Telephone +44 (0)1493 602602
Fax +44 (0)1493 665111
Email:sales@midassensors.com
www.midassensors.com
Electra House, 32 Southtown Road
Great Yarmouth, Norfolk
NR31 0DU, England
PROWAVE
Air Ultrasonic Ceramic Transducers
250ST/R180
Dimensions: dimensions are in mm
Impedance/Phase Angle vs. Frequency
Tested under 1Vrms Oscillation Level
250SR180 Impedance
250SR180 Phase
250ST180 Impedance
250ST180 Phase
250ST180
Transmitter
250SR180
Receiver
Center Frequency
25.0±1.0Khz
Bandwidth (-6dB) 250ST180
1.5Khz
250SR180
1.8Khz
Transmitting Sound Pressure
Level
at 25.0Khz; 0dB re 0.0002µbar
per 10Vrms at 30cm
Receiving Sensitivity
at 25.0Khz 0dB = 1 volt/µbar
Capacitance at 1Khz ±20%
112dB min.
Max. Driving Voltage (cont.)
20Vrms
Impedance (Ohm)
100000
90
75
60
45
30
15
-30
-45
-60
-75
-90
10000
1000
100
22
23
24
25
26
27
30
Sensitivity/Sound Pressure Level
Storage Temperature
-40 to 85°C
95° typical
All specification taken typical at 25°C
Closer frequency tolerance can be supplied
upon request.
-50
130
-55
125
-60
120
-65
115
-70
110
-75
105
-80
100
-85
95
-90
90
22
23
25
26
27
Beam Angle
Tested at 25.0Khz frequency
330
270
-12
-18
-24
-30
30
60
90
240
Aluminum Housing
Black Al. Housing
28
Frequency (Khz)
300
Model available:
24
120
210
180
150
29
30
SPL (dB)
2400 pF
Sensitivity (dB)
-62dB min.
-30 to 80°C
250ST/R180
250ST/R18B
29
Frequency (Khz)
Tested under 10Vrms @30cm
-6dB
Total Beam Angle
Operation Temperature
1
2
28
Phase Angle (Degree)
Specification
PROWAVE
250ST/R180
250ST180 Transmitter
Sensitivity Variation vs. Loaded Resistor
SPL Variation vs. Driving Voltage
-40
130
-45
125
-50
120
-55
115
SPL (dB)
Sensitivity (dB)
250SR180 Receiver
-60
-65
110
105
-70
100
-75
95
-80
90
1K
3.9K
10K
39K
100K
390K
4
6
8
10
12
Loaded Resistor (Ohm)
10K
39K
100K
390K
22
24
26
28
30
2
4
6
8
10
12
14
16
18
24
26
28
30
Vrms
Sensitivity Variation vs. Temperature
SPL Variation vs. Temperature
-40
130
-45
125
-50
120
-55
115
SPL (dB)
Sensitivity (dB)
-0.5
-1.0
-1.5
-2.0
-2.5
-3.0
-3.5
-4.0
-4.5
-5.0
-5.5
-6.0
-60
-65
110
105
-70
100
-75
95
-80
90
-40 -30
-20 -10
40
50
60
70
80
90
100
-40 -30 -20 -10
Temperature (Degree C)
Fc Variation %
40
50
40
50
60
70
80
90
100
Center Frequency Shift vs. Temperature
5.0
4.0
3.0
2.0
1.0
0.0
-1.0
-2.0
-3.0
-4.0
-5.0
-40 -30 -20 -10
10
Fc Variation %
18
Center Frequency Shift vs. Driving Voltage
Fc Variation %
Fc Variation %
5.0
4.0
3.0
2.0
1.0
0.0
-1.0
-2.0
-3.0
-4.0
-5.0
3.9K
16
Vrms
Center Frequency Shift vs. Loaded Resistor
1K
14
60
70
80
90
100
5.0
4.0
3.0
2.0
1.0
0.0
-1.0
-2.0
-3.0
-4.0
-5.0
-40 -30 -20 -10
40
50
60
70
80
90 100
很抱歉,暂时无法提供与“250SR180”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+51.95464
- 10+46.77896
- 100+43.15494
- 500+40.05162
- 1000+39.23934
