BOAH515905NM
BOAH515905NM
    PCTEL
    5.5GHz 蓝牙,Wi-Fi 圆顶 RF 天线 5.1GHz ~ 5.9GHz 5dBi N 型公头 连接器安装,立杆式安装
BOAH515905NM 数据手册
INFRASTRUCTURE ANTENNAS Omnidirectional Carrier Grade Antennas - Wi-Fi BOAH Series Horizontally Polarized Omnidirectional Base Station Platform RoHS COMPLIANT PCTEL’s BOAH horizontally polarized omnidirectional antennas are designed for long-lasting operation with outdoor 802.11 ac access points. Their rugged design withstands harsh environments, making the antennas ideal for industrial wireless, enterprise, and military applications. The antennas in this series are DC grounded for ESD protection of radio components. Features • • • • • • • UV-stable, white ruggedized plastic radome Chrome plated mounting base DC grounded design Fully sealed IP67 design Type N Male or Female connector options Wind rated 125 mph Temperature -40°C to +85°C STANDARD CONFIGURATION BOAH515905NF Model BOAH515905NM BOAH515905NF BOAH242505NF BOAH242505NM Connector Mount Options N Male N Female N Female N Male BAM1009 or BAM1011-HCA mast mounts sold separately (all models) ELECTRICAL SPECIFICATIONS - RF ANTENNA Model BOAH515905NM BOAH515905NF BOAH242505NF BOAH242505NM Frequency Range Polarization Nominal Gain VSWR 5.1-5.9 GHz 5.1-5.9 GHz 2.4-2.5 GHz 2.4-2.5 GHz Horizontal Horizontal Horizontal Horizontal 5 dBi 5 dBi 5 dBi 5 dBi < 2:1 < 2:1 < 2:1 < 2:1 Elevation Half Power Beamwidth 30° 30° 30° 30° Maximum Power 40 watts 40 watts 40 watts 40 watts Nominal Impedance 50 ohms 50 ohms 50 ohms 50 ohms MECHANICAL & ENVIRONMENTAL SPECIFICATIONS Model BOAH515905NM BOAH515905NF BOAH242505NF BOAH242505NM Dimensions Weight Housing Material 1.26 OD x 6.32 L in (3.20 x 16.05 cm) 1.26 OD x 6.55 L in (3.20 x 16.63 cm) 1.26 OD x 12.85 L in (2.41 x 32.63 cm) 1.26 OD x 12.62 L in (3.20 x 32.05 cm) 4 oz 4 oz 6 oz 6 oz White UV-stable ASA White UV-stable ASA White UV-stable ASA White UV-stable ASA MECHANICAL & ENVIRONMENTAL SPECIFICATIONS, continued Model BOAH515905NM BOAH515905NF BOAH242505NF BOAH242505NM Bending Moment at Rated Wind Lateral Thrust at Rated Wind Equivalent Flat Plate Area 0.57 lbf-ft 0.57 lbf-ft 2.7 lbf-ft 2.7 lbf-ft 2.1 lbf 2.1 lbf 5.0 lbf 5.0 lbf 0.029 ft2 0.030 ft2 0.064 ft2 0.062 ft2 PCTEL, Inc. WEB: www.antenna.com
BOAH515905NM 价格&库存
很抱歉,暂时无法提供与“BOAH515905NM”相匹配的价格&库存,您可以联系我们找货
