DAA4959-14DP
DAA4959-14DP
    PCTEL
    5.4GHz 蓝牙,Wi-Fi 鞭状,直形 RF 天线 4.9GHz ~ 5.9GHz 14.6dBi N 型母头(2) 墙式安装
DAA4959-14DP 数据手册
INFRASTRUCTURE ANTENNAS Directional Endfire Array Antenna DAA4959-14DP 5 GHz Dual-Polarized Directional Array Antenna RoHS COMPLIANT This 5 GHz dual port, dual-polarized directional array antenna provides high gain and managed sidelobes pattern shaping that supports a variety of broadband wireless access applications, including point-to-point wireless backhaul and point-to-multi point trackside Wi-Fi. The platform’s discrete directional antenna technology combines two traditional antennas into a single package without sacrificing performance. Unlike traditional panel antennas, this endfire array antenna is physically and visually less obtrusive, making it ideal for installations with limited space availability. Features • • • • • • 802.11n MIMO performance for optimized data speed and throughput Dual port, dual-polarization package replaces two traditional directional panels Gain and pattern optimized for point-to-point and point-to-multi point connectivity Small footprint design can accommodate tunnel or trackside installations with as little as 9 cm clearance Includes a robust wall/mast mount bracket designed to withstand maximum 56 m/s wind speed High front-to-back ratio allows for back-to-back mounting of antennas; ideal for trackside or roadside coverage DAA4959-14DP STANDARD CONFIGURATION Model Cable Connector Mount DAA4959-14DP Mating cable assemblies sold separately 2 x N Female Bulkhead Wall mount clamp bracket included ELECTRICAL SPECIFICATIONS - RF ANTENNA Frequency Range Gain VSWR Azimuth Half Power Beamwidth Elevation Half Power Beamwidth 4.9-5.9 GHz 14.6 dB < 2.0:1, typical < 2.5:1, across band 23-35° 23-35° ELECTRICAL SPECIFICATIONS - RF ANTENNA, continued Front to Back Ratio Side Lobes > 35 dB 12-15 dB below peak Nominal Impedance 50 ohms Polarization Port-to-Port Isolation Dual port, dual orthogonal 19 dB minimum MECHANICAL & ENVIRONMENTAL SPECIFICATIONS Dimensions Ingress Protection Temperature Range Rated Wind Antenna: 1.1 OD x 11.2 L in (2.85 x 28.5 cm) Mounting Bracket: 3.7 OD x 5.3 L x 1.57 W in (9.6 x 13.5 x 11.5 cm) IP67 -40°C to +70°C 125 mph PCTEL, Inc. WEB: www.antenna.com
DAA4959-14DP 价格&库存
很抱歉,暂时无法提供与“DAA4959-14DP”相匹配的价格&库存,您可以联系我们找货
