34233
34233
    MENDA
    CONN CVR 0.413ID 0.483"OD 1000PC
34233 数据手册
Made in the United States of America Conductive C-Type Connector Cover Features: Conductive Composite Permanently volume conductive and free of carbon black particulate. The connector covers do not leave black marks and are more suited to clean situations. Meets the requirements of NASM5501 31/32. Noncorrosive Connector covers are noncorrosive and produce no visible corrosion when tested to Federal Test Method 101C using Kovar test plates. Conformability The polyethylene material used in the covers was selected for its resilience. Properly sized, the covers provide a snug, secure fit. This helps keep connectors clean and prevents the cover from accidentally falling off. Item No. Size “A” “B” “C” “D” Item No. Packaged 50/pack; 10 packs/case 34216 20R 1.465" 0.562" 1.231" 1.301" 34217 20Y 1.406" 0.625" 1.15" 1.215" 34218 22R 1.59" 0.562" 1.34" 1.41" 34219 22Y 1.5" 0.625" 1.27" 1.34" 34220 24R 1.7" 0.562" 1.463" 1.533" 34221 24Y 1.64" 0.625" 1.39" 1.46" 34222 25Y 1.81" 0.625" 1.54" 1.58" 34223 28R 1.95" 0.562" 1.715" 1.79" 34224 28Y 1.875" 0.625" 1.645" 1.718" Item No. Size “A” “B” “C” “D” Packaged 25/pack; 10 packs/case ESD sensitive device symbol M5501/31A 1469 Unless otherwise noted, tolerance ± 10% Specifications and procedures subject to change without notice. “B” “C” “D” 34205 10R 0.84" 0.5" 0.605" 0.665" 34206 10Y 0.75" 0.625" 0.53" 0.595" 34207 12R 0.97" 0.5" 0.72" 0.755" 34208 12Y 0.86" 0.625" 0.655" 0.715" 34209 14R 1.125" 0.5" 0.85" 0.905" 34210 14Y 1.031" 0.625" 0.785" 0.845" 34211 16R 1.22" 0.5" 0.973" 1.035" 34212 16Y 1.125" 0.625" 0.893" 0.963" 34213 18R 1.33" 0.562" 1.093" 1.155" 34214 18Y 1.25" 0.625" 1.03" 1.088" 34215 19R 1.4" 0.562" 1.125" 1.213" 34229 4R 0.67" 0.5" 0.25" 0.336" 32R 2.22" 0.562" 1.965" 2.04" 34230 5R 0.67" 0.5" 0.313" 0.399" 34226 32Y 2.125" 0.625" 1.89" 1.97" 34231 6R 0.67" 0.5" 0.375" 0.461" 34227 36R 2.435" 0.6" 2.215" 2.29" 34232 8R 0.74" 0.5" 0.48" 0.54" 34228 36Y 2.34" 0.625" 2.14" 2.21" 34233 8Y 0.67" 0.625" 0.413" 0.483" 34234 9R 0.75" 0.5" 0.5" 0.586" Chemical Susceptibility* Reactions Material Properties Test Method Typical Value Dilute Acids Slight Attack Resistance ASTM D991
34233 价格&库存
很抱歉,暂时无法提供与“34233”相匹配的价格&库存,您可以联系我们找货
