35843
35843
    MENDA
    ELEC VAC PORTABLE 230VAC W/ACC
35843 数据手册
TECHNICAL BULLETIN TB-4013 Blow Vac Vacuum Operation and Maintenance 35840 Figure 1: Menda® 35841 Blow Vac Description The MENDA Blow Vac is a compact, dual function unit which is totally made up of ESD Safe housing parts and accessories. It is designed for precise removal and collection of dry dust particles and debris from equipment that is sensitive to electrostatic discharge (ESD). Dissipative thermoplastic rubber stretch hose with a steel conductive spring wire to remove electrostatic charges via the dissipative housing and ground wire plugged into a three-wire AC electrical outlet. The Blow Vac can also be converted in seconds into a powerful blower for dust removal in areas otherwise not accessible. You simply need to attach the optional two part blow assembly attachment, MENDA Part Number 35836. The Blow Vac has been specially made with a dissipative housing and attachments/accessories. All are groundable per S20.20
35843 价格&库存
很抱歉,暂时无法提供与“35843”相匹配的价格&库存,您可以联系我们找货
