Telephone +44 (0)1493 602602
Fax +44 (0)1493 665111
Email:sales@midassensors.com
www.midassensors.com
Electra House, 32 Southtown Road
Great Yarmouth, Norfolk
NR31 0DU, England
PROWAVE
Air Ultrasonic Ceramic Transducers
328ET/R250
Dimensions: dimensions are in mm
Impedance/Phase Angle vs. Frequency
Specification
Transmitter
328ER250
Receiver
Center Frequency
32.8±1.0Khz
Bandwidth (-6dB) 328ET250
1.0Khz
328ER250
1.0Khz
Max. Driving Voltage (cont.)
90
75
60
45
30
15
-30
-45
-60
-75
-90
10000
1000
100
28
29
30
31
32
33
34
35
38
Sensitivity/Sound Pressure Level
-67dB min.
2400 pF
20Vrms
Storage Temperature
-40 to 85°C
33° typical
All specification taken typical at 25°C
Closer frequency tolerance can be supplied
upon request.
-50
130
-55
125
-60
120
-65
115
-70
110
-75
105
-80
100
-85
95
-90
90
28
29
30
31
32
33
34
35
37
Frequency (Khz)
Beam Angle: Tested at 32.8Khz frequency
330
300
Model available:
270
-12
-18
-24
-30
30
60
90
240
Aluminum Housing
Black Alum. Housing
36
120
210
180
150
38
SPL (dB)
Tested under 10Vrms @30cm
-30 to 80°C
328ET/R250
328ET/R25B
37
113dB min.
-6dB
Total Beam Angle
Operation Temperature
1
2
36
Frequency (Khz)
Sensitivity (dB)
Transmitting Sound Pressure
Level
at 32.8Khz; 0dB re 0.0002µbar
per 10Vrms at 30cm
Receiving Sensitivity
at 32.8Khz 0dB = 1 volt/µbar
Capacitance at 1Khz ±20%
Impedance (Ohm)
100000
328ET250
Phase Angle (Degree)
Tested under 1Vrms Oscillation Level
328ER250 Impedance
328ER250 Phase
328ET250 Impedance
328ET250 Phase
PROWAVE
328ET/R250
328ET250 Transmitter
Sensitivity Variation vs. Loaded Resistor
SPL Variation vs. Driving Voltage
-40
130
-45
125
-50
120
-55
115
SPL (dB)
Sensitivity (dB)
328ER250 Receiver
-60
-65
110
100
-75
95
-80
Max. Driving Voltage (Cont.) 20Vrms
105
-70
90
1K
3.9K
10K
39K
100K
390K
4
6
8
10
12
Loaded Resistor (Ohm)
18
24
26
28
30
Center Frequency Shift vs. Driving Voltage
0.0
-1.0
Fc Variation %
Fc Variation %
5.0
4.0
3.0
2.0
1.0
0.0
-1.0
-2.0
-3.0
-4.0
-5.0
-2.0
-3.0
-4.0
-5.0
-6.0
-7.0
1K
3.9K
10K
39K
100K
390K
4
6
8
10
12
14
16
18
24
26
28
30
Vrms
Sensitivity Variation vs. Temperature
SPL Variation vs. Temperature
-40
130
-45
125
-50
120
-55
115
SPL (dB)
Sensitivity (dB)
16
Vrms
Center Frequency Shift vs. Loaded Resistor
-60
-65
110
105
-70
100
-75
95
-80
90
-40 -30
-20 -10
40
50
60
70
80
90
100
-40 -30 -20 -10
Temperature (Degree C)
Fc Variation %
40
50
40
50
60
70
80
90
100
Center Frequency Shift vs. Temperature
5.0
4.0
3.0
2.0
1.0
0.0
-1.0
-2.0
-3.0
-4.0
-5.0
-40 -30 -20 -10
10
Fc Variation %
14
60
70
80
90
100
5.0
4.0
3.0
2.0
1.0
0.0
-1.0
-2.0
-3.0
-4.0
-5.0
-40 -30 -20 -10
40
50
60
70
80
90
100
很抱歉,暂时无法提供与“328ER250”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+127.40289
- 10+114.65635
- 100+105.73169
