500MB120
500MB120
    PROWAVE(普崴電子)
500MB120 数据手册
Telephone +44 (0)1493 602602 Fax +44 (0)1493 665111 Email:sales@midassensors.com www.midassensors.com Electra House, 32 Southtown Road Great Yarmouth, Norfolk NR31 0DU, England Air Ultrasonic Ceramic Transducers 500MB120 Dimensions: dimensions are in mm Impedance/Phase Angle vs. Frequency Specification Dual Transducer Center Frequency 90 75 60 45 30 15 0 -15 -30 -45 -60 -75 -90 10000 1000 50.0±1.0Khz 100 45 Bandwidth (-6dB) 3Khz Transmitting Sound Pressure Level at 50.0Khz; 0dB re 0.0002µbar per 10Vrms at 30cm Receiving Sensitivity at 50.0Khz 0dB = 1 volt/µbar Sensitivity/Cross Talk Ratio 113dB min. 46 47 48 49 50 51 52 53 54 55 Frequency (Khz) Sensitivity/Sound Pressure Level Tested under 10Vrms @30cm -50 130 -55 125 -60 120 -65 115 -70 110 -75 105 1000 Ohm -80 100 -85 95 Capacitance at 1Khz ±20% 2400 pF -90 Max. Driving Voltage (cont.) 20Vrms Nominal Impedance (Trans.) Total Beam Angle -6dB 15 dB 30° Sensitivity (dB) -67dB min. 90 45 46 47 48 -20 to 70°C Storage Temperature -40 to 80°C 50 51 52 53 54 55 Beam Angle: Tested at 50.0Khz frequency 300 270 All specification taken typical at 25°C Closer frequency tolerance can be supplied upon request. 49 Frequency (Khz) 330 Operation Temperature SPL (dB) 500MB120 Impedance (Ohm) 100000 Phase Angle (Degree) Tested under 1Vrms Oscillation Level Transmitter Impedance Transmitter Phase Receiver Impedance Receiver Phase 0 0 -6 -12 -18 -24 -30 30 60 90 240 120 210 180 150 Supplied by Midas Components Ltd - 01493 602602 - www.midascomponents.co.uk
500MB120
- 物料型号: 500MB120 - 器件简介: 该换能器是一款双工超声波陶瓷换能器。 - 参数特性: - 中心频率: 50.0±1.0Khz - 带宽(-6dB): 3Khz - 发射声压级: 至少113dB (在50.0Khz; 0dB re 0.0002pbar per 10Vrms at 30cm) - 接收灵敏度: -67dB min. (在50.0Khz OdB = 1 volt/ubar) - 灵敏度/串扰比: 15 dB - 标称阻抗(发射): 1000 Ohm - 电容: 2400 pF (在1Khz ±20%) - 最大驱动电压(连续): 20Vrms - 总波束角度-6dB: 30° - 工作温度: -20 to 70°C - 存储温度: -40 to 80°C - 功能详解: 该换能器设计用于空气介质中,具有高声压级和高接收灵敏度,适用于需要高声学性能的应用。 - 应用信息: 适用于空气介质中的超声波应用,如距离测量、物体检测等。 - 封装信息: 提供了换能器的尺寸图,但具体尺寸数值未在摘要中显示。
500MB120 价格&库存
很抱歉,暂时无法提供与“500MB120”相匹配的价格&库存,您可以联系我们找货
500MB120
    • 1+173.57784
    • 10+156.17632
    • 100+144.05461
    库存:160
