BMHO69027002NF
BMHO69027002NF
    PCTEL
    825MHz,2.2GHz 2G,3G,5G,蜂窝,LTE 鞭状,直形 RF 天线 690MHz ~ 960MHz,1.7GHz ~ 2.7GHz 2dBi,2dBi N 型母头 杆安装架
BMHO69027002NF 数据手册
INFRASTRUCTURE ANTENNAS Omnidirectional Antenna - 4G LTE Vented BMHO69027002NF VenU® 4G LTE/Cellular & Wi-Fi Omnidirectional Antenna RoHS COMPLIANT The VenU BMHO69027002 is a high performance omnidirectional antenna designed for outdoor base station applications. It supports high capacity data throughput for 4G LTE Cellular, 3G and Wi-Fi wireless networks in a compact housing. The antenna can be direct mounted via a built-in N Female bulkhead termination that allows direct mounting to the radio equipment. Features • Rugged, UV-resistant, low-profile housing for outdoor applications • Innovative vented design with aerated cap and base drain system • N Female bulkhead for direct radio mount access BMHO69027002NF BAM1009 mount STANDARD CONFIGURATION Model Connector Mount BMHO69027002NF N Female bulkhead BAM-1009 base station aluminum mount kit for masts up to 2.4 inches in diameter (sold separately) ELECTRICAL SPECIFICATIONS - RF ANTENNA Frequency Range Gain VSWR Azimuth Half Power Beamwidth Elevation Half Power Beamwidth 690-960 MHz / 1700-2700 MHz 2 dBi / 2 dBi < 2.5 360° / 360° 45° / 35° ELECTRICAL SPECIFICATIONS - RF ANTENNA, continued Average Power Polarization Nominal Impedance 25 watts max. Vertical, linear 50 ohms MECHANICAL & ENVIRONMENTAL SPECIFICATIONS Dimensions Weight Housing Material 9 H x .94 OD in (22.86 x 2.38 cm) 0.30 lbs (0.14 kg) Black UV-Stable ASA MECHANICAL & ENVIRONMENTAL SPECIFICATIONS, continued Rated Wind Temperature Range Lateral Thrust @ Rated Wind Bending Moment @ Rated Wind 125 mph -40°C to +85°C 3.1 lbs 1.1 ft-lbs RoHS Compliance: 2002/95/EC and 2003/11/EC PCTEL, Inc. WEB: www.antenna.com
BMHO69027002NF 价格&库存
很抱歉,暂时无法提供与“BMHO69027002NF”相匹配的价格&库存,您可以联系我们找货
