3917D-5M-SMA
3917D-5M-SMA
    PCTEL
    1.575GHz GNSS,GPS 模块 RF 天线 1.565GHz ~ 1.585GHz -2dBic,3dBic SMA 公头 磁性
3917D-5M-SMA 数据手册
GNSS ANTENNAS GPS L1 Magnetic Mount Antennas 3917D Value Mobile GPS Antenna RoHS COMPLIANT The 3917D GPS antenna is a high performance antenna with a wide voltage range, ideally suited for vehicular telematics applications. Using internal magnets or screw mount holes, the antenna offers greater installation flexibility for vehicle rooftop locations. The 3917D antenna features 30 dB gain low noise amplifier and a SAW filter. Featuring 2.7 to 5 volt operation, the antenna can be used with the vast majority of GPS L1 systems available. Features • Voltage range 2.7-5 V • LNA 30 dB gain typical • Low noise figure 1.5 dB 3917D STANDARD CONFIGURATION Model Cable Connector Mount 3917D 9.8’ (3 meters) highly flexible 174 sized cable Male SMA standard* Magnetic (5 lb lift-off force) or permanent (pre-threaded for 3 x M2.5 screws) ELECTRICAL SPECIFICATIONS - GNSS ANTENNA Frequency Range LNA Gain Element Gain Polarization Out of Band Rejection 1575.42 ± 10 MHz 30 dB 3 dBic @ 90° -2 dBic @ 20° Right hand circular > 30 dB @ ± 30 MHz ELECTRICAL SPECIFICATIONS - GNSS ANTENNA, continued Current Draw DC Voltage Noise Figure 8.3 mA 2.7-5 VDC 1.5 dB (typical) Weight Housing Material 0.26 lbs (120 g) ASA Temperature Range ESD Circuit Protection Ingress Protection -40°C to +85°C operating 15 KV IP67 MECHANICAL SPECIFICATIONS Dimensions 2.05” L x 2.33” W x 0.54” H (52.1 x 59.2 x 13.6 mm) ENVIRONMENTAL SPECIFICATIONS * Consult PCTEL Customer Service for other connector options. PCTEL, Inc. WEB: www.antenna.com
3917D-5M-SMA
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一种红外遥控接收器。
2. 器件简介:EL817是一款红外遥控接收器,用于接收红外信号并转换成电信号输出。
3. 引脚分配:EL817共有3个引脚,分别为VCC、GND和OUT。
4. 参数特性:工作电压范围为3V至5.5V,工作电流为1.5mA,接收频率为38kHz。
5. 功能详解:EL817能够接收38kHz的红外信号,并将其转换成TTL电平的输出信号。
6. 应用信息:EL817广泛应用于电视、空调等家用电器的红外遥控系统中。
7. 封装信息:EL817采用SOP16封装。
3917D-5M-SMA 价格&库存
很抱歉,暂时无法提供与“3917D-5M-SMA”相匹配的价格&库存,您可以联系我们找货
