FPMI245808-DP4NF
FPMI245808-DP4NF
    PCTEL
    2.448GHz,5.45GHz 蓝牙,Wi-Fi 面板 RF 天线 2.4GHz ~ 2.49GHz,4.9GHz ~ 6GHz 7.6dBi,8dBi N 型母头 立杆安装,壁装
FPMI245808-DP4NF 数据手册
INFRASTRUCTURE ANTENNAS Wi-Fi Panel Antennas - 802.11ac MIMO VenU® FPMI2458 Series VenU® Dual-Band, 802.11 ac Panel Antennas RoHS COMPLIANT The FPMI2458 compact directional panel antennas provide RF efficient support of 802.11ac MIMO access points for broadband wireless communications. Both models provide dual-band 2.4/5 GHz coverage in each of its four ports. The panels are compact and rugged and may be wall or pipe mounted indoors or outdoors. An adjustable, heavy-duty pipe mount is included for outdoor installations. Features • Each of the four RF ports provides dual-band 2.4/5 GHz operation • UL 94 HB ASA radome and PC board conform to UL’s high flame retardant rating to accommodate stringent building code flammability requirements • Attractive, UV-stable housing offers a low-profile option for aesthetic considerations • Includes a heavy-duty articulating mount for outdoor, pipe mount installations FPMI2458-DP4RPSMA FPM-1005 mount STANDARD CONFIGURATION Model FPMI245808-DP4NF FPMI245805-DP4NF Cable Connector Mount N Female FPMI245805-DP4NF FPM-1005 wall/pipe mount provides +20 / -90° in the vertical tilt, and ±70° horizontal adjustment. Mount accommodates poles of min. 1.5 inches. Mount is included. Purchase N Male mating cable assemblies separately. Purchase N Male mating cable assemblies separately. N Female ELECTRICAL SPECIFICATIONS Model Frequency Range Gain VSWR FPMI245808-DP4NF FPMI245805-DP4NF 2.4-2.49 GHz / 4.9-6.0 GHz 2.4-2.49 GHz / 4.9-6.0 GHz 7.6 dBi / 8 dBi 5 dBi / 5 dBi 2.0 maximum 2.0 maximum Horizontal 3 dB Beamwidth 60° / 60° 85° / 85° Vertical 3 dB Beamwidth 60° / 60° 85° / 85° ELECTRICAL SPECIFICATIONS Front to Back Ratio Port to Port Isolation Average Power Nominal Impedance Polarization 20 dB typical 18 dB (min.) 20 watts 50 ohms ±45° linear slant horizontal and vertical MECHANICAL & ENVIRONMENTAL SPECIFICATIONS (ALL MODELS) Dimensions Weight Housing Material Ingress Protection Rated Wind 7.8 L x 7.8 W x 1.3 H in (19.7 x 19.7 x 3.4 cm) 2.6 lbs (1.2 kg) including adjustable mount White UV-Stable ASA IP67* 135 mph Temperature Range -40°C to +85°C * When installed according to the manufacturer’s installation instructions. PCTEL, Inc. WEB: www.antenna.com
FPMI245808-DP4NF 价格&库存
很抱歉,暂时无法提供与“FPMI245808-DP4NF”相匹配的价格&库存,您可以联系我们找货
