9211D
9211D
    PCTEL
    1.621GHz GNSS,GPS 模块 RF 天线 1.616GHz ~ 1.6265GHz 4dBic SMA 公头 磁性
9211D 数据手册
GPS/AVIATION SPECIAL PURPOSE ANTENNAS Iridium™ Approved Antennas 9211D Iridium™ Magnet Mount Passive Antenna The 9211D is a high performance passive 1616 to 1626.5 MHz, RHCP antenna, specifically designed to operate with the Iridium™ Satellite communication system. It features a precisely tuned custom ceramic patch antenna element and a matching network. The 9211D antenna is enclosed in a rugged, fully weatherproof housing that allows the Iridium Satellite SBD modem to be mounted away from the elements, yet fully meeting Iridium’s radiated power requirements. Its top cover (radome) is composed of high-grade GE plastic and the zinc base is equipped with both screw holes and magnets for ease of installation. The antenna comes standard with 6.6’ (2 meters) of high quality Shikoku coaxial cable and an SMA male connector. Features • • • • Ideal for Iridium™ Satellite Short Data Service applications Weather proof housing Magnet or screw mount RoHS compliant Antenna Response Specifications Frequency Range Gain Polarization Axial Ratio VSWR 1616 MHz to 1626.5 MHz 4 dBic @ Zenith (max) Right Hand Circular 3 dB @ Zenith (max)
9211D 价格&库存
很抱歉,暂时无法提供与“9211D”相匹配的价格&库存,您可以联系我们找货
