 ft) Max., B:83 mm (3.27 in), L:1.5 m (4.92 ft) A: From junction to probe B: Probe part L: Whole length Note: The L2101 to L2104 leads are variable length from junction to probe (A), up to 1.1 m (3.61 ft) Max. 2 m (6.56 ft) length TEMPERATURE SENSOR A: Variable length up to 1.1 m (3.61 ft) Max., Z2001 A: Variable length up to 1.1 m (3.61 ft) Max., B:176 mm (6.93 in), L:1.5 m (4.92 ft) B:118 mm (4.65 in), L:1.5 m (4.92 ft) 1.75 m (5.74 ft) length About probe length LED COMPARATOR ATTACHMENT L2105 4 -TERMINAL LEAD L2104 PIN TYPE LEAD L2103 PC Communication Measurement Leads / Input scanner PIN TYPE LEAD L2102 CLIP TYPE LEAD L2101 *For the RM3544-01 RS-232C CABLE 9637 RS-232C CABLE 9638 For the PC, 9pin - 9pin, cross, 1.8m (5.91 ft) length For the PC, 9pin - 25pin, cross, 1.8m (5.91 ft) length RESISTANCE METER RM3548 Model : RESISTANCE METER RM3548 Model No. (Order Code) RM3548 Accessories: Clip type lead L2107 ×1, Temperature sensor Z2002 ×1, LR6 Alkaline battery ×8, Instruction manual ×1, USB Cable(A-to-mini B type) ×1, Strap ×1, Spare fuse ×1 *The L2107, Z2002 are bundled with the RM3548 Measurement Leads CLIP TYPE LEADS L2107 LARGE CLIP TYPE LEAD 9467 PIN TYPE LEAD 9772 PIN TYPE LEAD 9465-10 TIP PIN 9465 -90 TIP PIN 9772-90 FOUR TERMINAL LEAD 9453 A: 80 mm (3.15 in) (red), 140 mm (5.51 in) To replace the tip on the A: 80 mm (3.15 in) (red), 140 mm (5.51 in) To replace the tip on the A:300 mm (11.81 in), B:116 mm (4.57 in), A: Variable length up to 1.1 m (3.61 ft) A:280 mm (11.02 in), B:118 mm (4.65 Max., B:83 mm (3.27 in), L:1.1 m (3.61 ft), in), L:1360 mm (4.46 ft), 60V DC 70 VDC 100 mm (3.94 in) LED COMPARATOR ATTACHMENT L2105 For RM3544s/3545s/3548, 2 m (6.56 ft) 9465-10, (one piece) (black, max. 550 mm (21.65 in)), B: 118 mm (4.65 in), L: 1780 mm (5.84 ft) 9772, L2100, (one piece) L:1360 mm (4.46 ft), 50V DC About probe length ZERO ADJUSTMENT BOARD 9454 For the L2100, 9465-10, 9465, 9461 A: From junction to probe B: Probe part L: Whole length Note: The L2107 lead is variable length from junction to probe (A), up to 1.1 m (3.61 ft) Max. Case TEMPERATURE SENSOR Z2002 (black, max. 550 mm (21.65 in)), B: 121 mm (4.76 in), L: 1883 mm (6.18 ft) CARRYING CASE C1006 For the RM3548 Note: Company names and Product names appearing in this catalog are trademarks or registered trademarks of various companies. DISTRIBUTED BY HEADQUARTERS 81 Koizumi, Ueda, Nagano 386-1192 Japan https://www.hioki.com/ All information correct as of Sept. 13, 2019. All specifications are subject to change without notice. RM3544_RM3548E11-99M Printed in Japan
HIOKI 9465-90. 价格&库存
很抱歉,暂时无法提供与“HIOKI 9465-90.”相匹配的价格&库存,您可以联系我们找货
