400EP25U
400EP25U
    PROWAVE(普崴電子)
    PROWAVE - 400EP25U - Ultrasonic Transducer, 40 kHz, -72 dB Sensitivity, 30 Deg Beam
400EP25U 数据手册
Pro-Wave Electronics Corp. Total Ultrasonic Solution 1 Scope The Pulse/Tone Burst transducer is designed for echo ranging systems requiring a shorter ringing characteristic when comparing to our standard type transducers. 2 Part Number 400EP25U Pulse Transit Enclose Type Ultrasonic Transducer 3 Dimension As per Figure 4 4 Specification (rated at temperature 25±3℃, 45 to 60% RH, unless otherwise noted) Items 4-1 Center Frequency Specification 40.0KHz Remarks ±1.0KHz 4-2 Sound Pressure Level 110dB (min) at resonant frequency ; 0dB re 0.0002µbar per 10Vrms at 30cm 10Vrms sine wave input detail see attached Figure 1 4-3 Sensitivity -72dB (min) at resonant frequency; 0dB re 1Volt/µbar detail see attached Figure 2 4-4 Bandwidth 2.5KHz (min) -6dB (Figure Of Merit) 4-5 Capacitance 4-6 Total Beam Angle 30° (TYP.) -6dB main beam 4-7 Max. Driving Voltage 100Vp-p 20 bursts maximum, 30ms repetition rate 4-8 Housing Material Aluminum 4-9 Operation Temperature -30℃ to +70℃ 4-10 Storage Temperature 2700pF ±20%, measured at 1KHz -40℃ to +80℃ 1 Pro-Wave Electronics Corp. Total Ultrasonic Solution 5 Environmental Characteristics 5-1 Overall echo sensitivity shall not change by more than ±3dB in the temperature range of -30℃ to 70℃, at a relative humidity of ±50% 5-2 Overall echo sensitivity shall not change by more than ±3dB in the humidity range of 10% to 90% at the temperature of 25℃ 5-3 Overall echo sensitivity shall be within ±3dB of the specified values after the device is subjected to any or all of the belows 5-3-1 Operation at 90% relative humidity and 40℃ for 100 hours, followed by a normalization period of 24 hours at 30% and 25℃ 5-3-2 Storage at -40℃ to + 80℃ for 24 hours followed by a normalization period of an hour at 25℃ 5-3-3 Vibration at 10 to 55Hz, 1.5mm amplitude. 1 minute sweep. X, Y, Z, 3 each axis for 3 hours. 5-3-4 Shock: After impact of 50G is applied following. X, Y, Z, 3 axis /3 cycle / each direction. 6 Mechanical Characteristics Lead strength To pull longitudinally 1.0 kgf min. To push longitudinally 1.0 kgf min. 7 Warranty 7-1 Warranty period is one year after delivery 7-2 Defective transducers attributable to manufacturer’s responsibility shall be replaced for free, during the warranty period. However, following cases are out of the this replacement. 7-2-1 Unsuitable handling or misuse by user. 7-2-2 Modification or repair by user. 7-2-3 Any other cases not responsible for manufacturer such as natural calamity, accident, etc. This warranty covers only replacement. Any loss derived from failure or malfunction of the transducer, or cost to replace is excluded from this warranty. 2 Pro-Wave Electronics Corp. Total Ultrasonic Solution Sound Pressure Level measuring system: Figure 1 Sensitivity measuring system: Figure 2 3 Pro-Wave Electronics Corp. Total Ultrasonic Solution Echo Senitivity Test Circuit: Figure 3 Dimensions: unit mm Figure 4 4
400EP25U 价格&库存
很抱歉,暂时无法提供与“400EP25U”相匹配的价格&库存,您可以联系我们找货
400EP25U
    库存:14
    400EP25U
      • 1+171.18266
      • 10+154.08314
      • 100+142.10722
      库存:140
