DSK481010
DSK481010
    OTHER
DSK481010 数据手册
Encoder accessories Enco der accesso ries (PDF 139 KB) DSK48 Double loop coupling DSK48 fo r enco der with shaft Ø 10 mm, 12 mm o r 14 mm. No mo ving parts, thermally and electrically insulating, smo o th running, maintenance-free. Go o d resistance to Gaso line, o il, benzene, to luene, aro matic and no n aro matic hydro carbo ns, alco ho ls, glyco ls, so lvents and many chemicals. Print versio n Pro duct dat a Max. o perating speed 30 0 0 rpm Max. to rque 20 0 Ncm Max. o ffset o f shafts radial ±3.0 mm Max. o ffset o f shafts axial ±4.0 mm Max. o ffset o f shafts angular ±12° To rsio n spring stiffness 28 Nm/rad Radial spring stiffness 7 N/mm Mo ment o f inertia 10 6 gcm² Max. clamping to rque 20 0 Ncm Weight 85 g PDFmyURL.com Material flange: steel galvanized co necting element: po lyurethane Operating temperature -30 °C up to +8 0 °C Order number(s) DSK48 10 10 do uble lo o p co upling: Ø d1 = 10 mm, Ø d2 = 10 mm DSK48 10 12 do uble lo o p co upling: Ø d1 = 10 mm, Ø d2 = 12 mm DSK48 1212 do uble lo o p co upling: Ø d1 = 12 mm, Ø d2 = 12 mm Drawings All dimensio nal specificatio ns in mm PDFmyURL.com Fo r further info rmatio n please co ntact o ur lo cal distributo r. Here yo u find a list o f o ur distributo rs wo rldwide Wachendo rff Auto matio n GmbH & Co . KG - Industriestrasse 7 - D-6 536 6 Geisenheim wdg@wachendo rff.de - Tel. +49 6 722 9 9 6 525 - Fax +49 6 722 9 9 6 570 PDFmyURL.com
DSK481010 价格&库存
很抱歉,暂时无法提供与“DSK481010”相匹配的价格&库存,您可以联系我们找货
