DSK290606
DSK290606
    OTHER
DSK290606 数据手册
Encoder accessories Enco der accesso ries (PDF 139 KB) DSK29 Double loop coupling DSK29 fo r enco der with shaft Ø 6 mm, 8 mm o r 10 mm. No mo ving parts, thermally and electrically insulating, smo o th running, maintenance-free. Go o d resistance to Gaso line, o il, benzene, to luene, aro matic and no n aro matic hydro carbo ns, alco ho ls, glyco ls, so lvents and many chemicals. Print versio n Pro duct dat a Max. o perating speed 30 0 0 rpm Max. to rque 50 Ncm Max. o ffset o f shafts radial ±2.0 mm Max. o ffset o f shafts axial ±2.0 mm Max. o ffset o f shafts angular ±10 ° To rsio n spring stiffness 13 Nm/rad Radial spring stiffness 13 N/mm Mo ment o f inertia 41 gcm² Max. clamping to rque 10 0 Ncm Weight 33 g PDFmyURL.com Material flange: steel galvanized co necting element: po lyurethane Operating temperature -30 °C up to +8 0 °C Order number(s) DSK29 0 6 0 6 do uble lo o p co upling: Ø d1 = 6 mm, Ø d2 = 6 mm DSK29 0 6 10 do uble lo o p co upling: Ø d1 = 6 mm, Ø d2 = 10 mm DSK29 0 8 10 do uble lo o p co upling: Ø d1 = 8 mm, Ø d2 = 10 mm DSK29 0 8 0 8 do uble lo o p co upling: Ø d1 = 8 mm, Ø d2 = 8 mm DSK29 10 10 do uble lo o p co upling: Ø d1 = 10 mm, Ø d2 = 10 mm Drawings All dimensio nal specificatio ns in mm Fo r further info rmatio n please co ntact o ur lo cal distributo r. PDFmyURL.com Here yo u find a list o f o ur distributo rs wo rldwide Wachendo rff Auto matio n GmbH & Co . KG - Industriestrasse 7 - D-6 536 6 Geisenheim wdg@wachendo rff.de - Tel. +49 6 722 9 9 6 525 - Fax +49 6 722 9 9 6 570 PDFmyURL.com
DSK290606 价格&库存
很抱歉,暂时无法提供与“DSK290606”相匹配的价格&库存,您可以联系我们找货
