FB29B0606
FB29B0606
    WACHENDORFF
    WACHENDORFF - FB29B0606 - Coupling, FB29B Series, Bellows Type, 10000 rpm, 80 Ncm, 6 mm Diameter Sha...
FB29B0606 数据手册
Wachendorff Automation encoders : Bellows coupling FB29B Encoder accessories FB29B Bellows coupling FB29B for encoder with shaft Ø 6 mm, 10 mm.  Product data Max. operating speed 10000 rpm Max. torque 80 Ncm Max. offset of shafts radial ±0.25 mm Max. offset of shafts axial ±0.4 mm Max. offset of shafts angular ±4° Torsion spring stiffness 150 Nm/rad Radial spring stiffness 25 N/mm Moment of inertia 8 gcm² Max. clamping torque 150 Ncm Weight 15 g Material Flange: Aluminium, anodised, Bellows: stainless steel Order number(s) FB29B0606 Bellows coupling: Ø d1 = 6 mm, Ø d2 = 6 mm FB29B1010 Bellows coupling: Ø d1 = 10 mm, Ø d2 = 10 mm Drawings All dimensional specifications in mm  Wachendorff Automation GmbH & Co. KG - Industriestrasse 7 - D-65366 Geisenheim wdg@wachendorff.de - Tel. +49 6722 996525 - Fax +49 6722 996570
FB29B0606 价格&库存
很抱歉,暂时无法提供与“FB29B0606”相匹配的价格&库存,您可以联系我们找货
