250-0577-00
250-0577-00
    FLIR(菲力尔)
250-0577-00 数据手册
E A S Y-T O - I N T E R FA C E E VA L U AT I O N BOARD FLIR Lepton® Camera Breakout Board v2.0 The FLIR Lepton® Thermal Camera Breakout Board is an easy-to-interface evaluation board to quickly connect all versions of the FLIR Lepton camera module to common platforms like Raspberry Pi* or custom hardware such as mobile development kits. It provides on-board power supplies, generated from 3 – 5.5V, and a master clock. Local power supplies, the master clock and the power-up sequence components can all be by-passed using a jumper. Lepton sold separately or in a kit through major electronic component distributors worldwide. PN: 250-0577-00 www.flir.com/lepton-bob 10.5mm 7.14mm 12.7mm Lepton® Module SIZE, WEIGHT AND POWER (SWAP) EASE OF INTEGRATION APPLICATIONS • Operating temperature 0°C to 55°C • Access to SPI and I2C camera module interfaces • Rugged and Mobile Devices • Input Voltage: 3 V to 5.5 V • Provides 25-MHz reference clock (can be by-passed) • Smart Buildings and Smart Cities Enhanced Features • Space-Saving, (29.5 mm × 29.0 mm) • Works with all FLIR Lepton modules ® Faster time to market • Power Efficient 1.2 V core voltage (can be by-passed) • Dual Low Noise LDO for 2.8 V voltage (can be by-passed) • 32-pin Molex camera socket for Lepton® Module *Raspberry Pi is a trademark of the Raspberry Pi Foundation. This product is not designed or qualified for production use. Designed for applications where SWaP, cost, and quality are critical • Motion Sensor • Gesture Recognition S P E C I F I C AT I O N S 35.0 mm 29.0 mm Mechanical 29.5 mm Thickness including Molex socket and jumper pins but excluding the Lepton: 15mm. Figure 1. Mounting hole locations. Electrical Schematic: 250-0577-24_R120 Assembly drawing: 250-0577-25_R120 The Lepton breakout board comes with jumpers on J5 – J9 installed. With all jumpers installed Lepton can be operated from J2 with 3-5V on J2 pin2. Jumpers J5 – J9 can be removed to provide control individual voltage, master clock or power up sequence externally. Pin-Out Pin # Function Pin # Function Pin 1 GND Pin 2 Power in 3 – 5.5V Pin 3 VPROG Pin 4 VCC28 Pin 5 SDA Pin 6 VCC28_IO Pin 7 SPI_CLK Pin 8 SCL Pin 9 SPI_MOSI Pin 10 SPI_CS Pin 11 GPIO0 Pin 12 SPI_MISO Pin 13 GPIO2 Pin 14 GPIO1 Pin 15 GPIO3 / VSYNC Pin 16 VCC12 Pin 17 RESET_L Pin 18 MASTER_CLK Pin 19 GND Pin 20 PW_DWN_L Specifications are subject to change without notice. For the most up-to-date specs, go to www.flir.com CORPORATE HEADQUARTERS FLIR Systems, Inc. 27700 SW Parkway Ave. Wilsonville, OR 97070 USA SANTA BARBARA FLIR Systems, Inc. 6769 Hollister Ave. Goleta, CA 93117 www.flir.com NASDAQ: FLIR Equipment described herein is subject to US export regulations and may require a license prior to export. Diversion contrary to US law is prohibited. Imagery for illustration purposes only. Specifications are subject to change without notice. ©2019 FLIR Systems, Inc. All rights reserved. 08/19 19-1617-OEM
250-0577-00 价格&库存
很抱歉,暂时无法提供与“250-0577-00”相匹配的价格&库存,您可以联系我们找货
  • 1+631.935881+81.66640
库存:222
250-0577-00
