GNSSPSM-S1-S1
GNSSPSM-S1-S1
    PCTEL
    插件
    1.5875GHz Galileo,GLONASS,GNSS,GPS 模块 RF 天线 1.565GHz ~ 1.61GHz -2dBic,3dBic SMA(2) 螺柱,通孔
GNSSPSM-S1-S1 数据手册
MOBILE ANTENNAS Plus - Permanent Mount GNSSPSM-S1-S1 GNSS+ Combination Antennas with High Rejection Technology RoHS COMPLIANT The Max-Matics™ GNSS+ High Rejection combination antennas have been designed to provide maximum performance and versatility for telematics applications, including fleet monitoring and asset tracking. By combining the high performance of a GNSS antenna with the flexibility to add virtually any PCTEL permanent mount compatible mobile antenna, the GNSS+ provides reliable, real-time wireless voice and data coverage for fleet monitoring applications. This antenna is designed to facilitate installation. It includes all necessary hardware for “blind” installations when removal of the vehicle’s headliner is not desired. GNSSPSM-S1-S1 Its precise performance and ease of installation provides outstanding value and flexibility for the most demanding wireless mobile applications. Features • Combination GNSS/mobile antenna design provides GPS/QZSS/GALILEO/GLONASS tracking coverage and voice/data wireless coverage capabilities for fleet monitoring or fleet tracking applications • UV-stable housing features attractive industrial design • Proprietary filtering design allows wideband coverage while achieving superior out-of-band rejection for all GNSS frequencies • Various connector options are available for both the GNSS antenna and the mobile antenna’s permanent mount STANDARD CONFIGURATION Model Cable Connector* Mount Mobile Antenna Mount Interface GNSSPSM-S1-S1 17’ RG-174 (GNSS antenna side) 17’ RG-58/U (mobile antenna side) SMA Plug (GNSS) SMA Plug (Mobile) 3/4-inch hole permanent stud 1-1/8”-18 thread mount ELECTRICAL SPECIFICATIONS - GNSS ANTENNA Frequency Band LNA Gain Element Gain Polarization Out of Band Rejection 1565-1610 MHz @ 3.0VDC: 26dB (typical) 3 dBic @ 90° -2 dBic @ 20° Right hand circular f0 = 1586 MHz f0 +/- 50MHz : ≥ 60dBc f0 +/- 60MHz : ≥ 70dBc ELECTRICAL SPECIFICATIONS - GNSS ANTENNA, continued Current Draw DC Voltage Noise Figure VSWR Nominal Impedance < 25 mA (typical) 2.8-6.0 V (operating) ≤ 12.0 V (survivability) < 2.0 dB (typical) 2.0:1 (maximum) 50 ohms MECHANICAL & ENVIRONMENTAL SPECIFICATIONS Dimensions 2.25W x 4.25 L x 1.25 H in (57 x 107 x 31.75 mm) Storage Temperature Range Operating Temperature Range Burn-out Protection Black UV-Stable -40°C to +85°C Polycarbonate -40°C to +85°C Protected from damage by RF signals when the power received by the antenna is no greater than +17 dBm, maximum Housing Material * Consult Customer Service for other connector options. 46 PCTEL, Inc. WEB: www.antenna.com
GNSSPSM-S1-S1 价格&库存
很抱歉,暂时无法提供与“GNSSPSM-S1-S1”相匹配的价格&库存,您可以联系我们找货
